CME forced auth codes in 8.5/8.6
Jun 16th, 2011
I m referring to this document (which doesnt seem to help me much)..so thought of posting at this forum....
Has any body successfully implemented FAC in CME..
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmefac.html
i have setup two LPCor groups one for end users and one for PSTN trunks..to test this functionality i put one ephone under the end users group and another ephone in the PSTN trunk group..and when you call from ephone 1 to 2...it asks for the username and password as programmed but then it hangs up the call...
i can post configs if needed...its pretty similar to whats in the document..
TIA..
3 votes
Overall Rating: 4.8 (6 ratings)
thisisshanky Fri, 06/17/2011 - 06:07
Thanks Paolo...its been a while :)..The issue was with the AAA not being enabled. Once AAA and gateway account was enabled everything started working. I have posted a sample config, in case some one needs it...Also LPCOR groups cannot be applied to dial-peers directly so you have to use trunk groups and point dial peers to trunk groups in order to apply LPCORs. So if you only want to block LD and International calls with a FAC code, you will need trunk groups defined and applied to those dial peers. All the non authenticated dial peer will use the port command.
AAA- Config
aaa new-model
aaa authentication login default local
aaa authentication login h323 local
aaa authorization exec h323 local
aaa authorization network h323 local
aaa session-id common
gw-accounting aaa
Trunk Group configuration
trunk group Telmex-E1
hunt-scheme least-idle
trunk group lpcor outgoing PSTNTrunk
LPCOR groups -> Feature of CME 8.5
voice lpcor enable
voice lpcor custom
group 10 end-users
group 11 PSTNTrunk
voice lpcor policy end-users
service fac
accept end-users fac
accept PSTNTrunk fac
voice lpcor policy PSTNTrunk
service fac
**APPLICATION CONFIGURATION THAT AUTHENTICATES USERS**
application
package auth
  param passwd-prompt flash:en_bacd_welcome.au
  param passwd 5555 <----- this is optional and i cant figure out why this is needed..it works with or with out it
  param term-digit #
  param user-prompt flash:en_bacd_enter_dest.au
  param abort-digit *
  param max-digits 32
*LD PIN Configuration**
username 6801 password 0 26621
**MEXICAN DIALPLAN***
controller E1 0/0/0
framing NO-CRC4
ds0-group 1 timeslots 1-15,17-30 type r2-digital r2-compelled ani
cas-custom 1
  country telmex use-defaults
  category 2
  answer-signal group-b 1
  trunk-group Telmex-E1
dial-peer voice 3 pots
description Emergency services
destination-pattern 906.
port 0/0/0:1
prefix 06
dial-peer voice 4 pots
trunkgroup Telmex-E1
description International calls
destination-pattern 900T
prefix 00
dial-peer voice 5 pots
description Long Distance
destination-pattern 901..........
prefix 01
dial-peer voice 6 pots
description Toll charge to Local cell phone
destination-pattern 9044..........
port 0/0/0:1
prefix 044
dial-peer voice 7 pots
description Toll charge to Long distance cell phone
destination-pattern 9045..........
prefix 045
dial-peer voice 8 pots
description Local calls
destination-pattern 9[1-9].......
port 0/0/0:1
dial-peer voice 9 pots
description Information
destination-pattern 9040
port 0/0/0:1
prefix 040
**EPHONE CONFIGURATION
ephone-template  1
lpcor type local
lpcor incoming end-users
ephone  65
mac-address 6C50.4DDB.353A
ephone-template 1
username "receptionist"
type 7962 addon 1 7915-24
button  1:100
thisisshanky Fri, 06/17/2011 - 07:46
I didnt either...until this client wanted this feature. Its a new feature introduced in CME 8.5/8.6. LPCors are much like regular CORs except they help in the embedded auth application to authorize a user to place a call based on the code entered...
Pavel Rostovcev Tue, 11/11/2014 - 04:48
Hello. I have FAC configuration and it's working fine. But i have a question how can i restrict all another phone calling through International dial-peer.For example- if you don't have lpcor outgoing AllUser you can't use International dial-peer. It's need for security from malicious calling.
voice lpcor enable
voice lpcor custom
group 10 AllUser
 voice lpcor policy AllUser
 service fac
 accept AllUser fac
application
 package auth
  param passwd-prompt flash://enter_pin.au
  param term-digit #
  param passwd 78423
  param user-prompt flash://enter_account.au
  param abort-digit *
  param max-digits 32
dial-peer voice 103 voip
 description -=International=-
 preference 1
 destination-pattern 810T
 session protocol sipv2
 session target ipv4:192.168.33.187
 incoming called-number 810T
 dtmf-relay h245-alphanumeric
 no vad
  ephone  1
 lpcor type local
 lpcor incoming AllUser
 mac-address 0015.6387.9DA8
 but
ephone  2
mac-address 001C.58A2.3B64
button  1:2ton  1:1
Venkitesh H Iyer Wed, 11/12/2014 - 01:06
Dear Askil,
Here in our organization, we use Translation Pattern for International Calling. Every department (Finance, Accounts, HR), etc. have a code that they need to dial everytime they need to do an International Call. This way on our Call Accounting System, we filter and get to know who has called whom and which IP Phone has entered which code.
