05-05-2011 02:09 PM - edited 03-06-2019 04:55 PM
I am trying to find out what would be the best way to limit the bandwith per switchport/user.
Our remote offices have 3560 with latest IOS running "c3560-ipbasek9-tar.122-55.SE1"
This is the topology for one of the remote offices, the rest of the offices are preety much the same, we have about 18 remote offices sharing a DS3 internet pipe:
(Remote Office) 2811 - 3560 --------T1-------- NOC (Where the ISP seats DS3)
We have two vlans 10 (data) and 15 (Voice), 15 is for the IP phones connected to the remote office switch 3560.
We are experiencing at times, users streaming videos/others clogging T1s, and slowing down the rest of the newtwork (Internet).
What I am trying to find out is if for example if we can limit bandwith on each switport to a specific speed; ex: 500kb, knowing they have a T1 of bandwith limitation to the internet and internal servers (NOC). Of course I don't want to affect the IP phones traffic.
Any advice will be awesome,
Thank you,
Zeek
05-12-2011 02:30 PM
So you experience congestion caused by Internet traffic (from the central site to the remote sites, right? Why don't you use QoS, mark the VoIP traffic with a higher COS marker and prioritize that on the port going into the T1 at the NOC? If necessary, you can also put "legit" office data traffic in a higher COS than Youtube traffic that way.
05-12-2011 08:21 PM
Hi Zeek,
To limit bandwidth on the port, you can enable mls qos function on switch.
let's say you have PC and VoIP connected to first 10 ports on switch, you can configure like this
SW#conf t
mls qos
int range fa0/1 - 10
switchport access vlan 10
switchport voice vlan 15
switch priority extend cos 1
mls qos trust cos
mls qos command is configured to tell switch that it should trust incoming cos traffic.default value is 0 so we have changed it to 1
this way voice traffic get higher priority over data traffic.
Jigar Dave
Note: if it solves your problem, mark it as answered and rate it.
05-13-2011 08:59 AM
I just replied to a post yesterday on 3750s,,i think you can use same commands on 3560 also :
On 3750s :
Rate limiting is not supported by 3750, but policing is:
One way to do egress rate-limiting is using: 'srr-queue bandwidth limit' command.
For e.g:
Switch(config)# interface gigabitethernet 1/0/2
Switch(config-if)# srr-queue bandwidth limit 70 ( this is terms of percentage )
Another Way is :
policy-map rate-limit
class class-default
police 1000000 8000 exceed-action drop
int gi1/0/3
service-policy input rate-limit
service-policy output rate-limit
That should limit inbound and outbound at 1Mb
Another example is :
mls qos
class-map match-any Policy
match ip dscp 0 8 16 24 32 40 48 56
policy-map limit30M
class Policy
police 30000000 512000 exceed-action drop
end
int gi 1/0/1
speed 100
duplex full
service-policy input limit30M
srr-que bandwidth limit 30 (expressed as % of 100/full or 30% of 100MB, which is 30MB)
i did not try this but this might wrk i guess,, please try in a lab if u have
i think you can kinda play with these commands
Try and look through the command reference for 3750 for many ways
These are my understandings
Lemme knw if this wrks
Thnx
