05-19-2011 08:15 AM - last edited on 03-25-2019 03:32 PM by ciscomoderator
I am facing a problem in my ME3400-24FS-A Switch, the switch is in production and showing high CPU utilization and for that clients are facing slow performance who are connected to the switch. All ports of the switch are plugged with 100BaseLX-FE sfp.
Need your advice, how i can keep the switch in normal cpu utilization.
Here is process details of the switch:
CPU utilization for five seconds: 53%/0%; one minute: 57%; five minutes: 58%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
43 944513677 15399460 61334 37.45% 41.58% 41.69% 0 SFF8472
123 149825305 38051892 3937 6.45% 7.39% 7.18% 0 Hulc LED Process
59 7700014 66240354 116 1.25% 0.43% 0.43% 0 Fifo Error Detec
250 115 98 1173 0.78% 0.12% 0.02% 1 Virtual Exec
Output is omitted
In the attached file you can see the show version of the switch, or if you need more information then let me know.
Mamun
05-19-2011 08:20 AM
The problem is related to one of the SFPs in the switch. I would try removing one at a time to see if the problem goes away.
05-20-2011 09:49 PM
Thanks, I will check and let you know..
Mamun
05-31-2013 01:08 AM
This is a know internal bug which is not fixed yet. Upgrade to latest and do "no monitoring" to stop SFF8472 process to monitor the SFP module.
Anshul
06-04-2013 06:09 PM
HI,
The bug I was talking about is for ME3600, was not sure if that goes on ME3400 also. Howeever I have seen many case with same issue on ME3400, all of them resolved after replacing the SFP.
Anshul
06-04-2013 08:52 PM
Hi Abdullah
As per the logs you have shared we can see that the high CPU is due to SFF8472 process and SFF8472 preocess handles the SFP transceivers.
So most probably high CPU is caused due to some faulty SFP so check and replace the SFP and check if issue get resolved. Even we have some known bugs that cause such issues. So in case after replacing the SFP you see that issue still persists I will recommend you to upgrade to the latest code.
Thanks & Regards
Sandeep
01-07-2015 05:37 PM
How to check which SFP has a problem?
Thank you very much.
