SSL VPN
May 26th, 2011
We need to configure SSL VPN on a 2821 router just to provide VPN connection (with ability to create some “enhanced” access restriction policies) to some of our mobile employees. This router is currently our VOICE gateway as well. The IOS version is: 12.3(14)T6.
I was wondering is SSL VPN supported on this IOS version. If so, how can I configure it (via Command Line or SDM)? I’d personally prefer to do it through the command line interface as it gives more flexibility.
Any help would be much appreciated.
Ehsan
visaxena Thu, 06/02/2011 - 22:07
12.3(14)T6 is a verrrrrrrry old version
the support for SSL VPN client (usable SSL VPN - from alot of angles) came in from 12.4(20)T onwards.
Try the new SDM it should give you all the feautres or try Cisco Configuration Pro.
-Vikas
Related Content