Ex.
voice translation-rule 2
 rule 1 /^912345\(.*\)/ /020\1/
 rule 2 /^967890\(.*\)/ /020\1/
voice translation-profile ild
 translate called 2
Since we use a calling card for International calling, the code and dial-prefix are replaced with 020. You can modify the translation pattern accordingly.
Hope this helps.
Best Regards,
Ganesh
ilana_ilana Wed, 06/22/2016 - 22:25
Hello all,
I am in stage of deploying fac in cme 10.5 to restrict international calls only and I am facing the same issue as the initial post of this thread, also the prompt plays sometime and sometime it by pass the prompt and connect international call direct. Can any body review my config and advise suggestion please ?
Following is my config & debug:
aaa new-model
aaa authentication login default group tacacs+ local
aaa authentication enable default enable
aaa authorization config-commands
aaa authorization exec default group tacacs+ local
aaa authorization commands 0 default group tacacs+ local
aaa authorization commands 1 default group tacacs+ local
aaa authorization commands 15 default group tacacs+ local
aaa accounting send stop-record authentication failure
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 0 default start-stop group tacacs+
aaa accounting commands 1 default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa accounting network default start-stop group tacacs+
aaa accounting system default start-stop group tacacs+
voice lpcor enable
voice lpcor custom
 group 10 ild
voice lpcor policy ild
 service fac
 accept ild fac
application
 package auth
  param max-retries 0
  param passwd-prompt flash:enter_pin.au
  param abort-digit *
  param term-digit #
  param user-prompt flash:enter_account.au
  param passwd 12345
  param max-digits 32
 service clid_authen_collect
  param uid-len 4
  param pin-len 4
username 1234 password 7 040A59555B
gw-accounting aaa
dial-peer cor custom
 name local
 name national
 name mobile
 name intl
 name fac-int
dial-peer cor list call-local
 member local
dial-peer cor list call-national
 member national
dial-peer cor list call-mobile
 member mobile
dial-peer cor list call-intl
 member intl
dial-peer cor list normal-user
 member local
dial-peer cor list fac-int
member fa-int
dial-peer cor list executive-user
 member local
 member national
 member mobile
dial-peer cor list intl-user
 member local
 member national
 member mobile
 member intl
 member local
 member national
 member mobile
 member intl
 member fac-int
dial-peer voice 50 voip  <-------- Is it necessary to create voip dial-peer ?
 corlist incoming fac-int
 corlist outgoing fac-int
 description ****INTL Dialing****
 session target ipv4:10.119.3.2
 incoming called-number 900T
 codec g711ulaw
 no vad
 port 0/0/0:15
 prefix 00
ephone-dn  70  octo-line
 number 8770
 label CIPC
 name CIPC
ephone  70
 lpcor type local
 lpcor incoming ild
 device-security-mode none
 description DXB CIPC
 mac-address XXXX.XXXX.XXXX
 busy-trigger-per-button 1
 type CIPC
 button  1:70
Following are some logs:
190792: Jun 22 10:54:05.302: //-1/xxxxxxxxxxxx/LPCOR/lpcor_get_index_by_ipaddress:
   ipaddress 10.119.3.77; vrf=0, host=; subnet_type=3
190793: Jun 22 10:54:05.302: //-1/xxxxxxxxxxxx/LPCOR/lpcor_get_index_by_ipaddress:
   Found lpcor index 0 for ipaddress 10.119.3.77
190794: Jun 22 10:54:05.302: //-1/xxxxxxxxxxxx/LPCOR/lpcor_get_index_by_peer:
   peer tag 40002, direction 0
190795: Jun 22 10:54:05.302: //-1/xxxxxxxxxxxx/LPCOR/lpcor_get_index_by_peer:
   Return Lpcor Index 0 for Peer Tag 40002
190796: Jun 22 10:54:39.430: //-1/xxxxxxxxxxxx/LPCOR/lpcor_get_index_by_name:
   lpcor ild
190797: Jun 22 10:54:39.430: //-1/xxxxxxxxxxxx/LPCOR/lpcor_get_index_by_name:
   lpcor ild index 10
190798: Jun 22 10:54:42.886: //-1/xxxxxxxxxxxx/LPCOR/lpcor_get_index_by_peer:
   peer tag 40002, direction 1
190799: Jun 22 10:54:42.886: //-1/xxxxxxxxxxxx/LPCOR/lpcor_get_index_by_peer:
190800: Jun 22 10:54:48.490: //-1/xxxxxxxxxxxx/LPCOR/lpcor_get_index_by_ipaddress:
   ipaddress 10.119.3.2; vrf=0, host=; subnet_type=3
190801: Jun 22 10:54:48.490: //-1/xxxxxxxxxxxx/LPCOR/lpcor_get_index_by_ipaddress:
   Found lpcor index 0 for ipaddress 10.119.3.2
Venkitesh H Iyer Sun, 06/26/2016 - 22:46
Hello All,
The issue has been resolved.
