traceroute througth asa is not working when ecmp error inspection is enabled
Answered Question
Jun 7th, 2011
  • Silver, 250 points or more
Hello, dear All!
I have problem with icmp traceroute configuration. When I enabling icmp error inspection in global policy, my traceroute results through ASA 8.2.4 looks like this:
        My traceroute  [v0.75]
        Tue Jun  7 13:33:01 2011
Keys:  Help   Display mode   Restart statistics   Order of fields   quit
        Packets               Pings
Host        Loss%   Snt   Last   Avg  Best  Wrst StDev
1. 192.168.1.247        0.0%     2    0.3   0.4   0.3   0.4   0.0
2. ???
3. ???
4. ???
5. ???
6. ???
7. ???
8. destination.lan        0.0%     1   29.2  29.2  29.2  29.2   0.0
When ICMP error inspection is disabled, my results looks better, but still not all hops in the path:
        Tue Jun  7 13:32:44 2011
        Packets               Pings
1. 192.168.1.247        0.0%    36    0.5   0.4   0.3   0.5   0.1
2. core-asa.lan        0.0%    35    0.3   0.5   0.3   1.8   0.4
3. ???
4. ???
5. 123.123.123.1        0.0%    35    2.5   5.9   1.9  41.6   9.2
6. 123.123.123.57        0.0%    35   28.7  30.3  27.2 107.7  13.5
7. 123.123.123.58        0.0%    35   28.4  28.6  27.6  32.9   1.0
8. destination.lan        0.0%    35   29.1  30.2  28.9  33.4   0.9
icmp inspection and ttl decrement on ASA is enabled. Also I configured ACL on outside interface to permit ICMP completely.
What's the problem? Thanks in advance.
Correct Answer by Kureli Sankar about 5 years 9 months ago
Well, got to go with asp drop captures and  icmp packets ingress and egress.
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCti20726
-KS
I would get to the two devices that do not show up and see if they are not blocking/not sending time exceeded message.
-KS
Overall Rating: 5 (2 ratings)
Eugene Khabarov Tue, 06/07/2011 - 03:09
Hi! Thanks. But I already performed this at first step.
brquinn Tue, 06/07/2011 - 07:05
  • Bronze, 100 points or more
Can you please paste your MPF configuration? This should include all class-map, policy-map and service-policy commands you have configured. Note: you can use "show service-policy" to see if your configured policies are being matched.
Brendan
Eugene Khabarov Tue, 06/07/2011 - 07:18
policy-map global_policy
class inspection_default
  inspect dns preset_dns_map
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect sqlnet
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect pptp
  inspect mgcp
  inspect snmp
  inspect ip-options
  inspect ftp
  inspect icmp
class NETFLOW_ALL_CLASS
  flow-export event-type all destination 192.168.1.202
class csc_class
  csc fail-open
class class-default
  set connection decrement-ttl
Global policy:
  Service-policy: global_policy
    Class-map: inspection_default
      Inspect: dns preset_dns_map, packet 488771211, drop 610643, reset-drop 0
      Inspect: h323 h225 _default_h323_map, packet 44707, drop 0, reset-drop 916
               tcp-proxy: bytes in buffer 0, bytes dropped 66210
      Inspect: h323 ras _default_h323_map, packet 127581, drop 1466, reset-drop 0
      Inspect: rsh, packet 22369, drop 0, reset-drop 0
      Inspect: rtsp, packet 3404318, drop 0, reset-drop 0
               tcp-proxy: bytes in buffer 0, bytes dropped 259440
      Inspect: sqlnet, packet 226321, drop 0, reset-drop 0
      Inspect: sunrpc, packet 7878, drop 412, reset-drop 338
               tcp-proxy: bytes in buffer 0, bytes dropped 28
      Inspect: xdmcp, packet 350, drop 36, reset-drop 0
      Inspect: sip , packet 2308307, drop 0, reset-drop 0
               tcp-proxy: bytes in buffer 0, bytes dropped 0
      Inspect: netbios, packet 151697978, drop 0, reset-drop 0
      Inspect: tftp, packet 401488316, drop 664, reset-drop 0
      Inspect: pptp, packet 40620, drop 0, reset-drop 0
      Inspect: mgcp, packet 1449, drop 0, reset-drop 0
      Inspect: snmp, packet 561762523, drop 0, reset-drop 0
      Inspect: ip-options _default_ip_options_map, packet 0, drop 0, reset-drop 0
      Inspect: ftp, packet 3494988544, drop 4146, reset-drop 1541
      Inspect: icmp, packet 2173761, drop 2927, reset-drop 0
    Class-map: NETFLOW_ALL_CLASS
    Class-map: csc_class
      CSC: packet sent 323573774
      CSC: packet received 345081778
    Class-map: class-default
      Default Queueing      Set connection policy:         drop 0
      Set connection decrement-ttl
brquinn Tue, 06/07/2011 - 07:33
I suspect the class-map is not getting hit at all so the TTL is never being decremented. The reason is due to the ASA
only matching the first class it finds for each feature type. It is not matching the class you intend, instead I think it is matching your NETFLOW_ALL_CLASS class or possibly your csc_class. How are these classes configured?
