High CPU consuming
Jun 16th, 2011
Dear All
I have 7200 router, it was runing 124-4.XD3 IOS, the CPU was working normal avarage around 15%, its use for L2TP users, it was have avarage 2000 concurrent L2TP connection, there was no CPU consuming.
Then for business plan we change the IOS to 12.2(33)SR and configured Broadband aggregation, after that the CPU become higher day after day even the PPPoE and L2TP session not more than 900 concurrent. the CPU reach 60%, even in non-peak hours it reach 50%
sh ver
Cisco IOS Software, 7200 Software (C7200P-ADVIPSERVICESK9-M), Version 12.2(33)SR
C6, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Mon 08-Mar-10 08:03 by prod_rel_team
ROM: System Bootstrap, Version 12.4(12.2r)T, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, 7200 Software (C7200P-KBOOT-M), Version 12.2(33)SRC
System returned to ROM by reload at 14:58:14 UTC Thu Jun 2 2011
System image file is "disk2:c7200p-advipservicesk9-mz.122-33.SRC6.bin"
Last reload reason: Reload command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco 7206VXR (NPE-G2) processor (revision A) with 917504K/65536K bytes of memor
y.
Processor board ID 36743260
MPC7448 CPU at 1666Mhz, Implementation 0, Rev 2.2
6 slot VXR midplane, Version 2.11
Last reset from power-on
PCI bus mb1 (Slots 1, 3 and 5) has a capacity of 600 bandwidth points.
Current configuration on bus mb1 has a total of 0 bandwidth points.
This configuration is within the PCI bus capacity and is supported.
PCI bus mb2 (Slots 2, 4 and 6) has a capacity of 600 bandwidth points.
Current configuration on bus mb2 has a total of 0 bandwidth points.
Please refer to the following document "Cisco 7200 Series Port Adaptor
Hardware Configuration Guidelines" on Cisco.com <http://www.cisco.com>
for c7200 bandwidth points oversubscription and usage guidelines.
1 FastEthernet interface
3 Gigabit Ethernet interfaces
2045K bytes of NVRAM.
250880K bytes of ATA PCMCIA card at slot 2 (Sector size 512 bytes).
65536K bytes of Flash internal SIMM (Sector size 512K).
sh processes cpu
CPU utilization for five seconds: 73%/17%; one minute: 67%; five minutes: 66%
PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
   1         620     11401         54  0.00%  0.00%  0.00%   0 Chunk Manager
   2        1400    238221          5  0.00%  0.00%  0.00%   0 Load Meter
   3           0         1          0  0.00%  0.00%  0.00%   0 L2X Socket proce
   4     4594808    312806      14689  7.27%  0.99%  0.69%   0 Check heaps
   5       36380    195739        185  0.07%  0.00%  0.00%   0 Pool Manager
   6           0         2          0  0.00%  0.00%  0.00%   0 Timers
   7     1789408   3141124        569  0.15%  0.16%  0.16%   0 ARP Input
   8         408   1241861          0  0.00%  0.00%  0.00%   0 ARP Background
   9           0         2          0  0.00%  0.00%  0.00%   0 ATM Idle Timer
  10           0         1          0  0.00%  0.00%  0.00%   0 ATM ASYNC PROC
  11           0        85          0  0.00%  0.00%  0.00%   0 AAA_SERVER_DEADT
  12           0         1          0  0.00%  0.00%  0.00%   0 Policy Manager
  13           0         4          0  0.00%  0.00%  0.00%   0 Entity MIB API
  14       87356   1933514         45  0.00%  0.00%  0.00%   0 EEM ED Syslog
  15           8     19853          0  0.00%  0.00%  0.00%   0 IPC Dynamic Cach
  16           0         1          0  0.00%  0.00%  0.00%   0 IPC Zone Manager
  17        1276    237895          5  0.00%  0.00%  0.00%   0 IPC Service NonC
