CSM 4.0.1 adds multiple DM_INLINE_NETWORK objects
Jun 9th, 2011
Hi all,
when we add a ASA 8.3 to CSM 4.0.1, the ruleset gets totally messed up because CSM seems to get confused about certain object groups:
CSM uses DM_INLINE_NETWORK_xx instead of some real group names, even adds multiple DM_INLINE_NETWORK_xx entries for the same object group depending on how often it is used in ACLs.
Is CSM not able to deal with all kinds of object group names or what can be the reason for this behaviour?
Thanks and cheers,
Uli
saurbechtle Thu, 06/09/2011 - 08:47
Sorry, I was wrong, it is different: we have created ACLs containing several single objects as source and/or destination...
Is it possible to prevent this or is CSM not able to deal with this?
Tried to adjust options under Tools>CSM Administration>Deployment: unchecked 'Create Object Groups...'
Thanks and cheers,
Uli
