IPSEC VPN Setup on ASA 5510
I know I'm missing something really simple here, but I'm a relative newbie to Cisco, so bear with me.
We're in the process of setting up an ASA 5510 as our main VPN appliance.
The Outside interface of the 5510 faces our DMZ, the Inside interface sits on our main network.  The 5510 uses radius for authentication going to a server on the same subnet for the authentication.  That works fine.  VPN client can connect to the 5510 and successfully authenticate.  Routes are pass through to the VPN client, no problem.  PC with VPN client can access internet (which is by design, it should use it's own internet connection), but cannot ping/access/trace over the tunnel at all.
My hunch is that this is a nat issue - but I am confused as to how the NAT should be configured - I've tried several configurations with no luck.
The VPN client is set to pull an ip address from the pool - 192.168.56.10 - 100.  The 5510 is sitting on a separate subnet (50.x/22).  This seems to work on the Cisco 1700 that it will be replacing just fine.  I mirrored routes and ACLs as well onto the new 5510.  No luck.  Client connects, authenticates, pulls an IP address and routes, but can't see anything on the inside of the 5510.
Any thoughts would be appreciated.
Thanks!
Yudong Wu Fri, 05/13/2011 - 09:58
  • Gold, 750 points or more
1. In general, you need bypass NAT for the vpn traffic to the client.
On ASA, you need add something similar like the following.
access-list nonat permit ip 192.168.50.0 255.255.252.0 192.168.56.0 255.255.255.0
nat (inside) 0 access-list nonat
2. check the routing and make sure the internal network know to send the packet to ASA if they need to reach 192.168.56.0
Tried that with no luck.  Still connecting, authenticating, pulling routes, but know traffic.  Checked the client - it isn't receiving any packets.  It's sending packets, showing some as encrypted, but most are bypassed.  Here's the config:
ASA Version 8.2(1)
hostname ASAVPN
names
interface Ethernet0/0
nameif Outside
security-level 0
ip address 255.255.255.240
interface Ethernet0/1
nameif Inside
security-level 100
ip address 192.168.50.5 255.255.252.0
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
shutdown
no nameif
no security-level
no ip address
ftp mode passive
access-list hpcovpn04_splitTunnelAcl standard permit 192.168.48.0 255.255.252.0
access-list hpcovpn04_splitTunnelAcl standard permit 192.168.36.0 255.255.255.0
access-list hpcovpn04_splitTunnelAcl standard permit 192.168.52.0 255.255.255.0
access-list hpcovpn04_splitTunnelAcl standard permit 192.168.53.0 255.255.255.0
access-list hpcovpn04_splitTunnelAcl standard permit 192.168.54.0 255.255.255.0
access-list hpcovpn04_splitTunnelAcl standard permit 192.168.66.0 255.255.255.0
access-list hpcovpn04_splitTunnelAcl standard permit host
access-list hpcovpn04_splitTunnelAcl standard permit 192.168.64.0 255.255.255.0
access-list hpcovpn04_splitTunnelAcl standard permit 192.168.65.0 255.255.255.0
access-list Inside_nat0_outbound extended permit ip 192.168.48.0 255.255.252.0 192.168.56.0 255.255.255.0
access-list nonat extended permit ip 192.168.48.0 255.255.252.0 192.168.56.0 255.255.255.0
pager lines 24
mtu Outside 1500
mtu Inside 1500
ip local pool DIAL-IN 192.168.56.10-192.168.56.254 mask 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
nat-control
nat (Inside) 0 access-list nonat
route Outside 0.0.0.0 0.0.0.0 12.54.190.17 1
route Inside 192.168.32.0 255.255.240.0 192.168.50.1 1
route Inside 192.168.52.0 255.255.252.0 192.168.48.5 1
route Inside 192.168.56.0 255.255.255.0 1
route Inside 192.168.64.0 255.255.255.0 192.168.50.2 1
route Inside 192.168.65.0 255.255.255.0 192.168.50.2 1
route Inside 192.168.66.0 255.255.255.0 192.168.48.5 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
aaa-server RADIUS protocol radius
aaa-server RADIUS (Inside) host 192.168.xx.xx
timeout 5
key xxx
http server enable
http 192.168.48.0 255.255.252.0 Inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map Outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map Outside_map interface Outside
crypto isakmp enable Outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
telnet 192.168.48.0 255.255.252.0 Inside
telnet timeout 5
ssh timeout 5
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
anyconnect-essentials
group-policy DfltGrpPolicy attributes
vpn-tunnel-protocol webvpn
group-policy hpcovpn04 internal
group-policy hpcovpn04 attributes
dns-server value 192.168.xx.xx 192.168.xx.xx
vpn-tunnel-protocol IPSec l2tp-ipsec
ipsec-udp enable
split-tunnel-policy tunnelspecified
split-tunnel-network-list value hpcovpn04_splitTunnelAcl
default-domain value henrypratt.com
tunnel-group hpcovpn04 type remote-access
tunnel-group hpcovpn04 general-attributes
address-pool DIAL-IN
authentication-server-group RADIUS
default-group-policy ourpolicy
tunnel-group ourpolicy ipsec-attributes
pre-shared-key *
prompt hostname context
Cryptochecksum:beee0e013866150a3079f917676574fd
: end
Yudong Wu Fri, 05/13/2011 - 10:49
I am not sure why you have this entry.
