05-11-2011 06:25 PM - edited 02-21-2020 05:20 PM
IPSEC between ASA and 877 using profiles for remote vpn policy
I have this working when using "groupauth etc" on the 877 but the site to site tunnel will not come up using vpn policy on the 877 "crypto isakmp profile RemoteAccessVPN"
ASA
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption aes
hash sha
group 1
lifetime 28800
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto map ASA1MAP 40 match address JDV-VPN
crypto map ASA1MAP 40 set pfs
crypto map ASA1MAP 40 set peer 120.151.3.247
crypto map ASA1MAP 40 set transform-set ESP-3DES-SHA
crypto map ASA1MAP 40 set security-association lifetime seconds 28800
crypto map OUTSIDE_MAP interface outside
access-list JDV-VPN extended permit ip host 10.10.19.19 host 10.10.10.100
access-list JDV-VPN extended permit ip host 10.10.19.19 host 10.10.9.254
nat (inside) 0 access-list JDV-VPN
tunnel-group 120.151.3.247 type ipsec-l2l
tunnel-group 120.151.3.247 ipsec-attributes
pre-shared-key *
Router
encr aes
group 2
crypto isakmp policy 2
encr 3des
group 2
crypto isakmp key * address 203.23.17.71 no-xauth
crypto isakmp nat keepalive 20
crypto isakmp client configuration group jdv
key jdv2011
dns 10.10.10.100
pool ippool
acl 102
match identity group jdv
client authentication list userauthen
isakmp authorization list groupauthor
client configuration address respond
crypto ipsec security-association lifetime seconds 86400
crypto ipsec transform-set remoteset esp-3des esp-sha-hmac
crypto ipsec transform-set jdvtrans esp-3des esp-sha-hmac
crypto dynamic-map dynmap 10
set transform-set remoteset
crypto map jdvmap isakmp-profile RemoteAccessVPN
crypto map jdvmap 10 ipsec-isakmp dynamic dynmap
crypto map jdvmap 11 ipsec-isakmp
set peer 203.23.176.71
set transform-set jdvtrans
set pfs group2
match address 104
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$FW_INSIDE$
no ip address
bridge-group 1
interface Dialer0
description $FW_OUTSIDE$
ip address 120.151.3.247 255.255.255.0
crypto map jdvmap
interface BVI1
description $ES_LAN$$FW_INSIDE$
ip address 10.10.10.1 255.255.255.0
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1412
ip local pool ippool 192.168.253.50 192.168.253.60
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0
ip nat inside source static tcp 10.10.10.1 22 interface Dialer0 22
ip nat inside source list 101 interface Dialer0 overload
logging trap debugging
access-list 101 deny ip 10.10.10.0 0.0.0.255 192.168.253.0 0.0.0.255
access-list 101 deny ip host 10.10.10.100 host 10.10.19.19
access-list 101 permit ip 10.10.10.0 0.0.0.255 any
access-list 102 permit ip 10.10.10.0 0.0.0.255 192.168.253.0 0.0.0.255
access-list 104 permit ip host 10.10.10.100 host 10.10.19.19
dialer-list 1 protocol ip permit
Any comments would be appreciated.
Thank you.
Steve
05-12-2011 05:29 AM
I notice the following on the configuration.
You have crypto map OUTSIDE_MAP applied on the outside interface while the peer is defined on the crypto map ASA1MAP. crypto map ASA1MAP is not applied any where.
what does the crypto map OUTSIDE_MAP contain? i.e. are there any other tunnels terminating on the crypto map OUTSIDE_MAP
If yes, then make the peer router a part of the crypto map OUTSIDE_MAP.
e.g. crypto map OUTSIDE_MAP 40 match address JDV-VPN
crypto map OUTSIDE_MAP 40 set pfs
crypto map OUTSIDE_MAP 40 set peer 120.151.3.247
crypto map OUTSIDE_MAP 40 set transform-set ESP-3DES-SHA
crypto map OUTSIDE_MAP 40 set security-association lifetime seconds 28800
If not, then apply the crypto map ASA1MAP on outside interface.
i.e. no crypto map OUTSIDE_MAP interface outside
crypto map ASA1MAP interface outside
On the router i notice you have the following configuration:
I would request you to make the dynamic map at a higher sequence in the crypto map. If it is at a lower sequence then the L2L tunnel will try and negotiate the tunnel with dynamic map here and create issues.
i.e. no crypto map jdvmap 10 ipsec-isakmp dynamic dynmap
crypto map jdvmap 12 ipsec-isakmp dynamic dynmap
Hope this helps.
