WPA & WPA2 PSK – Cisco 1142 AP
Answered Question
May 6th, 2011
I’m configuring a Cisco 1142n AP in autonomous mode. The networking part is successfully working, multiple VLANs, SSIDs etc. I would like to configure one of my wireless networks to work with WAP2-PSK and the other with WPA-PSK.
I’m confused as to what encryption to set on each radio and the ciphers to use on the SSID for each vlan to enable the best possible security. I’m not using a RADIUS sever in my network .
Can someone point me in the right direction with the right CLI commands?
Thanks.
Correct Answer by Surendra BG about 6 years 1 month ago
Here is the configuration we need to do for WPA and WPA 2
WPA Uses TKIP as the Encryption
en
conf t
dot11 ssid
auth open
auth key-man wpa
wpa-psk ascii
vlan #
end
en
int dot11 0/1
encryption vlan # mode ciphers TKIP
end
WPA Uses AES as the Encryption
en
conf t
dot11 ssid
auth open
auth key-man wpa version 2
wpa-psk ascii
vlan #
end
en
int dot11 0/1
encryption vlan # mode ciphers aes
end
hers is the document that i have written that does the same as well!! in the below link the SSID TWO uses WPA and SSID THREE uses WPA-2
https://supportforums.cisco.com/docs/DOC-14496
Lemme know if this naswered ur question and please dont forget to rate the useful posts!!
Surendra
Overall Rating: 5 (3 ratings)
Correct Answer
Surendra BG Fri, 05/06/2011 - 20:01
  • Cisco Employee,
en
conf t
dot11 ssid
auth open
auth key-man wpa
wpa-psk ascii
vlan #
end
en
int dot11 0/1
end
en
conf t
dot11 ssid
auth open
wpa-psk ascii
vlan #
end
en
int dot11 0/1
end
Surendra
MrPrince1979 Sun, 05/08/2011 - 18:54
Thanks very much Surendra, this was exactly what I was looking for. Nice article too.
EvaldasOu Wed, 08/29/2012 - 09:18
Hi Surendra,
AP#(config-ssid)#authentication key-management wpa ?
  cckm      allow CCKM clients
  optional  allow legacy clients
So if I will choose CCKM it means I will be using WPA2? , and if I just press enter there ( ) it means I will be using WPA?
This is on AP model 1240a/g
Thanks!
George Stefanick Wed, 08/29/2012 - 09:25
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, October 2015
Evaldas,
Not so.. WPA/TKIP is WPA, WPA2/AES is WPA2. CCKM is used for 802.1X, like EAP-PEAP for example. To be clear, you have 2 type of security
PSK - Preshare Key
802.1X - EAP
CCKM is used for EAP, not PSK. Make sense, if not let me know..
EvaldasOu Wed, 08/29/2012 - 09:31
Hi George,
Thank you very much for your very fast answer!
That's clear. So I think if I want to use WPA2 on this AP ( 1240) I just need to set my encryption as AES-CCM?
dot11 ssid cisco
   vlan 100
   authentication open
   guest-mode
   wpa-psk ascii 7 123456712305051033
interface Dot11Radio0
encryption vlan 100 mode ciphers aes-ccm
I can't find where we should apply command with a version of WPA ( if we want to use WPA 1 or WPA2)
George Stefanick Wed, 08/29/2012 - 10:08
When you select the "key-management" do a ? you will see version 1 or 2. If you dont you need to upgrade your firmware on that ap to support it,
As for AES-CCMP .
EvaldasOu Wed, 08/29/2012 - 10:23
AP(config-ssid)#authentication key-management ?
  wpa   allow WPA clients
AP(config-ssid)#authentication key-management wpa ?
So no version 1 or 2 there. That's all that I can see. For sure I will need software upgrade there?
IF I would choose:
AP(config-ssid)#
authentication key-management wpa ( and hit an enter key. Which version of WPA I will be using? If encryption is set like this? :
George Stefanick Wed, 08/29/2012 - 10:31
yea, looks like you need to upgrade ...
When you hit <?> you will see version 1 or 2 ...
George Stefanick Wed, 08/29/2012 - 10:32
yes, WPA w/ AES-CCMP would be picked.
Which isnt standard, WPA-TKIP and WPA2-AES is standard.
EvaldasOu Wed, 08/29/2012 - 10:38
Thanks George!
These AP's would need a big software upgrade No WPA2-AES also
George Stefanick Wed, 08/29/2012 - 10:51
No worries big guy .. If you find any of this helpful please support the rating system. I'm trying to catch back up to Steve.
Related Content