It should be route outside .......
You don't have any internal network which is overlapped with VPN client ip pool 192.168.56.x?
Issue a ping from client to an internal host and then check "show cry ipsec sa" to see if decrypt/encry count is incrementing?
Issue a ping from internal host to vpn client and then check "show cry ipsec sa" to see if decrypt/encry count is incrementing? also check vpn client statistics to see if encry/decry count incrementing as well.
interface: Outside
    Crypto map tag: SYSTEM_DEFAULT_CRYPTO_MAP, seq num: 65535, local addr:
      local ident (addr/mask/prot/port): (0.0.0.0/0.0.0.0/0/0)
      remote ident (addr/mask/prot/port): (192.168.56.10/255.255.255.255/0/0)
      current_peer: , username: xxxx
      dynamic allocated peer ip: 192.168.56.10
      #pkts encaps: 0, #pkts encrypt: 0, #pkts digest: 0
      #pkts decaps: 21, #pkts decrypt: 21, #pkts verify: 21
      #pkts compressed: 0, #pkts decompressed: 0
      #pkts not compressed: 0, #pkts comp failed: 0, #pkts decomp failed: 0
      #pre-frag successes: 0, #pre-frag failures: 0, #fragments created: 0
      #PMTUs sent: 0, #PMTUs rcvd: 0, #decapsulated frgs needing reassembly: 0
      #send errors: 0, #recv errors: 0
      local crypto endpt.: /10000, remote crypto endpt.: /10000
      path mtu 1500, ipsec overhead 82, media mtu 1500
      current outbound spi: A08643E8
    inbound esp sas:
      spi: 0x3B849C45 (998546501)
         transform: esp-aes esp-sha-hmac no compression
         in use settings ={RA, Tunnel,  UDP-Encaps, }
         slot: 0, conn_id: 20480, crypto-map: SYSTEM_DEFAULT_CRYPTO_MAP
         sa timing: remaining key lifetime (sec): 28585
         IV size: 16 bytes
         replay detection support: Y
         Anti replay bitmap:
          0x00000000 0x003FFFFF
    outbound esp sas:
      spi: 0xA08643E8 (2693153768)
         sa timing: remaining key lifetime (sec): 28584
         IV size: 16 bytes
         Anti replay bitmap:
          0x00000000 0x00000001
Yudong Wu Fri, 05/13/2011 - 11:22
If you don't see encry count incrementing in "show cry ipsec sa" when you ping from internal host to vpn client, it indicated that the packet from internal host either did not reach ASA or it did not entry tunnel for some reason.
Do a packet capture on Inside interface to see if the packet reach inside interface
1. define a ACL
2. then use capture command to apply acl to inside interface.
If you don't see the packet in capture, you need check the routing to see why inside host did not forward packet to ASA.
If you do see the packet, use "packet-trace" command to see how ASA handle it after receiving it on inside interface.
Yudong Wu Fri, 05/13/2011 - 11:40
can you post the full packet-trace command output with the command which you used.
Yudong Wu Fri, 05/13/2011 - 11:46
please run the capture on Inside interface first to confirm that the packet is received when you ping from a internal host to client.
