[ACS 5.2] switch Command authorization failed
May 30th, 2011
Hi all,
i've problem, switch "authorization failed" on every command that i type.
Switch#sho run
Command authorization failed.
Switch#conf t
i only use basic configuration. *attached below
Switch config :
aaa new-model
aaa authentication login default group tacacs+ none
aaa authentication enable default group tacacs+ none
aaa authorization config-commands
aaa authorization exec default group tacacs+ if-authenticated
aaa authorization commands 1 default group tacacs+ if-authenticated none
aaa authorization commands 15 default group tacacs+ if-authenticated none
aaa session-id common
ip tacacs source-interface Vlan888
tacacs-server host 10.255.253.25
tacacs-server key cisco
ACS config :
# Network resources - network devices and AAA clients
     * name switch , ip 10.255.253.65 , authen option : tacacs+ , shared secret cisco
# User and identity store - internal identity store - users
     * name tester , pass : passw0rd , enable pass : enable
# Policy elements - authorization and permissions - device administration - shell profile
     * name : testProfile , command task - maximum privilege 15 , (default privilege not in use / default)
# Policy elements - authorization and permissions - device administration - command sets
     * name : PermitAll , mark "Permit any command that is not in the table below"
# Access policies - access service - default device admin - authorization
     * rule-8 , identity group in all groups , shell profile : testProfile
has anyone seen this type of issue and perhaps offer some advice on what I am missing.
Many Thanks in advanced.
zujalal Mon, 05/30/2011 - 12:58
  • Cisco Employee,
Hi.
What do you have under line vty 0 4
regards
ki.song Tue, 09/06/2011 - 05:23
mine says
line vty 0 4
access-class ACL....
exec-timeout 9 0
password 7 ....
transport input ssh
ki.song Tue, 09/06/2011 - 05:19
Did you find an answer for this? I have the same problem.
Nicolas Darchis Tue, 09/06/2011 - 11:47
  • Cisco Employee,
The whole question is :
if the switch says command authorization failed, what does ACS say in the authorization logs ???
ki.song Tue, 09/06/2011 - 11:52
Classification: UNCLASSIFIED
Caveats: FOUO
It works now. The authorization logs does not say anything.
randy.klassen Thu, 09/08/2011 - 11:32
I had the same problem and marked the default priv lvl 15 and the max 15 (this was only for the admin account) the guest account i set up uses default 1 max (none) and it works perfectly.
you can #sho priv inside your cisco devie and it should say 15, if it doesnt then you know its a problem with your shell profile priv lvl.
Related Content