Detailed Explanation:
application
  param uid-len 3
  param pin-len 3
in this example the Account and PIN are three digits long).  This forces a user id and pid length
aaa new-model
username 201 password 123
username 201 autocommand exit
username 202 password 321
username 202 autocommand exit
** The "autocommand" option for the username, immediately logs out the user from the CME if these credentials are used for Telnet or SSH. The idea is to prevent a DOS attack on the unit if a malicious source were to monopolize the terminal (VTY) sessions. Please notice that if you have EZVPN server set up, these usernames could be used to access the system, in which case implementeting the FAC configuration at all is emphatically discouraged. Alternatively, you could use an access class to prevent the FAC users from connecting to the CME via telnet or SSH.
Then create dial-peers and translation pattern as required (example below)
voice translation-rule 1
rule 1 /^9\(.*\)/ /\1/
translate called 1
preference 5
port 0/0/0:15
forward digits all
session target ipv4:x.x.x.x (CME IP Address)
codec g711ulaw
no vad
Now, the above configuration enforces FAC usage for any caller trying to dial an international number.
In order to partition the dialplan, so some callers can go through without having to enter an username and password,
while others are still required to enter the credentials, more Class of Restriction Lists need to be configured.
Assuming the following:
- Extension 201 (ephone-dn 1) is a VIP caller and wants to dial without having to authenticate.
- Extension 202 (ephone-dn 2) is a regular caller and he has to go through the validation.
name international-fac
dial-peer cor list call-international-fac
member international-fac
dial-peer cor list user-international-fac
member internal
member local
member domestic
corlist incoming call-international-fac - these lines have already been added in the dial peer above
corlist outgoing call-international-fac - these lines have already been added in the dial peer above
ephone-dn 1
corlist incoming user-international
ephone-dn 2
corlist incoming user-international-fac
Venkitesh
eljose_lol Tue, 06/21/2011 - 14:46
Hi men
do you have some config example of LPCOR that creating category call users, for example: CAT 1 = local, mobile, LD,
CAT 2= local only and them asing to a ephone user.
thanks
thisisshanky Tue, 06/21/2011 - 15:20
are you trying to do LD codes and  various Class of restrictions for different users ? I think LPCOrs will  work only with this scrip tin place to authenticate fac...(again this is  such a new feature i cant authoritatively speak about it). Also i m  pretty sure you can use LPCORs for long distance authentication but at  same time use regular cors to restrict callers.....so cor lists will be  used to decide who gets to call what, while LPCors will be used to  restrict callers from calling LD calls..by forcing them to enter a  code...again this is all in theory...i have not tested this...
here is a good link to regular CORs..
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a008019d649.shtml
eljose_lol Wed, 06/22/2011 - 13:57
Hi thisisshanky
thanks for the answer, do you think that i can mix COR and LPCOR?
hugogarciaalcocer Tue, 07/26/2011 - 09:23
Yep, I've been trying to do the same with LPCors without any success... Is there a way (using only one trunk group) to ask for authentication ONLY for LD's and International calls but not for the local calls?
I mean there will be some users that will need to authenticate also for local calls but I can't seem to understand how this works for different types of users using a single trunkgroup...
THANKS!
t_kilany_2 Sun, 08/21/2011 - 15:44
Hello shamku,
I'm facing the same problem you have earlier, "
it asks for the username and password as programmed but then it hangs up the call..."
I have review the AAA section of my configuration it is the same exactly like you mentioned here and similar to the example of the Cisco documentation, but still the call is hangs up.
Any idea?
I have try some debug command, and got the following:
Aug 19 22:23:20.924: //850//Auth:/AUTH_ProcessAuthFailure: Auth operation Failed
Aug 19 22:23:20.924: //850//Auth:/AUTH_Close: status(2)
Aug 19 22:23:20.924: //-1//Auth:/AUTH_SetAuthFacData:
Aug 19 22:23:20.924: //-1//Auth:/AUTH_FacDataIsAvailable:
Aug 19 22:23:20.924: //850//Auth:/AUTH_Complete: Auth Returning 2 [AUTH_STATUS_FAILED]:  use_count(3)
Aug 19 22:23:20.928: //-1//Auth:HN006C9510:/AFW_M_Auth_Free:
Thanks!
thisisshanky Mon, 08/22/2011 - 14:02
Did you re-record the wave files properly in the g711ulaw 8bit mono  format...when the file formats were wrong i noticed that this was not  functioning properly...
Also please paste your configs, i can take a look at it...
t_kilany_2 Mon, 08/22/2011 - 16:53
Hi shamku,
Thank you for your reply!