ASAVPN# packet input outside tcp 192.168.49.29 http 192.168.56.10 http detaile$
Phase: 1
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Additional Information:
Found no matching flow, creating a new flow
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   192.168.56.10   255.255.255.255 Outside
Phase: 3
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
Forward Flow based lookup yields rule:
in  id=0xab7b0000, priority=111, domain=permit, deny=true
        hits=1, user_data=0x0, cs_id=0x0, flags=0x4000, protocol=0
        src ip=0.0.0.0, mask=0.0.0.0, port=0
        dst ip=0.0.0.0, mask=0.0.0.0, port=0, dscp=0x0
Result:
input-interface: Outside
input-status: up
input-line-status: up
output-interface: Outside
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
ASAVPN# packet input inside tcp 192.168.56.10 http 192.168.49.29 http detailed
Phase: 1
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   192.168.48.0    255.255.252.0   Inside
Phase: 3
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
in  id=0xab7f6650, priority=111, domain=permit, deny=true
        hits=9, user_data=0x0, cs_id=0x0, flags=0x4000, protocol=0
Result:
input-interface: Inside
input-status: up
output-interface: Inside
output-status: up
Action: drop
ASAVPN# packet input inside tcp 192.168.49.29 http 192.168.56.10 http detailed
Phase: 1
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
Phase: 3
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-group Inside_access_in in interface Inside
access-list Inside_access_in extended permit object-group DM_INLINE_PROTOCOL_1 any any
object-group protocol DM_INLINE_PROTOCOL_1
protocol-object ip
protocol-object udp
protocol-object tcp
in  id=0xac019928, priority=12, domain=permit, deny=false
        hits=3, user_data=0xa89f6e40, cs_id=0x0, flags=0x0, protocol=0
Phase: 4
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
in  id=0xab7f8420, priority=0, domain=permit-ip-option, deny=true
        hits=191, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
Phase: 5
Type: NAT-EXEMPT
Subtype:
Result: ALLOW
Config:
nat-control
  match ip Inside 192.168.48.0 255.255.252.0 Outside 192.168.56.0 255.255.255.0
    NAT exempt
    translate_hits = 4, untranslate_hits = 29
in  id=0xabfaa238, priority=6, domain=nat-exempt, deny=false
        hits=3, user_data=0xabd9c480, cs_id=0x0, use_real_addr, flags=0x0, protocol=0
        src ip=192.168.48.0, mask=255.255.252.0, port=0
        dst ip=192.168.56.0, mask=255.255.255.0, port=0, dscp=0x0
Phase: 6
Type: NAT
Subtype:
Result: ALLOW
Config:
nat (Inside) 0 0.0.0.0 0.0.0.0
nat-control
  match ip Inside any Outside any
    no translation group, implicit deny
    policy_hits = 0
in  id=0xac01aba8, priority=0, domain=nat, deny=false
        hits=3, user_data=0xac01aae8, cs_id=0x0, flags=0x0, protocol=0
Phase: 7
Type: NAT
Subtype: host-limits
Result: ALLOW
Config:
nat-control
    policy_hits = 0
in  id=0xabd9bb98, priority=0, domain=host, deny=false
        hits=137, user_data=0xac01aae8, cs_id=0x0, reverse, flags=0x0, protocol=0
Phase: 8
Type: VPN
Subtype: encrypt
Result: ALLOW
Config:
out id=0xac00e338, priority=70, domain=encrypt, deny=false
        hits=2, user_data=0x2f37c, cs_id=0x0, reverse, flags=0x0, protocol=0
        dst ip=192.168.56.10, mask=255.255.255.255, port=0, dscp=0x0
Phase: 9
Type: VPN
Subtype: ipsec-tunnel-flow
Result: ALLOW
Config:
Reverse Flow based lookup yields rule:
in  id=0xabf0ba20, priority=69, domain=ipsec-tunnel-flow, deny=false
        hits=2, user_data=0x31afc, cs_id=0x0, reverse, flags=0x0, protocol=0
        src ip=192.168.56.10, mask=255.255.255.255, port=0
Phase: 10
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
in  id=0xab7b1dd0, priority=0, domain=permit-ip-option, deny=true
        hits=449, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
Phase: 11
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 577, packet dispatched to next module
Module information for forward flow ...
snp_fp_tracer_drop
snp_fp_inspect_ip_options
snp_fp_tcp_normalizer
snp_fp_translate
snp_fp_adjacency
snp_fp_encrypt
snp_fp_fragment
snp_ifc_stat
Module information for reverse flow ...
snp_fp_tracer_drop
snp_fp_ipsec_tunnel_flow
snp_fp_translate
snp_fp_adjacency
snp_fp_fragment
snp_ifc_stat
Result:
input-status: up
output-status: up
Action: allow
Phase: 1
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   192.168.56.0    255.255.255.0   Outside
Phase: 3
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
        hits=2, user_data=0x0, cs_id=0x0, flags=0x4000, protocol=0
Result:
input-status: up
output-status: up
Action: drop
Yudong Wu Fri, 05/13/2011 - 11:57
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;}
Please use
We are troubleshoot the direction from internal host to vpn client.
accesss-list cap permit ip host 192.168.56.0 255.255.255.0
accesss-list cap permit ip 192.168.56.0 255.255.255.0 host
capture in access-list cap interface Inside
Then issue the ping from internal host to vpn client.
show capture in    << < will list the packet captured.
