Interface administratively down
May 10th, 2011
Hi all,
  I am configuring a 2801 router . I set up ip address on the interface Fa 0/0 and  'no shutdown' command. But, after a restart , the interface is changing to down  again!
  What I must do to ?
Thanks in advanced!
Roman Rodichev Tue, 05/10/2011 - 14:06
is it just down or admin down? if it's just down then it's down because there's no live ethernet connection, is it plugged into anything?
Roman Rodichev Tue, 05/10/2011 - 15:37
If you do "show version" what does it say for configuration register, if it says something like 0xNN4N (where N is any number), then do these:
config t
config-register 0x2102
int fas0/0
no shut
exit
exit
write mem
reload