I have used some Cisco files for audio. I guess they are ok.
enter_account.au
enter_pin.au
Codec Details for these files are as follow:
Codec: PCM MU-LAW (mlaw)
Channels: Mono
Sample rate: 8000 Hz
Bits per sample: 16
I will attach the configuration shortly as soon as I get back to office.
Tarik
Salvo_Phl Thu, 09/01/2011 - 04:43
Thanks Man,
This helped alot! Working at one of our remote brnaches thanks to your configs.
Phil
jonwoloshyn Thu, 09/22/2011 - 21:18
thisisshanky - have you noticed in your config the following:
This is not how you entered the command.
The entered command is just
trunk group XXX
For some reason IOS is changing the command in the config to what you have. When you reboot, your FACs won't work as IOS will not understand "trunk group lpcor outgoing PSTNTrunk"
I've had that issue just recently. Wondering if it's fixed in newer code. I think I was on 15.1 M1 Anyone else seen it?
thisisshanky Thu, 09/22/2011 - 21:21
You are right John
I did notice the same problem with the customer and right now as we speak we manually re-enter the command if router is rebooted. I am not sure if a later code has fixed this, yet to try..best open a tac case..
jonwoloshyn Thu, 09/22/2011 - 21:28
I'll try a newer version of code in my lab. I checked the bug toolkit but didn't see anything related. My customers system is completely isolated from their data network down to the copper so the only way for me to open a TAC case and get anywhere is to be onsite with the box so a TAC case isn't optimal for me as I don't have the cycles to sit there or any way to cost recover my time
jonwoloshyn Thu, 09/22/2011 - 21:34
BTW - with the param passwd, if you leave out the param passwd-prompt command, set the param passwd to a value and create all your numeric user accounts with the same password as what you have specified as param passwd, the auth application skips the password check so instead of needing userid and password, the caller only needs userid. Basically, means single stage authentication code like CUCM. Much nicer and easier for users to accept when coming from a different system.
thisisshanky Thu, 09/22/2011 - 21:36
wow thats a great find, i was wondering how to do that...good to know..
Praveen Arak Fri, 03/28/2014 - 03:49
Dear ,
        Can you please givr me working example for this as I do have same request  to use single pin authentication in CME 9.X .
Praveen
Jorge Luis Cove... Fri, 02/24/2012 - 07:48
Hi thisisshanky, I tested your script and it works well with FXO lines connected to PSTN.
But when I tested it using E1 primary the call end inmediately after ingress user and password.
This is the disconnect cause code: Service or option not available, or unspecified (63)
Venkitesh H Iyer Wed, 02/29/2012 - 23:09
Hello Jorge,
We are having 2 BRI Lines & 1 PRI Line in our Office and it works perfectly fine. In fact, we have kept the PRI for Local Calling (Local + STD) & the 2 BRI Lines for only ILD Calling. If you need, I will be pasting the configuration for you. Let me know. We are using LPCOR & COR Together. It works perfectly fine.
Ganesh
cogamboa Fri, 07/20/2012 - 12:35
thisisshanky:
You will have the full configutracion, I can provide a copy
saurabh_om Mon, 07/09/2012 - 11:52
I am trying to acheive FAC on CME 9. But i have doubt to get below matrix
                                 Local Call     LD Call        Intl Call
LOcal User  -->           NO FAC         FAC             FAC
LD Useer    -->            NO FAC         No FAC        FAC
Intl User    --->            NO FAC         NO FAC          NO FAC
How can i acheive this in LPcor policy and single E1 with many dialpeer pot for outgoing.
dennis916 Thu, 07/19/2012 - 02:52
hi saurabh_om,
We are facing the same delema, got a few tries doing this scenario and come up with the same result, if you are using a single E1 Pri/Bri that has all the outgoing function, lpcor is not the solution for now, unless cisco will fix it and rescript it in the new IOS version. Because that's the biggest problem of using lpcor, its like we need to block the whole E1 Pri dedicated for authentication calls and must have another E1 Pri using non-authentication calls. Sounds stupid and costly but we have to live with for now ^_^
If you want you can try using the "acctfixedpin.tcl" script, it runs on dial-peers and can be controlled by typical corlists.  Though its unsupported tcl script by Cisco, but develop by a brilliant guy who seem to be knockout by LPCOR.. hahahah Goodluck ^_^
jonwoloshyn Fri, 07/27/2012 - 07:03
dennis,
I think you can achieve what you want by combining lpcor and cor.
Use cor to restrict which dial peers a line/phone can use.
for dial peers that require fac, point them to the trunk group with lpcor
for dial peers that don't require fac, point them to the voice-port itself instead of the trunk
I was able to achieve this using cor/lpcor for a customer that only required fac on ld/intl but also had fax machines that didn't need to use fac.
