Jaime Valencia Fri, 05/27/2011 - 07:04
  • Cisco Employee,
  • Hall of Fame,
    2011
Ordering Information
You can obtain  Cisco Jabber for Android through normal ordering processes. You can  download Cisco Jabber for Android for free from the Android Market using  devices running Android Version 2.2 and later. To use the software, a  device license (ADR-USR-LIC) is required.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
