06-15-2011 02:58 AM - edited 03-10-2019 05:22 AM
looking at the device's CPU processes I have noticed that more tha 95% of utilization is "idle".
On the Cisco IPS Manager Express I can see under Sensor Information: Analisys Engine Status: Reconfiguring the Engine and user activity: LoadConfigtrojan.udp
Can anyone help?
Thanks!
Solved! Go to Solution.
06-15-2011 08:21 AM
Hello Carlo,
What version of IPS code are you running? This issue was seen in early 2010 when running early versions of 6.2 and 7.0. It is usually accompanied by a core.txt, which can be seen in the output of a "show tech."
If you would like to further investigate the issue, please open a TAC case and attach a "show tech." Alternatively, an upgrade to the latest code in your train should resolve the issue.
Thank you,
Blayne Dreier
Cisco TAC Escalation Team
**Please check out our Podcasts**
TAC Security Show: http://www.cisco.com/go/tacsecuritypodcast
TAC IPS Media Series: https://supportforums.cisco.com/docs/DOC-12758
06-15-2011 08:21 AM
Hello Carlo,
Thank you,
Blayne Dreier