I don't have the config handy but it worked fine
dennis916 Sun, 07/29/2012 - 20:15
Thank you for the quick reply, was able to try this configuration and I may be missing something out. ^_^ if you could provide additional assistance, it would be much appreciated.  I will retry this again and will give feedback.  Thanks.
saurabh_om Sun, 07/29/2012 - 23:38
Hello Dennis,
LPCOR and multiple auth code policy with single PRI line or POTS dial-peers.  with Voice Dial-pper, yes you can play with policies.
I found an alternative is to create translation patterns and match PSTN numbers with voice dial-pper first and then looping number back to CME itself.  Apply LPCOR policy on voice Dial-peer and take decision allow/restrict there itself.
Later make POTS dial-peer to reroute translated number to PSTN trunk.
Here is configuration :
Defines the name and number of LPCOR resource groups
voice lpcor custom
group 10 local                                             LPCOR group for Local Calls
group 11 ld                                                 LPCOR group for Long Distance Calls
group 12 isd                                                 LPCOR group for International Calls
Creates a LPCOR policy for a resource group
voice lpcor policy local                                       Service policy for local resource group
service fac                                                         Enable FAC Service for a routing endpoint
accept ld                                                             Accept calls from group without any FAC
accept isd
voice lpcor policy ld                                           Service policy for long distance resource group
service fac
accept local fac                                                 Accept calls from group with a valid FAC
accept isd
voice lpcor policy isd                                         Service policy for international resource group
service fac
accept local fac
accept ld fac
LPCOR for international numbers patterns:
voice translation-rule 2                         Voice translation rule translating international number
rule 1 /^000/ /654000/
voice translation-profile add654
translate called 2
dial-peer voice 311 voip
description international
translation-profile outgoing add654
destination-pattern 000T
lpcor outgoing isd
session target ipv4:10.220.2.2
dtmf-relay h245-alphanumeric h245-signal
codec g711ulaw
dial-peer voice 312 voip
incoming called-number 654000T
codec g711ulaw
dial-peer voice 310 pots
description # Dial-Peer to Dial ISD Numbers #
destination-pattern 654000T
port 0/0/0:15
prefix 00
LPCOR for Long Distance numbers patterns:
trunk group PRI-ACCESS                                             Define a trunk-group and associate an LPCOR policy
trunk group lpcor outgoing ld
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-5ess
isdn incoming-voice voice
isdn bchan-number-order ascending
trunk-group PRI-ACCESS                                                        Associate trunk-group to E1 PRI
no cdp enable
dial-peer voice 302 pots
trunkgroup PRI-ACCESS                                                          Associate trunk-group to longdistance dialpeer
description # Dial-Peer to Dial LD Mobile Numbers #
destination-pattern 00[7-9].........
forward-digits 11
*********** PLEASE RATE THE ANSWER IF YOU FIND IT HELPFUL *****************
dennis916 Mon, 07/30/2012 - 22:29
saurabh_om,
The idea is very helpful and solved the configuration issue we encounter.  We limit the configuration of the dial-peers and translation though by controlling it by cor-list (Pots - Outgoing to PSTN) per IP Phone access, much simplier to control and maintain ^_^
voice-port 0/0/0:15
description ***** ISDN PRI *****
no vad
timeouts interdigit 3
timeouts call-disconnect 3
timeouts wait-release 1
bearer-cap Speech
trunk group Cust01-E1
lpcor incoming Cust01ISDNTrunks
lpcor outgoing Cust01ISDNTrunks
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-31
trunk-group Cust01-E1 timeslots 1-31 preference 1
dial-peer voice 103 pots
corlist outgoing Cust01localcalls --> Cor List access to Local Calls
description ***** Outgoing POTS Call Leg from CME
destination-pattern 9[1-9]T
port 0/0/0:15 --> Local PSTN Access pointing to ISDN port.
dial-peer voice 100 pots
trunkgroup Cust01-E1 --> Local PSTN Access pointing to ISDN Trunkgroup
corlist outgoing Cust01IDDcalls --> Cor List access to IDD Calls
destination-pattern 9[0][0]T
forward-digits 11
prefix 00
Thank you,
Dennis
omarcruz1 Wed, 09/19/2012 - 15:16
Hi everybody,
All of you guys have a realy helpful information here but I have not gotten it. I am still trying to configure the FAC feature. The issue is that system is not validating neither the username nor password, because I dial number I want to reach then I receive recordings user&passwd prompt, I put them right or even wrong and the call is stablished. I have been looking out a lot of information of how to configure FAC, searching information about this issue but I can find nothing.
Im deplying over a 3945E ios 15.1(4)M4. CME 8.6
I will be thankful if anyone has any advice
Sincerely,
Omar Cruz
saurabh_om Wed, 09/19/2012 - 15:35
Hello Omar,
Can you share running configuration of CME.
