JAVA memory heap size and ASDM or IDM
Mar 9th, 2010
  • Bronze, 100 points or more
When I try to load ASDM or IDM with either IE or Firefox, I receive the following error
ERROR: Current JAVA memory heap size is less than 256MB.
You must increase memory size before running IDM.
Click on help for more information.
Instruction provided by Cisco refer to JAVA 1.4.2 and 1.5
We run Java verison 6 and the instructions - although similar - do not work for JAVA version 6.
I did enter the  -Xmx256m in the Java Runtime Parameters field but it still failed.
I also rebooted the PC just for fun.
My exact JAVA version:
JAVA 6 update 18 build 1.6.0_18-b07
Any help would be wonderful!!!!
Tks
Frank
New document  https://supportforums.cisco.com/docs/DOC-16442 is created from this discussion. Thanks Message was edited by: Ankur Thukral
Overall Rating: 4.7 (3 ratings)
RAMACHANDRA R Wed, 03/10/2010 - 00:04
Hi ,
Please do check your Operating System like 32bit or 64bit, please download the JRE based on your operating system and it should fix your problem immediately, please refer the below link for downloading latest compataible JRE for your OS.
https://cds.sun.com/is-bin/INTERSHOP.enfinity/WFS/CDS-CDS_Developer-Site/en_US/-/USD/ViewProductDetail-Start?ProductRef=jre-6u18-oth-JPR@CDS-CDS_Developer
Rgds
Rama
fsebera Wed, 03/10/2010 - 08:01
Tks
I removed JAVA 6 from my MS XP OS and installed JAVA 5. This JAVA down grade fixed my IPS management issue but now security folks have issues with my old outdated JAVA version. Win some, lose some.
Frank
fsebera Mon, 03/29/2010 - 07:44
The only way I could get this thing to operate was to downgrade to JAVA 5.
If there is another way, no one is talking.
Good luck
Frank
trippi Mon, 04/05/2010 - 11:47
What versions of IE/Firefox/ASDM are you using?
trippi Tue, 04/06/2010 - 06:55
If you didn't already, try setting it under both the user and system runtime properties...
You could also try setting it to 512, or try setting the initial heap size to 256.
java -Xms -Xmx
charg_in1 Wed, 04/28/2010 - 17:53
Hi There,
Try modifying the shortcut that launches ASDM. I found mine runs javaw but sets the min mem to 64 and max to 256. I changed these to min 256 and max 512 and that fixed the issue. Im running the latest Java.
Rgds,
DJ
HQABMC2004 Tue, 05/18/2010 - 11:51
Hi DJ,
I am having same issue, could you please post the full target path or IDM shortcut?
Thanks in advance
ST
charg_in1 Thu, 05/20/2010 - 07:18
"C:\Program Files (x86)\Java\jre6\bin\javaw.exe" -Xms256m -Xmx512m -Dsun.swing.enableImprovedDragGesture=true -classpath lzma.jar;jploader.jar;asdm-launcher.jar;retroweaver-rt-2.0.jar com.cisco.launcher.Launcher
GrumpyBear Wed, 06/02/2010 - 12:09
Updated my Java and ran into this problem.  You think Cisco would change the target to meet the minimum memory requirements for the most memory hungry application using the ASDM-IDM launcher.
Can the original poster please mark this as "fixed" please?
abbeypressiss Mon, 06/14/2010 - 13:10
I'm running ASDM Version 5.2(5) on Windows 2003 5.2. Java Version is 1.6.0_20.
I solved the Java memory heap size problem by modifying the asdm-launcher.config file in the same directory as asdm-launcher,exe. I changed two vmparam entries, the -Xms and -Xmx to 256m and 512m respectively.
Christopher Dreier Sat, 11/06/2010 - 18:02
  • Silver, 250 points or more
Hello fsebera,
This is likely due to, "CSCtf21045: With Java 6, Update 18, IDM does not load due to heap size check." This issue is resolved in ASDM 6.3(4) and 6.3(4)53, which are currently available on cisco.com.
Thank you,
Blayne Dreier
Cisco TAC Escalation Team
**Please check out our Podcasts**
TAC Security Show: http://www.cisco.com/go/tacsecuritypodcast
TAC IPS Media Series: https://supportforums.cisco.com/community/netpro/security/intrusion-prevention?view=tags&tags=tac_ips_media_series
I have a similar issue, but just when selecting the IPS button under configuration.
I'm running IE7 and Java 1.6.0_21 on XP, with ASDM v5.2(5) on ASA 7.2(5) .
ADSM runs fine, just the IPS section.
****EDIT:
I just cracked this. It was slightly different for mine, as the Java Control panel change or the shortcut edit didn't work.
On mine, I had to do the following:
- Right click "Cisco ASDM Launcher" > Properties
- Click "Find Target"
- opens ASDM target directory
- disabled "asdm-launcher.config" file from read-only
- edit the file, changing the 2 params for Xms and Xmx to 256 & 512
- save, close and revert to read-only
- restart ASDM and my IPS section works
cisco steps Mon, 02/21/2011 - 17:41
I am still having problem w/ IDM, JAVA memory heap size
I have window 7
64 bit
can someone assist pls
thank you
aldoleiva Mon, 02/21/2011 - 20:45
I have windows 7 (32bit) and Java and ASDM info below
Java Version = 1.6.0_22
Local DM Launcher Version = 1.4.18
Minor change from older post!!
On mine,
- Click "open file location"
-copy file  "asdm-launcher.config" to desktop and disabled "asdm-launcher.config" file from read-only
- delete "asdm-launcher.config" file in ASDM folder
- edit the file on desktop, changing vmparam to = vmparam -Xmx300m
- copy file from desktop "asdm-launcher.config" into ASDM folder
- save, close and revert file to read-only
ohhh yeahhh
cisco steps Tue, 02/22/2011 - 10:50
ohhh yeahhh , worked as you mentioned. Ty very much...
nhandinhle2002@... Mon, 05/02/2011 - 06:44
Dear ocporbust, i tried emulate Cisco IPS 4235 with Qemu. I have problem with Jave memory heap size with IDM login. Can you help me ?
My operating system is Window 7 64bit, Java 6 Update 25 64 bit. Thank you very much
yevgeniy.fedko Mon, 01/09/2012 - 10:50
Additional work around, worked with IPS IDM v6,
IDM was strarting Java along with:
C:\Documents and Settings\Administrator\Application Data\Sun\Java\Deployment\cache\6.0\47\86032ef-66189461
I opened it and edited sting to:
Since that, no IDM issue )
zhiping wan Sun, 12/01/2013 - 07:55
i got a problem also like this,your solution  works ,thank you  so much!
Ravi Singh Fri, 01/31/2014 - 09:03
  • Cisco Employee,
You can increase the Heap size of Java through "Control Panel>JAVA>JAVA>View"