  18         896   1189354          0  0.00%  0.00%  0.00%   0 IPC Periodic Tim
  19           0         1          0  0.00%  0.00%  0.00%   0 IPC Managed Time
  20         644   1189353          0  0.00%  0.00%  0.00%   0 IPC Deferred Por
  21           0         1          0  0.00%  0.00%  0.00%   0 IPC Seat Manager
  22           0         1          0  0.00%  0.00%  0.00%   0 IPC Seat Control
  23          88    238222          0  0.00%  0.00%  0.00%   0 IPC Loadometer
  24           0         2          0  0.00%  0.00%  0.00%   0 Serial Backgroun
  25           0         1          0  0.00%  0.00%  0.00%   0 RO Notify Timers
  26           0         1          0  0.00%  0.00%  0.00%   0 RMI RM Notify Wa
  27         472    151083          3  0.00%  0.00%  0.00%   0 DDR Timers
  28           0         2          0  0.00%  0.00%  0.00%   0 ATM AutoVC Perio
  29           0         2          0  0.00%  0.00%  0.00%   0 ATM VC Auto Crea
  30          16    119115          0  0.00%  0.00%  0.00%   0 Compute SRP rate
  31     2400080  21414450        112  0.00%  0.01%  0.08%   0 EnvMon
  32           0         1          0  0.00%  0.00%  0.00%   0 OIR Handler
  33           0         1          0  0.00%  0.00%  0.00%   0 Crash writer
  34           0         1          0  0.00%  0.00%  0.00%   0 Exception contro
  35        2200    237093          9  0.00%  0.00%  0.00%   0 ALARM_TRIGGER_SC
  36           0         1          0  0.00%  0.00%  0.00%   0 CEF MIB API
  37         948   1189356          0  0.00%  0.00%  0.00%   0 GraphIt
  38           0         1          0  0.00%  0.00%  0.00%   0 SERIAL A'detect
  39           0         2          0  0.00%  0.00%  0.00%   0 Dialer event
  40           0         2          0  0.00%  0.00%  0.00%   0 SMART
  41           0         1          0  0.00%  0.00%  0.00%   0 RFS server proce
  42           0         1          0  0.00%  0.00%  0.00%   0 Critical Bkgnd
  43      112568    578621        194  0.00%  0.04%  0.05%   0 Net Background
  44           0         2          0  0.00%  0.00%  0.00%   0 IDB Work
  45       23576    664891         35  0.00%  0.00%  0.00%   0 Logger
  46        1564   1189352          1  0.00%  0.00%  0.00%   0 TTY Background
  47       38788   1189374         32  0.00%  0.03%  0.02%   0 Per-Second Jobs
  48       80568     23708       3398  0.00%  0.00%  0.00%   0 Per-minute Jobs
  49         776         5     155200  0.00%  0.00%  0.00%   0 PrstVbl
  50        5160    154631         33  0.00%  0.00%  0.00%   0 IF-MGR control p
  51           0        15          0  0.00%  0.00%  0.00%   0 IF-MGR event pro
  52           0         1          0  0.00%  0.00%  0.00%   0 Inode Table Dest
  53           4     13677          0  0.00%  0.00%  0.00%   0 Transport Port A
  54           0         2          0  0.00%  0.00%  0.00%   0 INTR MGR PROCESS
  55     1553620    253665       6124  0.00%  0.13%  0.12%   0 HC Counter Timer
  56           0         2          0  0.00%  0.00%  0.00%   0 CES Timer
  57           0         1          0  0.00%  0.00%  0.00%   0 POS APS Event Pr
  58           0         1          0  0.00%  0.00%  0.00%   0 SONET alarm time
  59           0         2          0  0.00%  0.00%  0.00%   0 Hawkeye Backgrou
  60           0         1          0  0.00%  0.00%  0.00%   0 CSP Timer
  61           0         2          0  0.00%  0.00%  0.00%   0 FPD Management P