Saurabh
omarcruz1 Fri, 09/21/2012 - 11:17
Saurabh,
thanks alot for your fast answer, but finally I could get it!!!! the issue was that I had 2 Dail Peers (DP) A and B. I was only requesting FAC for A. I had not seen that I kept B, so all the trafic was traveling through B. I took it out and right away it worked. : D
thanks for your attention though and have a great weekend!!!
aldredbenedict Fri, 11/09/2012 - 07:38
Hey guys I know this might sound dumb but I need to confirm this issue
Can the forced authorization code support many usernames and passwords (username xxx password 0 1234)? Let's say I have 2 usernames : 1234 and 4321. Can I use both of them to authenticate the calls?
aldredbenedict Mon, 11/12/2012 - 03:00
Thanks hanky. Btw does anybody know how to include the FAC username/pin in the CDR?
@Omar, I'm using ios 15.2(4)M1 and CME version 9.1. I haven't tried restarting the router (as it is in production mode), but once I do, I will tell you the results
omarcruz1 Fri, 11/09/2012 - 11:45
hi everybody,
I was implementing FAC on CME 8.6 with IOS 15.4M.3 all the functions are working good besides a little detail. I am facing with a command deleted called "trunk group lpcor outgoing " when I reloaded my CME. As I see you guys experienced this behavior before. the questions is Do you guys know the IOS version which is working properly?
thanks in advance
Alexandr Alakin Wed, 01/23/2013 - 03:05
I would like to know working IOS as well..
I have some odd behaviour with IOS 15.1(3)T3 (CME Version 8.5)
#sh voice lpcor policy
voice lpcor policy LP_2 (group 2)
  service fac is enabled
  ( accept     ) LP_2 (group 2)
  ( accept fac ) LP_3 (group 3)
voice lpcor policy LP_3 (group 3)
  ( accept fac ) LP_2 (group 2)
  ( accept     ) LP_3 (group 3)
ephone  2
lpcor type local
lpcor incoming LP_2
lpcor outgoing LP_2
ephone  3
lpcor type local
lpcor incoming LP_3
lpcor outgoing LP_3
I'm trying to enable FAC between 2002 (ephone 2) and 2003 (ephone 3).
Call 2003->2002 works fine, FAC is required in order to place a call (Debug shows: Source LPCOR is LP_3, Target LPCOR is LP_2)
Call 2002->2003 does not require FAC (Debug show that used LPCORs: Source LPCOR is LP_2, Target LPCOR is LP_2) until I add
conf t
accept LP_2 fac
I still cannot figure out why on earth the same LP_2 is used as both Source and Target??
Config and logs are attached
alis.tommy Sat, 12/07/2013 - 16:19
Hi All
I'm trying to configure CME FAC also for customer requirement,
But still doesn't work. Any idea please?
my configuration
aaa new-model
aaa authorization exec default local
trunk group TELKOM-E1
trunk group lpcor outgoing trunk
voice-card 0
voice lpcor enable
voice lpcor custom
group 10 user
group 11 trunk
voice lpcor policy user
service fac
accept user fac
accept trunk fac
voice lpcor policy trunk
service fac
accept user fac
accept trunk fac
application
package auth
  param passwd-prompt flash:en_bacd_welcome.au  --> should we put this file  en_bacd_welcome.au to flash?
  param abort-digit *
  param user-prompt flash:en_bacd_enter_dest.au --> should we put this file en_bacd_welcome.au to flash?
  param passwd 5555
  param term-digit #
  param max-digits 32
username 649 password 0 1258
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-30
trunk-group TELKOM-E1 timeslots 1-30
gw-accounting aaa
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn outgoing display-ie
no cdp enable
voice-port 0/0/0:15
name ALL
name LIMITED
dial-peer cor list ALL
member ALL
dial-peer cor list LIMITED
member LIMITED
dial-peer voice 1 pots
translation-profile incoming incoming
incoming called-number .
direct-inward-dial
dial-peer voice 15 pots
corlist outgoing ALL
translation-profile outgoing outgoing
destination-pattern 9T
port 0/0/0:15
dial-peer voice 16 pots
trunkgroup TELKOM-E1
lpcor outgoing trunk --> not yet configured, need this?
telephony-service
no auto-reg-ephone
max-ephones 100
max-dn 200
ip source-address 10.224.248.1 port 2000
system message CME
cnf-file location flash:
time-zone 40
date-format dd-mm-yy
max-conferences 8 gain -6
moh music-on-hold.au
multicast moh 239.1.1.1 port 2000 route 10.224.252.254
web admin system name unhcr password unhcr123
dn-webedit
transfer-system full-consult
create cnf-files version-stamp 7960 Dec 03 2013 13:00:40
ephone-template  1
lpcor type local
lpcor incoming user
lpcor outgoing user --> not yet configured, need this?