Phase: 1
Type: CAPTURE
Subtype:
Result: ALLOW
Config:
in  id=0xac00ec78, priority=12, domain=capture, deny=false
        hits=4099, user_data=0xabf59c30, cs_id=0x0, l3_type=0x0
        src mac=0000.0000.0000, mask=0000.0000.0000
        dst mac=0000.0000.0000, mask=0000.0000.0000
Phase: 2
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
in  id=0xab7f5c10, priority=1, domain=permit, deny=false
        hits=42154, user_data=0x0, cs_id=0x0, l3_type=0x8
Phase: 3
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Phase: 4
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
Phase: 5
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
        hits=332, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
Phase: 6
Type: CAPTURE
Subtype:
Result: ALLOW
Config:
in  id=0xabfaa3a8, priority=12, domain=capture, deny=false
        hits=1, user_data=0xabf59c30, cs_id=0xab7b4ed8, reverse, flags=0x0, protocol=0
        src ip=192.168.49.29, mask=255.255.255.255, port=0
Phase: 7
Type: NAT-EXEMPT
Subtype:
Result: ALLOW
Config:
nat-control
  match ip Inside 192.168.48.0 255.255.240.0 Outside 192.168.56.0 255.255.255.0
    NAT exempt
    translate_hits = 2, untranslate_hits = 0
in  id=0xabdab5a8, priority=6, domain=nat-exempt, deny=false
        hits=1, user_data=0xac019ab8, cs_id=0x0, use_real_addr, flags=0x0, protocol=0
        src ip=192.168.48.0, mask=255.255.240.0, port=0
Phase: 8
Type: NAT
Subtype:
Result: ALLOW
Config:
nat-control
    policy_hits = 2
        hits=8, user_data=0xac01aae8, cs_id=0x0, flags=0x0, protocol=0
Phase: 9
Type: NAT
Result: ALLOW
Config:
nat-control
    policy_hits = 2
        hits=277, user_data=0xac01aae8, cs_id=0x0, reverse, flags=0x0, protocol=0
Phase: 10
Type: VPN
Subtype: encrypt
Result: ALLOW
Config:
out id=0xabfa9e58, priority=70, domain=encrypt, deny=false
        hits=1, user_data=0x32634, cs_id=0x0, reverse, flags=0x0, protocol=0
Phase: 11
Type: VPN
Result: ALLOW
Config:
in  id=0xabfa9940, priority=69, domain=ipsec-tunnel-flow, deny=false
        hits=1, user_data=0x34354, cs_id=0x0, reverse, flags=0x0, protocol=0
Phase: 12
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
        hits=534, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
Phase: 13
Type: CAPTURE
Subtype:
Result: ALLOW
Config:
out id=0xac0197f8, priority=12, domain=capture, deny=false
        hits=0, user_data=0xabf59c30, cs_id=0xab7b4ed8, reverse, flags=0x0, protocol=0
        src ip=192.168.56.0, mask=255.255.255.0, port=0
        dst ip=192.168.49.29, mask=255.255.255.255, port=0, dscp=0x0
Phase: 14
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 800, packet dispatched to next module
snp_fp_tracer_drop
snp_fp_translate
snp_fp_adjacency
snp_fp_encrypt
snp_fp_fragment
snp_ifc_stat
snp_fp_tracer_drop
snp_fp_translate
snp_fp_adjacency
snp_fp_fragment
snp_ifc_stat
Result:
input-status: up
output-status: up
Action: allow
Yudong Wu Fri, 05/13/2011 - 12:24
Ok, so the problem is that the packet did not reach ASA inside interface when internal host sent the traffic to vpn client.
You need check your internal network hop by hop to see why the packet is not forwarded to ASA.
Yudong Wu Fri, 05/13/2011 - 14:50
Ok. at lease we made some progress.
If the server is pingable, vpn client does have the ip connectivity. You might need to check if DNS works o not.
From your configuration, you configured "default-group-policy ourpolicy" but I did not see any group-policy in the configuration with "ourpolicy".
After vpn client is UP, you can try if you can reach the internal server via DNS name.
Related Content