  62           0         1          0  0.00%  0.00%  0.00%   0 FPD Action Proce
  63        1108     74393         14  0.00%  0.00%  0.00%   0 Collection proce
  64           0         1          0  0.00%  0.00%  0.00%   0 CES Line Conditi
  65           0         2          0  0.00%  0.00%  0.00%   0 Flash MIB Update
  66           4         6        666  0.00%  0.00%  0.00%   0 Flash Card Oir
  67           0         1          0  0.00%  0.00%  0.00%   0 Async write proc
  68           0         1          0  0.00%  0.00%  0.00%   0 Async write proc
  69           0         1          0  0.00%  0.00%  0.00%   0 Async write proc
  70           0         1          0  0.00%  0.00%  0.00%   0 Async write proc
  71           8     19853          0  0.00%  0.00%  0.00%   0 DFS flush period
  72     1190120  12956856         91  0.23%  0.23%  0.22%   0 AAA Server
  73       37948    166779        227  0.00%  0.00%  0.00%   0 AAA ACCT Proc
  74        3796  36930272          0  0.00%  0.00%  0.00%   0 ACCT Periodic Pr
  75           0         1          0  0.00%  0.00%  0.00%   0 AAA System Acct
  76           0         1          0  0.00%  0.00%  0.00%   0 tHUB
  77           0         2          0  0.00%  0.00%  0.00%   0 AAA Dictionary R
  78           0         2          0  0.00%  0.00%  0.00%   0 CEF switching ba
  79           0         2          0  0.00%  0.00%  0.00%   0 IPAM/ODAP Events
  80        4792  36930277          0  0.00%  0.01%  0.00%   0 IPAM Manager
  81           0         2          0  0.00%  0.00%  0.00%   0 IPAM Events
  82           0        15          0  0.00%  0.00%  0.00%   0 IP ARP Adjacency
  83     4277228  78191448         54  0.95%  0.95%  0.92%   0 IP Input
  84           0         1          0  0.00%  0.00%  0.00%   0 ICMP event handl
  85           0         5          0  0.00%  0.00%  0.00%   0 TurboACL
  86           0         2          0  0.00%  0.00%  0.00%   0 TurboACL chunk
  87         168      3204         52  0.00%  0.00%  0.00%   0 ADJ resolve proc
  88           0         1          0  0.00%  0.00%  0.00%   0 IPv6 Echo event
  89           0         1          0  0.00%  0.00%  0.00%   0 LSP Tunnel FRR
  90           0         1          0  0.00%  0.00%  0.00%   0 MPLS Auto-Tunnel
  91           0         1          0  0.00%  0.00%  0.00%   0 O-UNI Client Msg
  92           0         1          0  0.00%  0.00%  0.00%   0 AAA EPD HANDLER
  93           0         1          0  0.00%  0.00%  0.00%   0 PM EPD API
  94           0         5          0  0.00%  0.00%  0.00%   0 PPP SIP
  95       14144    101572        139  0.00%  0.00%  0.00%   0 PPP Bind
  96       33920    303835        111  0.00%  0.00%  0.00%   0 PPP IP Route
  98     1568632  37728948         41  0.15%  0.13%  0.11%   0 SSM connection m
  99           0         2          0  0.00%  0.00%  0.00%   0 Spanning Tree
100           0         2          0  0.00%  0.00%  0.00%   0 ATM OAM Input
101           0         2          0  0.00%  0.00%  0.00%   0 ATM OAM TIMER
102          28      1987         14  0.00%  0.00%  0.00%   0 MOP Protocols
103     6304800  22987724        274  1.03%  0.88%  0.81%   0 SSS Manager
104           0         1          0  0.00%  0.00%  0.00%   0 SSS Policy Manag
105       22984    468723         49  0.00%  0.00%  0.00%   0 SSS Feature Mana
106         860   4652544          0  0.00%  0.00%  0.00%   0 SSS Feature Time
107           0         1          0  0.00%  0.00%  0.00%   0 SG DPM