ephone-dn  13  dual-line
number 649
pickup-group 1101
label Server Room - 649
description Server Room - 649
name Server Room - 649
ephone  13
mac-address 0C68.03C1.79B8
ephone-template 1
type 7945
button  1:13
RTR-01#sh flash0:
-#- --length-- -----date/time------ path
1     68482708 Aug 13 2013 11:24:54 +07:00 c3900e-universalk9-mz.SPA.151-4.M5.bin
239       2464 Aug 13 2013 11:37:14 +07:00 home.shtml
240          0 Nov 30 2013 16:38:02 +07:00 its
241          0 Nov 30 2013 16:38:02 +07:00 its/vrf1
242         60 Nov 30 2013 16:38:06 +07:00 its/SEPDEFAULT.cnf
243       3239 Nov 30 2013 16:38:06 +07:00 its/vrf1/XMLDefault.cnf.xml
244        517 Nov 30 2013 16:38:08 +07:00 its/vrf1/XMLDefault7902.cnf.xml
245        970 Nov 30 2013 16:38:08 +07:00 its/vrf1/XMLDefault7905.cnf.xml
246       1260 Nov 30 2013 17:52:16 +07:00 its/vrf1/XMLDefault7906.cnf.xml
247        603 Nov 30 2013 16:38:08 +07:00 its/vrf1/XMLDefault7910.cnf.xml
248       1260 Nov 30 2013 17:52:18 +07:00 its/vrf1/XMLDefault7911.cnf.xml
249        970 Nov 30 2013 16:38:10 +07:00 its/vrf1/XMLDefault7912.cnf.xml
250        970 Nov 30 2013 16:38:10 +07:00 its/vrf1/XMLDefault7920.cnf.xml
251       1186 Nov 30 2013 17:52:18 +07:00 its/vrf1/XMLDefault7921.cnf.xml
252       1222 Nov 30 2013 17:52:18 +07:00 its/vrf1/XMLDefault7925.cnf.xml
253       1260 Nov 30 2013 17:52:18 +07:00 its/vrf1/XMLDefault7931.cnf.xml
254        550 Nov 30 2013 16:38:12 +07:00 its/vrf1/XMLDefault7935.cnf.xml
255        550 Nov 30 2013 16:38:12 +07:00 its/vrf1/XMLDefault7936.cnf.xml
256       1260 Nov 30 2013 17:52:18 +07:00 its/vrf1/XMLDefault7937.cnf.xml
257       1065 Nov 30 2013 16:38:14 +07:00 its/vrf1/XMLDefault7940.cnf.xml
258       1227 Nov 30 2013 16:38:14 +07:00 its/vrf1/XMLDefault7940-7914-1.cnf.xml
259       1227 Nov 30 2013 16:38:14 +07:00 its/vrf1/XMLDefault7940-7915-12-1.cnf.xml
260       1227 Nov 30 2013 16:38:14 +07:00 its/vrf1/XMLDefault7940-7915-24-1.cnf.xml
261       1227 Nov 30 2013 16:38:14 +07:00 its/vrf1/XMLDefault7940-7916-12-1.cnf.xml
262       1227 Nov 30 2013 16:38:16 +07:00 its/vrf1/XMLDefault7940-7916-24-1.cnf.xml
263       1358 Nov 30 2013 16:38:16 +07:00 its/vrf1/XMLDefault7940-7914-2.cnf.xml
264       1358 Nov 30 2013 16:38:16 +07:00 its/vrf1/XMLDefault7940-7915-12-2.cnf.xml
265       1358 Nov 30 2013 16:38:16 +07:00 its/vrf1/XMLDefault7940-7915-24-2.cnf.xml
266       1358 Nov 30 2013 16:38:18 +07:00 its/vrf1/XMLDefault7940-7916-12-2.cnf.xml
267       1358 Nov 30 2013 16:38:18 +07:00 its/vrf1/XMLDefault7940-7916-24-2.cnf.xml
268       1260 Nov 30 2013 17:52:20 +07:00 its/vrf1/XMLDefault7941.cnf.xml
269       1262 Nov 30 2013 17:52:20 +07:00 its/vrf1/XMLDefault7941GE.cnf.xml
270       1260 Nov 30 2013 17:52:20 +07:00 its/vrf1/XMLDefault7942.cnf.xml
271       1260 Nov 30 2013 17:52:20 +07:00 its/vrf1/XMLDefault7945.cnf.xml
272       1065 Nov 30 2013 16:38:20 +07:00 its/vrf1/XMLDefault7960.cnf.xml
273       1227 Nov 30 2013 16:38:20 +07:00 its/vrf1/XMLDefault7960-7914-1.cnf.xml
274       1227 Nov 30 2013 16:38:20 +07:00 its/vrf1/XMLDefault7960-7915-12-1.cnf.xml
275       1227 Nov 30 2013 16:38:22 +07:00 its/vrf1/XMLDefault7960-7915-24-1.cnf.xml
276       1227 Nov 30 2013 16:38:22 +07:00 its/vrf1/XMLDefault7960-7916-12-1.cnf.xml
