Dial Peers understanding
May 22nd, 2011
dial-peer voice 1 pots
incoming called-number .
direct-inward-dial
This is one way (incoming or outgoing) dial peer or two way (incoming and outgoing) dial peer.
Overall Rating: 4 (3 ratings)
paolo bevilacqua Sun, 05/22/2011 - 04:08
  • Hall of Fame,
    Founding Member
Incoming only (has incoming called-number).
For outgoing, you need destination-pattern, and port or trunk or session-target.
Just think logically and it will become clear to you.
omerpal1190 Sun, 05/22/2011 - 05:42
thnx for ur quick response. This is incoming from pstn to our gateway. Now it should forward calls to CUCM, at this stage it needs Voip dial peer (will it be incoming or outgoing dial-peer).
Lets say call forwarded to cucm....then it has to come back. Will it use same VOIP dial peer??? Thanks
paolo bevilacqua Sun, 05/22/2011 - 06:04
  • Hall of Fame,
    Founding Member
Sorry to see that my post here has not been rated fairly, and I will refrain to intervene further.
nitsinha Mon, 05/23/2011 - 01:22
  • Silver, 250 points or more
When the call comes in to your gateway, you will need an incoming and an outgoing dial-peer for the call to get completed. The incoming pots dial-peer is already configured. The outgoing dialpeer will point to your CUCM server as shown below
dial-peer voice 2 voip
  destination-pattern
  session target ipv4:
Now when an outbound call is made from the CUCM, you will again need two dialpeers on your H323 gateway. You can use dialpeer 2 as the incoming dialpeer just by adding 'incoming called number .' command. The outbound dialpeer will be a pots dialpeer with destination pattern, port and forward digits command.
Check the following doc to help you out with dialpeer configs
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a008010fed1.shtml
Hope that helps
Nitesh
PS:Please rate helpful posts
omerpal1190 Mon, 05/23/2011 - 01:42
thnx for your reply.
First:
I saw my configuration and i coudnt see the 'incoming called number .' command on my voip dial peer.
Second:
I have h323 cisco gateway and cucm 7. Do i need to make route pattern on cucm 7.1 to route the call as i m having dial peers on h323 gateway?
nitsinha Mon, 05/23/2011 - 02:00
First:
If you do not see the incoming called number . command under any voip dialpeer the you would have to add it or else it will use the default dialpeer as the inbound dialpeers which has preconfigured parameters and cant be modified.
Second:
Yes you will need route pattern on the CUCM to route calls to the H323 gateway. Then on the gateway you would need dialpeers to route the calls to the PSTN since the call control protocol is peer to peer.
Nitesh
