PPTP tunnel between Cisco Routers
Jun 7th, 2011
I want to establish the PPTP tunnel between Cisco routers. 1st router is configured to accept the dialin. What configuration required to establish the PPTP tunnel between 2nd & 1st router.
Thanks in advance.
Nilesh
Jennifer Halim Wed, 06/08/2011 - 00:29
  • Cisco Employee,
PPTP is a remote access VPN protocol, not site-to-site VPN between 2 routers.
If you would need to create site-to-site tunnel between 2 Cisco routers, then you would need to create IPSec tunnel.