Anisha
P.S.: please mark this thread as answered if you feel your query is resolved. Do rate helpful posts.
05-12-2011 04:46 PM
Oops that was a typo on the asa config for the interface map. Lowering the l2l sequence appears to have made a difference.
The situation has changed and it both sites have the same local & remote subnets. Nat will need to be implemented on the 877.
Local and remote sides are 10.10.10.0/24 and nat needs to be implemented on the 877 to be translated to 172.20.10.100
Configs are now:
ASA
crypto map ASA1MAP 40 set peer 120.151.31.247
access-list JDV-VPN extended permit ip host 10.10.18.50 host 172.20.10.100
tunnel...
877 Router
encr aes
group 2
encr 3des
group 2
crypto isakmp key ### address 203.23.17.71 no-xauth
crypto map jdvmap 9 ipsec-isakmp
set peer 203.23.17.71
set pfs group2
match address 104
access-list 104 permit ip host 10.10.10.100 host 172.20.10.100
access-list 101 deny ip host 10.10.10.100 host 10.10.10.100
05-12-2011 06:32 PM
Am confused..
What are the networks which need to talk? Also are any of them getting natted??
Anisha
P.S.:please mark this thread as answered if you feel your query is resolved. Do rate helpful posts.
05-12-2011 06:40 PM
On the asa side:
should be
access-list JDV-VPN extended permit ip host 10.10.10.50 host 172.20.10.100
Topology is:
asa has local network 10.10.10.0 on inside
877 has local network 10.10.10.0 on inside
I want to nat on the 877 side the host 10.10.10.100 to 172.20.10.100 so the ASA will see 172.20.10.100 (as defined in the crypto acl)
Not sure of the nat statement to implement on the 877 router.
Pleaes advise if further information is required.
05-12-2011 10:23 PM
I tried to use a route-map to acheive NAT of the internal ip on the 877 with:
ip nat pool PRIVATEPOOL 172.20.10.100 172.20.10.100 netmask 255.255.255.0
ip nat inside source route-map NATADDR pool PRIVATEPOOL overload
access-list 101 deny ip host 10.10.10.100 host 10.10.18.50
access-list 104 permit ip host 172.20.10.100 host 10.10.18.50
access-list 120 permit ip host 10.10.10.100 host 10.10.18.50
route-map NATADDR permit 1
match ip address 120
But it bombs out on the router:
2859: May 13 15:14:38.743 PCTime: ISAKMP:(2027):Checking IPSec proposal 1
002860: May 13 15:14:38.743 PCTime: ISAKMP: transform 1, ESP_3DES
002861: May 13 15:14:38.743 PCTime: ISAKMP: attributes in transform:
002862: May 13 15:14:38.743 PCTime: ISAKMP: SA life type in seconds
002863: May 13 15:14:38.743 PCTime: ISAKMP: SA life duration (basic) of 28800
002864: May 13 15:14:38.743 PCTime: ISAKMP: SA life type in kilobytes
002865: May 13 15:14:38.743 PCTime: ISAKMP: SA life duration (VPI) of 0x0 0x46 0x50 0x0
002866: May 13 15:14:38.743 PCTime: ISAKMP: encaps is 1 (Tunnel)
002867: May 13 15:14:38.743 PCTime: ISAKMP: authenticator is HMAC-SHA
002868: May 13 15:14:38.743 PCTime: ISAKMP: group is 2
002869: May 13 15:14:38.743 PCTime: ISAKMP:(2027):atts are acceptable.
