IPV6 DHCP : Active Clients always zero 0
Answered Question
Jun 14th, 2011
Hello All,
I have configure IPV6 DHCP by using below mentioned configuration, all my LAN PCs are getting IPV6 correctly and internet is also running well.
But if run this command on Router, so it shows Active Clients are always zero 0.
R1# sh ipv6 dhcp pool
DHCPv6 pool: DHCP_POOL
  DNS server: 2001:470:ab::cd
  Domain name: abc.com
  Active clients: 0
R1# sh ipv6 dhcp binding --> also show empty result.
Can anyone please tell me the reason .
MY CONFIGURATION:
ipv6 unicast-routing
ipv6 dhcp pool DHCP_POOL
dns-server 2001:470:ab::cd
domain-name abc.com
interface FastEthernet0/0
no ip address
speed 100
full-duplex
ipv6 address 2400:FC00:ab::/64 eui-64
ipv6 nd prefix 2400:FC00:ab::/64
ipv6 nd other-config-flag
ipv6 dhcp server DHCP_POOL
ipv6 route ::/0 2400:FC00:ab::1
int fa0/0 is directly connected to my LAN Switch.
Correct Answer by Phillip Remaker about 5 years 10 months ago
"Managed-config-flag" means that the router manages and controls the IPv6 addresses.  Since it manages and controls, it has "state" because it tracks who has what address.  Hence, it is "stateful DHCPv6."
"Other-config-flag" controls whether or not DHCPv6 hands out informational details, like DNS server information.  Since it merely distributes information but does not track or retain state from the requestors, this is "stateless DHCPv6."
You need to set BOTH, not replace one with the other. Both the Managed and Other bit need to be set.
See also http://blogs.technet.com/b/teamdhcp/archive/2007/01/23/dhcpv6-behaviour-...
You are using DHCP statelessly, meaning it is only providing configuration information like the DNS server but it is not managing IPv6 addresses.  If you want the router to hand out and manage addresses instead of SLAAC, use
ipv6 nd managed-config-flag
so that the M bit is set in the router advertisements.
For more information, see:
http://blogs.cisco.com/borderless/ipv6-automatic-addressing/
Overall Rating: 0 (3 ratings)
Correct Answer
Phillip Remaker Tue, 06/14/2011 - 10:17
  • Cisco Employee,
waqasahmed0 Tue, 06/14/2011 - 21:56
Ok  i changed my config from
ipv6 nd other-config-flag   -------->  ipv6 nd managed-config-flag
But still , output of
Show ipv6 dhcp pool shows active clients zero 0
and Show ipv6 dhcp binding is also empty.
My config on interface, now look like this:
no ip address
speed 100
full-duplex
end
what i am doing wrong ??
update: One thing more , when i run ipv6 nd managed-config-flag on int fa0/0, DNS address removed from my clients !!!
Yash Malvania Fri, 09/13/2013 - 13:36
Hey i had a similar problem and your solution fixed it. Now where i am stuck is that i want to keep a track of the client mac address and the dhcp assigned address. what command can i use to see that?
waqasahmed0 Wed, 06/15/2011 - 00:41
Ok , the problem solved by changing the configuration in this way. Now it is showing Active clients and Bindings.
I will try your method too, to just add ipv6 nd managed-config-flag in my previous config.
But i am still confused which configuratrion is better and which technique to use ??
My previous config was stateless , is my new config is stateful ??
My NEW Configuration:
ipv6 cef
address prefix 2400:FC00:ab::/64 lifetime infinite infinite
link-address 2400:FC00:ab::2/64
domain-name abc.com
interface FastEthernet1/0
no ip address
duplex full
speed 100
ipv6 address 2400:FC00:ab::2/64
ipv6 enable
Correct Answer
Phillip Remaker Wed, 06/15/2011 - 09:38
  • Cisco Employee,