108           0         1          0  0.00%  0.00%  0.00%   0 Timer handler fo
109           0         1          0  0.00%  0.00%  0.00%   0 Prepaid response
110           0         1          0  0.00%  0.00%  0.00%   0 Timed Policy act
111           0         1          0  0.00%  0.00%  0.00%   0 AAA response han
112           0         2          0  0.00%  0.00%  0.00%   0 KRB5 AAA
113           0         1          0  0.00%  0.00%  0.00%   0 delayed evt hand
114           0         1          0  0.00%  0.00%  0.00%   0 AC Switch
115           0         1          0  0.00%  0.00%  0.00%   0 SG CMD HANDLER
116           0         2          0  0.00%  0.00%  0.00%   0 IP PORTBUNDLE
117          52    290816          0  0.00%  0.00%  0.00%   0 IP SIP Process
118        4044  36930299          0  0.00%  0.00%  0.00%   0 RADIUS Proxy
119           0         1          0  0.00%  0.00%  0.00%   0 TC SIP
120          72     23792          3  0.00%  0.00%  0.00%   0 CEF background p
121           0         1          0  0.00%  0.00%  0.00%   0 IP IRDP
122           0         2          0  0.00%  0.00%  0.00%   0 SNMP Timers
123       42784    919143         46  0.00%  0.00%  0.00%   0 IP Background
124      124252    846556        146  0.00%  0.00%  0.00%   0 IP RIB Update
125          32       998         32  0.00%  0.00%  0.00%   2 Virtual Exec
126        4900    178197         27  0.00%  0.00%  0.00%   0 VPDN failure man
127           0         1          0  0.00%  0.00%  0.00%   0 IP Traceroute
128           0         1          0  0.00%  0.00%  0.00%   0 Socket Timers
129        1644     27024         60  0.00%  0.00%  0.00%   0 DHCPD Receive
130          52      2068         25  0.00%  0.00%  0.00%   0 static
131         240     49569          4  0.00%  0.00%  0.00%   0 TCP Timer
132        1696      7889        214  0.00%  0.00%  0.00%   0 TCP Protocols
133           0      3971          0  0.00%  0.00%  0.00%   0 HTTP CORE
134       10896 293774766          0  0.07%  0.07%  0.07%   0 HQF Shaper Backg
135        6972 293774795          0  0.07%  0.06%  0.07%   0 HQF Input Shaper
136           0         2          0  0.00%  0.00%  0.00%   0 LFDp Input Proc
137           0         2          0  0.00%  0.00%  0.00%   0 SCTP Main Proces
138           0         2          0  0.00%  0.00%  0.00%   0 PPP Compress Inp
139           0         2          0  0.00%  0.00%  0.00%   0 PPP Compress Res
140           0         1          0  0.00%  0.00%  0.00%   0 COPS
141           0         2          0  0.00%  0.00%  0.00%   0 Dialer Forwarder
142           0         3          0  0.00%  0.00%  0.00%   0 Flow Exporter Ti
143           0         1          0  0.00%  0.00%  0.00%   0 RARP Input
144           0         2          0  0.00%  0.00%  0.00%   0 PPP NBF
145           0         1          0  0.00%  0.00%  0.00%   0 PAD InCall
146           0         2          0  0.00%  0.00%  0.00%   0 X.25 Background
147           0         1          0  0.00%  0.00%  0.00%   0 X.25 Encaps Mana
148        2452  11862393          0  0.00%  0.00%  0.00%   0 RBSCP Background
149           0         1          0  0.00%  0.00%  0.00%   0 VPDN call manage
150      748224   1825397        409  0.23%  0.16%  0.16%   0 CEF: IPv4 proces
151        3408     77652         43  0.00%  0.00%  0.00%   0 ADJ background
152           0         1          0  0.00%  0.00%  0.00%   0 ac_atm_state_eve
