Will a reset on a 1242 to factory defaults...
Answered Question
Jun 2nd, 2011
I have a 1242 that was configured for LWAPP and I reset to factory defaults. I'm curious if it returned to autonomous mode?
Thanks in advance
Correct Answer by Stephen Rodriguez about 5 years 9 months ago
It should not have.  When you migrate from IOS to CUWN, the process removes all of the old IOS that was there, erases the flash basically.
So, a factory reset should only clear out any configuration, but would leave you running a CUWN image on the AP.
Cheers,
Steve
If  this helps you and/or answers  your question please mark the question as "answered" and/or rate it, so  other users can easily find it.
Overall Rating: 5 (1 ratings)
Correct Answer
Stephen Rodriguez Thu, 06/02/2011 - 12:54
  • Purple, 4500 points or more
Cheers,
Steve