002870: May 13 15:14:38.743 PCTime: IPSEC(validate_proposal_request): proposal part #1
002871: May 13 15:14:38.747 PCTime: IPSEC(validate_proposal_request): proposal part #1,
(key eng. msg.) INBOUND local= 120.151.31.247, remote= 203.23.176.71,
local_proxy= 172.20.10.100/255.255.255.255/0/0 (type=1),
remote_proxy= 10.10.18.50/255.255.255.255/0/0 (type=1),
protocol= ESP, transform= NONE (Tunnel),
lifedur= 0s and 0kb,
spi= 0x0(0), conn_id= 0, keysize= 0, flags= 0x0
002872: May 13 15:14:38.747 PCTime: Crypto mapdb : proxy_match
src addr : 172.20.10.100
dst addr : 10.10.18.50
protocol : 0
src port : 0
dst port : 0
002873: May 13 15:14:38.747 PCTime: map_db_check_isakmp_profile profile did not match
002874: May 13 15:14:38.747 PCTime: map_db_check_isakmp_profile profile did not match
002875: May 13 15:14:38.747 PCTime: map_db_check_isakmp_profile profile did not match
002876: May 13 15:14:38.747 PCTime: map_db_find_best did not find matching map
002877: May 13 15:14:38.747 PCTime: IPSEC(ipsec_process_proposal): proxy identities not supported
002878: May 13 15:14:38.747 PCTime: ISAKMP:(2027): IPSec policy invalidated proposal with error 32
002879: May 13 15:14:38.747 PCTime: ISAKMP:(2027): phase 2 SA policy not acceptable! (local 120.151.3.247 remote 203.23.17.71)
002880: May 13 15:14:38.747 PCTime: ISAKMP: set new node -659687587 to QM_IDLE
002881: May 13 15:14:38.747 PCTime: ISAKMP:(2027):Sending NOTIFY PROPOSAL_NOT_CHOSEN protocol 3
spi 2204537592, message ID = -659687587
05-15-2011 04:10 PM
Any suggestions on this one?
Steve
05-22-2011 06:25 PM
Any response on this one? Or would I be better off opening a TAC case?
05-24-2011 06:55 AM
I see that you have called the following Transform set on the ASA:
ESP-3DES-SHA
While the transform set configured is:
So the transform set ESP-3DES-SHA does not exist. Hence you are getting the following message in the debug:
Please configure the following transform set on the ASA;
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
And try connecting. Let me know how it goes. Hope this helps.
Anisha
P.S.: please mark this post as answered if you feel your query is resolved. Do rate helpful posts.
05-24-2011 04:21 PM
nope...
is configured on the asa and that was updated in the 3rd post...
NOTE I BELIEVE THIS PROBLEM STARTED TO OCCUR WHEN USING PROFILES FOR REMOTE AND L2L VPN
For reference config on both devices is as follows:
ASA:
access-list NO-NAT extended permit ip host 10.10.18.50 host 172.20.10.100
crypto map ASA1MAP 40 set peer 120.1.1.1
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp policy 15
encryption 3des
hash sha
group 1
lifetime 86400
tunnel-group 120.1.1.1 type ipsec-l2l
tunnel-group 120.1.1.1ipsec-attributes
Router:
encr aes
group 2
encr 3des
group 2
crypto isakmp key #r$456Jhg address 203.1.1.1 no-xauth
key 1234
dns 10.10.10.100
pool ippool
acl 102
crypto ipsec security-association lifetime seconds 28800
set peer 203.1.1.1
set pfs group2
match address 104
05-24-2011 06:57 PM
The following changes will make the tunnel to work fine. Please let me know if it helps.
On the Router:
no ip nat inside source route-map NATADDR pool PRIVATEPOOL overload
and
no crypto map jdvmap isakmp-profile RemoteAccessVPN
set isakmp-profile RemoteAccessVPN
Gino
Please rate the solutions.