153           0         2          0  0.00%  0.00%  0.00%   0 IP Inband Sessio
154           0         1          0  0.00%  0.00%  0.00%   0 EM Background Pr
155           0         1          0  0.00%  0.00%  0.00%   0 IDMGR CORE
156         240      4710         50  0.00%  0.00%  0.00%   0 LOCAL AAA
157           0         5          0  0.00%  0.00%  0.00%   0 MPLS Auto Mesh P
158         360       219       1643  0.00%  0.20%  0.07%   3 Virtual Exec
159           0         2          0  0.00%  0.00%  0.00%   0 ENABLE AAA
160           0         2          0  0.00%  0.00%  0.00%   0 LINE AAA
161           0         2          0  0.00%  0.00%  0.00%   0 TPLUS
162           0         2          0  0.00%  0.00%  0.00%   0 Crypto Support
163           0        12          0  0.00%  0.00%  0.00%   0 crypto engine pr
164           0         1          0  0.00%  0.00%  0.00%   0 Key Proc
165           0         6          0  0.00%  0.00%  0.00%   0 Crypto ACL
166           0         1          0  0.00%  0.00%  0.00%   0 Crypto INT
167           0         4          0  0.00%  0.00%  0.00%   0 Crypto IKMP
168          16     59560          0  0.00%  0.00%  0.00%   0 IPSEC key engine
169           0         1          0  0.00%  0.00%  0.00%   0 IPSEC manual key
170           0         1          0  0.00%  0.00%  0.00%   0 Crypto PAS Proc
171           0         4          0  0.00%  0.00%  0.00%   0 Crypto CA
172           0         1          0  0.00%  0.00%  0.00%   0 Crypto PKI-CRL
173           0         1          0  0.00%  0.00%  0.00%   0 Crypto SSL
174           0         1          0  0.00%  0.00%  0.00%   0 encrypt proc
175           0         1          0  0.00%  0.00%  0.00%   0 GDOI GM Process
176      362624   4767399         76  0.00%  0.02%  0.00%   0 AAA SEND STOP EV
177           0         2          0  0.00%  0.00%  0.00%   0 EEM ED Resource
178           0         3          0  0.00%  0.00%  0.00%   0 EEM ED Track
179           0         1          0  0.00%  0.00%  0.00%   0 Syslog Traps
180          56    119107          0  0.00%  0.00%  0.00%   0 RMON Recycle Pro
181           0         2          0  0.00%  0.00%  0.00%   0 RMON Deferred Se
182          24       138        173  0.00%  0.01%  0.00%   4 Virtual Exec
183           0         1          0  0.00%  0.00%  0.00%   0 MV64 TDR Process
184           0        37          0  0.00%  0.00%  0.00%   0 EEM Server
185           0         2          0  0.00%  0.00%  0.00%   0 EEM Policy Direc
186           0         3          0  0.00%  0.00%  0.00%   0 EEM ED CLI
187           0         3          0  0.00%  0.00%  0.00%   0 EEM ED Config
188           0         3          0  0.00%  0.00%  0.00%   0 EEM ED Counter
189           0         3          0  0.00%  0.00%  0.00%   0 EEM ED Env
190           0         3          0  0.00%  0.00%  0.00%   0 EEM ED Interface
191           0         3          0  0.00%  0.00%  0.00%   0 EEM ED IOSWD
192           0         3          0  0.00%  0.00%  0.00%   0 EEM ED None
193           0         3          0  0.00%  0.00%  0.00%   0 EEM ED OIR
194           0         2          0  0.00%  0.00%  0.00%   0 tENM
195           0         3          0  0.00%  0.00%  0.00%   0 EEM ED SNMP
196           0         3          0  0.00%  0.00%  0.00%   0 EEM ED Test
197           4     29860          0  0.00%  0.00%  0.00%   0 EEM ED Timer
198          12     56583          0  0.00%  0.00%  0.00%   0 IP SLA MPLSLM Pr