Feature Matching Within a Service Policy
Brendan
Eugene Khabarov Tue, 06/07/2011 - 07:47
MSK-iASA5520CSC-t10-u1# sh running-config class-map NETFLOW_ALL_CLASS
match access-list NETFLOW_ALL_EXPORT
MSK-iASA5520CSC-t10-u1# sh running-config class-map csc_class
class-map csc_class
match access-list csc_inout
MSK-iASA5520CSC-t10-u1# sh access-list NETFLOW_ALL_EXPORT
access-list NETFLOW_ALL_EXPORT; 1 elements; name hash: 0xcb1355f3
access-list NETFLOW_ALL_EXPORT line 1 extended permit ip any any (hitcnt=384518) 0x7fd5e24c
MSK-iASA5520CSC-t10-u1# sh access-list csc_inout
access-list csc_inout; 8 elements; name hash: 0x838c79c5
access-list csc_inout line 1 extended permit tcp host 192.168.1.2 any eq www (hitcnt=1641) 0x9c990a55
access-list csc_inout line 2 extended permit tcp host 192.168.1.11 any eq www (hitcnt=742) 0x31cec72a
access-list csc_inout line 3 extended permit tcp host 192.168.1.2 any eq ftp (hitcnt=0) 0x716d034b
access-list csc_inout line 4 extended permit tcp host 192.168.1.11 any eq ftp (hitcnt=0) 0xb0426519
access-list csc_inout line 5 extended permit tcp host 10.143.4.5 any eq www (hitcnt=6144) 0xbd0bdd39
access-list csc_inout line 6 extended permit tcp host 10.143.4.5 any eq ftp (hitcnt=0) 0x60b4726f
access-list csc_inout line 7 extended permit tcp host 10.143.4.5 any eq smtp (hitcnt=0) 0x92815168
access-list csc_inout line 8 extended permit tcp host 10.143.4.5 any eq pop3 (hitcnt=0) 0x0986ac75
I modified my policy-map configuration, so now it looks like this:
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect sqlnet
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect pptp
  inspect mgcp
  inspect snmp
  inspect ip-options
  inspect ftp
  inspect icmp
class csc_class
  csc fail-open
class class-default
but still two hops missing.
brquinn Tue, 06/07/2011 - 07:55
You're missing 'inspect icmp error'. Also, not all traceroutes use ICMP traffic. Are you sure your traceroute program isn't using TCP or UDP and the traffic is being blocked by an ACL? Note: The replies when the ttl expires are always ICMP.
Brendan
Eugene Khabarov Tue, 06/07/2011 - 07:59
This is the core problem. When I enabling icmp error inspection - I can't see any hops except first and last as I already said in first message.
This traceroute program using only icmp. Standard unix traceroute with flag -I say the same - two hops missing without icmp error inspection and only first and last shown if there is icmp error inspection enabled.
Kureli Sankar Tue, 06/07/2011 - 20:16
  • Cisco Employee,
For trace route to work, in addition to icmp and icmp error inspection enabled you also need to allow
icmp time-exceeded and icmp unreachable via ACL from the outside to the inside (low to high) allowed.
Refer this link:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a0080094e8a.shtml
If you need the ASA to show up as one of the hops then, you need to do this in addition to the above:(you already have this configured)
http://www.cisco.com/en/US/docs/security/asa/asa80/command/reference/s1.html#wp1395966
-KS
Eugene Khabarov Wed, 06/08/2011 - 02:28
Thank you. But as i already mentioned, all icmp traffic is allowed in outside acl.
ASA OS was upgrade to 8.2.5 also.
Correct Answer
Kureli Sankar Wed, 06/08/2011 - 04:24
  • Cisco Employee,
-KS
Eugene Khabarov Wed, 06/08/2011 - 05:46
You right. The problem was with intermediate devices. But I still can't make it works when ICMP error inspection is enabled.
