SPA525G trouble
Answered Question
Jun 1st, 2011
Hi There,
I have a problem with my SPA 525G phone. I tried to updgrade the firmware and the phone stack after restarting. The bootting process stops at the CISCO logo and there is no way to continue. I have discussed the problem with the support team but it seams there is no cure from CISCO side.
Is there some one knows how and where the firmware can be reloaded with the correct version of firmware? We are located in Mississauga, ON.
Please contact me at [email protected]
Pauls Stanchev
Correct Answer by nseto about 5 years 9 months ago
Please contact the support center.  Phone number at the following link.
Sounds like this could be an RMA issue.
http://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
Overall Rating: 5 (1 ratings)
nseto Thu, 06/02/2011 - 13:28
  • Silver, 250 points or more
You can try the following steps to see if you can recover the phone.
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
1. Cold reboot the phone
2. When the animation appears
3. Press speaker key 3 times
4. User will be show a list of menu, from there
   a. User could reset the configuration
   b. Upgrade the firmware
pstanchev Fri, 06/03/2011 - 07:38
Thank you for the response.
I have tried the steps but didn't get anywhere with pressing the button. I have the CISCO logo on the screen but it does not accept any key pressings.
Do you have any other options?
pstanchev Fri, 06/03/2011 - 08:40
The problem is that this thing happened 2 weeks after the warranty end. The custommer suport suggests to buy new phone. The owner whants to replace the whole phone system.
