Does LAP 1250 support Mesh.
Answered Question
May 6th, 2011
Dear experts!
I see that Cisco LAP 1240 support Mesh mode, but I am not sure if LAP 1250 support or not? I can't find any document that say about this.
Best Regards!
Correct Answer by Surendra BG about 5 years 9 months ago
Depends on the WLC software that you are using!! if you are running the latest 7.0.116 then the Indoor mesh is supported using 1250 series APs..
With the 7.0.116.0 release, the mesh functionality is added in the Cisco  Aironet 1040, 1140, 1250, 1260, 1520, and 3500 series indoor access  points. The mesh backhaul radio supports the 802.11n data rate. When  operating in mesh mode, their mesh backhaul will support both the  802.11a and 802.11n data rate.
Lemme know this answered ur question and please dont forget to rate the usefull posts!!
Surendra
Overall Rating: 5 (1 ratings)
Correct Answer
Surendra BG Fri, 05/06/2011 - 21:57
Surendra
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