199          20       305         65  0.00%  0.00%  0.00%   0 Syslog
200           0         1          0  0.00%  0.00%  0.00%   0 RMON Packets
201           0         1          0  0.00%  0.00%  0.00%   0 IP SLAs Ethernet
202           0         1          0  0.00%  0.00%  0.00%   0 IP SLA AutoEther
203         264     22608         11  0.00%  0.00%  0.00%   0 Net Input
204     5244200    388598      13495  0.47%  0.44%  0.43%   0 Compute load avg
205           8         5       1600  0.00%  0.00%  0.00%   0 crypto sw pk pro
207     1398812 547611831          2  5.27%  5.27%  5.24%   0 L2X Data Daemon
208      447680    774468        578  0.07%  0.05%  0.04%   0 L2TP mgmt daemon
209      213684    638194        334  0.07%  0.02%  0.00%   0 L2TUN Applicatio
210           0         1          0  0.00%  0.00%  0.00%   0 VPDN Test
211     1440332  27764880         51  0.07%  0.13%  0.11%   0 PPPoE Background
212     2845100  35973988         79  0.31%  0.29%  0.28%   0 PPPoE Discovery
213       91560  46276259          1  0.07%  0.04%  0.05%   0 PPP manager
214     3801560  70682638         53  0.63%  0.61%  0.58%   0 PPP Events
215         116   1190837          0  0.00%  0.00%  0.00%   0 Multilink PPP
216           0         2          0  0.00%  0.00%  0.00%   0 Multilink event
218       75752   1395317         54  0.00%  0.00%  0.00%   0 IP SNMP
219       21072    698269         30  0.00%  0.00%  0.00%   0 PDU DISPATCHER
220       86136    697192        123  0.00%  0.00%  0.00%   0 SNMP ENGINE
221           0         2          0  0.00%  0.00%  0.00%   0 IP SNMPV6
222           0         1          0  0.00%  0.00%  0.00%   0 SNMP ConfCopyPro
223           0         1          0  0.00%  0.00%  0.00%   0 SNMP Traps
224     1520096  73207009         20  0.31%  0.29%  0.26%   0 RADIUS
225           8     19906          0  0.00%  0.00%  0.00%   0 Time Range Proce
226      695960    234558       2967  0.00%  0.11%  0.11%   0 VTEMPLATE Backgr
227           4      9927          0  0.00%  0.00%  0.00%   0 DHCPD Timer
228           4     19853          0  0.00%  0.00%  0.00%   0 DHCPD Database
229        2120    545479          3  0.00%  0.00%  0.00%   0 EIGRP-IPv4: Rout
230      844824  22549554         37  0.15%  0.07%  0.07%   0 EIGRP-IPv4: PDM
231     3497712 279146321         12 39.35% 39.22% 39.04%   0 EIGRP-IPv4: HELL
please note that EIGRP process have high CPU
also note that i have 2 7200 router have the same confiugration but runing 12.4(4)XD10 and same number of session the CPU working normal 6% and EIGRP normail
Thank you
Qaes
Shelley Bhalla Tue, 06/21/2011 - 07:09
  • Cisco Employee,
It is hard to identify root cause by the explanation given. It could be a memory leak, route flapping or process switching issue. I believe you need to open a TAC case to troubleshoot this further.
Shelley.
faraidalu Mon, 08/15/2011 - 00:33
Hi There,
Just want to share a tip on ow to filter your CPU utilisation on your Cisco router. I find alias commands handy and use them all the time. From the config mode, you can type as below.
R(config)#alias exec cpu sho process cpu sorted | exc 0.00%__0.00%__0.00%
This will create an alias called cpu, from priviledge mode, you can then type cpu and it will filter all process' that are not consuming the CPU, this is done with the help of exc [exclude]. This excludes all process' with 0% utilisation.
Below is my example on one of my routers.
Faraimd
