Can't ping from core switch to other VLANs.
May 17th, 2011
Hi all,
Here is my network diagram:
From the core switch, I can only ping to vlan 1 (10.65.0.0/24). I can't ping to other vlans (2 & 3). I'm using Router-on-a-stick configuration. This is just a lab environment for practice for a newbie like me..
Any help will be much appreciated...
Geert Reijnders Tue, 05/17/2011 - 23:44
please attach the configs of your core switch and your router. Looking at your diagram I think you might be missing sub interfaces for the other two vlans on your router.
vinsanity02 Tue, 05/17/2011 - 23:57
Core_Switch#show run
Building configuration...
Current configuration : 1521 bytes
version 12.2
no service timestamps log datetime msec
no service timestamps debug datetime msec
service password-encryption
hostname Core_Switch
username cisco\admintest privilege 15 password 7 0822455D0A16
no ip domain-lookup
interface FastEthernet0/1
switchport mode trunk
duplex full
speed 100
interface FastEthernet0/2
duplex full
speed 100
interface FastEthernet0/3
duplex full
speed 100
interface FastEthernet0/4
duplex full
speed 100
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
ip address 10.65.0.6 255.255.255.0
ip classless
line con 0
line vty 0 4
login local
line vty 5 15
login local
end
Router1#show run
Current configuration : 2111 bytes
version 12.4
hostname Router1
enable secret 5 $1$mERr$hx5rVt7rPNoS4wqbXKX7m0
no ip domain-lookup
interface FastEthernet0/0
no ip address
duplex auto
speed auto
shutdown
no ip address
duplex full
speed 100
interface FastEthernet0/1.1
encapsulation dot1Q 1 native
ip address 10.65.0.1 255.255.255.0
interface FastEthernet0/1.2
encapsulation dot1Q 2
ip address 10.65.1.1 255.255.255.0
interface FastEthernet0/1.3
encapsulation dot1Q 3
ip address 10.65.2.1 255.255.255.0
interface Serial0/0/0
no ip address
interface Serial0/0/1
no ip address
shutdown
interface Serial0/1/0
no ip address
shutdown
interface Serial0/1/1
no ip address
shutdown
interface FastEthernet1/0
switchport mode access
shutdown
interface FastEthernet1/1
shutdown
interface FastEthernet1/2
shutdown
interface FastEthernet1/3
shutdown
interface FastEthernet1/4
shutdown
interface FastEthernet1/5
shutdown
interface FastEthernet1/6
shutdown
interface FastEthernet1/7
shutdown
interface FastEthernet1/8
shutdown
interface FastEthernet1/9
shutdown
interface FastEthernet1/10
shutdown
interface FastEthernet1/11
shutdown
interface FastEthernet1/12
shutdown
interface FastEthernet1/13
shutdown
interface FastEthernet1/14
shutdown
interface FastEthernet1/15
shutdown
interface Vlan1
no ip address
shutdown
ip classless
line con 0
line vty 0 4
logging synchronous
login local
line vty 5 15
logging synchronous
login local
end
Geert Reijnders Wed, 05/18/2011 - 00:05
can you ping from your servers the gateway of their vlans?
did you create Layer 2 vlans on your coreswitch?
vinsanity02 Wed, 05/18/2011 - 00:11
Yes, I can..
I think, I did..
Core_Switch#show vlan
VLAN Name                             Status    Ports
1    default                          active    Fa0/5, Fa0/6, Fa0/7, Fa0/8
                                                Fa0/9, Fa0/10, Fa0/11, Fa0/12
                                                Fa0/13, Fa0/14, Fa0/15, Fa0/16
                                                Fa0/17, Fa0/18, Fa0/19, Fa0/20
                                                Fa0/21, Fa0/22, Fa0/23, Fa0/24
                                                Gig0/1, Gig0/2
2    USERS                            active
3    SERVERS                          active
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
VLAN Type  SAID       MTU   Parent RingNo BridgeNo Stp  BrdgMode Trans1 Trans2
1    enet  100001     1500  -      -      -        -    -        0      0
2    enet  100002     1500  -      -      -        -    -        0      0
3    enet  100003     1500  -      -      -        -    -        0      0
1002 fddi  101002     1500  -      -      -        -    -        0      0
1003 tr    101003     1500  -      -      -        -    -        0      0
1004 fdnet 101004     1500  -      -      -        ieee -        0      0
1005 trnet 101005     1500  -      -      -        ibm  -        0      0
Remote SPAN VLANs
Primary Secondary Type              Ports
vinsanity02 Wed, 05/18/2011 - 03:00
maybe it doesn't work in packet tracer.. it may work in lab enviroments with real equipments, i think...
Florin Barhala Wed, 05/18/2011 - 03:10
  • Bronze, 100 points or more
Use traceroute and ping while specifying the source IP address.
vinsanity02 Wed, 05/18/2011 - 23:21
i've fixed it.. i added a static routes for vlan 2 & 3 in the core switch..
Core_Switch(config)#ip routing
Core_Switch(config)#ip route 10.65.1.0 255.255.255.0 10.65.0.1
Core_Switch(config)#ip route 10.65.2.0 255.255.255.0 10.65.0.1