277       1227 Nov 30 2013 16:38:22 +07:00 its/vrf1/XMLDefault7960-7916-24-1.cnf.xml
278       1358 Nov 30 2013 16:38:22 +07:00 its/vrf1/XMLDefault7960-7914-2.cnf.xml
279       1358 Nov 30 2013 16:38:24 +07:00 its/vrf1/XMLDefault7960-7915-12-2.cnf.xml
280       1358 Nov 30 2013 16:38:24 +07:00 its/vrf1/XMLDefault7960-7915-24-2.cnf.xml
281       1358 Nov 30 2013 16:38:24 +07:00 its/vrf1/XMLDefault7960-7916-12-2.cnf.xml
282       1358 Nov 30 2013 16:38:24 +07:00 its/vrf1/XMLDefault7960-7916-24-2.cnf.xml
283       1260 Nov 30 2013 17:52:22 +07:00 its/vrf1/XMLDefault7961.cnf.xml
284       1422 Nov 30 2013 17:52:22 +07:00 its/vrf1/XMLDefault7961-7914-1.cnf.xml
285       1422 Nov 30 2013 17:52:22 +07:00 its/vrf1/XMLDefault7961-7915-12-1.cnf.xml
286       1422 Nov 30 2013 17:52:22 +07:00 its/vrf1/XMLDefault7961-7915-24-1.cnf.xml
287       1422 Nov 30 2013 17:52:22 +07:00 its/vrf1/XMLDefault7961-7916-12-1.cnf.xml
288       1422 Nov 30 2013 17:52:24 +07:00 its/vrf1/XMLDefault7961-7916-24-1.cnf.xml
289       1553 Nov 30 2013 17:52:24 +07:00 its/vrf1/XMLDefault7961-7914-2.cnf.xml
290       1553 Nov 30 2013 17:52:24 +07:00 its/vrf1/XMLDefault7961-7915-12-2.cnf.xml
291       1553 Nov 30 2013 17:52:24 +07:00 its/vrf1/XMLDefault7961-7915-24-2.cnf.xml
292       1553 Nov 30 2013 17:52:24 +07:00 its/vrf1/XMLDefault7961-7916-12-2.cnf.xml
293       1553 Nov 30 2013 17:52:26 +07:00 its/vrf1/XMLDefault7961-7916-24-2.cnf.xml
294       1262 Nov 30 2013 17:52:26 +07:00 its/vrf1/XMLDefault7961GE.cnf.xml
295       1424 Nov 30 2013 17:52:26 +07:00 its/vrf1/XMLDefault7961GE-7914-1.cnf.xml
296       1424 Nov 30 2013 17:52:26 +07:00 its/vrf1/XMLDefault7961GE-7915-12-1.cnf.xml
297       1424 Nov 30 2013 17:52:28 +07:00 its/vrf1/XMLDefault7961GE-7915-24-1.cnf.xml
298       1424 Nov 30 2013 17:52:28 +07:00 its/vrf1/XMLDefault7961GE-7916-12-1.cnf.xml
299       1424 Nov 30 2013 17:52:28 +07:00 its/vrf1/XMLDefault7961GE-7916-24-1.cnf.xml
300       1555 Nov 30 2013 17:52:28 +07:00 its/vrf1/XMLDefault7961GE-7914-2.cnf.xml
301       1555 Nov 30 2013 17:52:28 +07:00 its/vrf1/XMLDefault7961GE-7915-12-2.cnf.xml
302       1555 Nov 30 2013 17:52:30 +07:00 its/vrf1/XMLDefault7961GE-7915-24-2.cnf.xml
303       1555 Nov 30 2013 17:52:30 +07:00 its/vrf1/XMLDefault7961GE-7916-12-2.cnf.xml
304       1555 Nov 30 2013 17:52:30 +07:00 its/vrf1/XMLDefault7961GE-7916-24-2.cnf.xml
305       1260 Nov 30 2013 17:52:30 +07:00 its/vrf1/XMLDefault7962.cnf.xml
306       1422 Nov 30 2013 17:52:30 +07:00 its/vrf1/XMLDefault7962-7914-1.cnf.xml
307       1422 Nov 30 2013 17:52:32 +07:00 its/vrf1/XMLDefault7962-7915-12-1.cnf.xml
308       1422 Nov 30 2013 17:52:32 +07:00 its/vrf1/XMLDefault7962-7915-24-1.cnf.xml
309       1422 Nov 30 2013 17:52:32 +07:00 its/vrf1/XMLDefault7962-7916-12-1.cnf.xml
310       1422 Nov 30 2013 17:52:32 +07:00 its/vrf1/XMLDefault7962-7916-24-1.cnf.xml
311       1553 Nov 30 2013 17:52:32 +07:00 its/vrf1/XMLDefault7962-7914-2.cnf.xml
312       1553 Nov 30 2013 17:52:32 +07:00 its/vrf1/XMLDefault7962-7915-12-2.cnf.xml
313       1553 Nov 30 2013 17:52:34 +07:00 its/vrf1/XMLDefault7962-7915-24-2.cnf.xml
314       1553 Nov 30 2013 17:52:34 +07:00 its/vrf1/XMLDefault7962-7916-12-2.cnf.xml
315       1553 Nov 30 2013 17:52:34 +07:00 its/vrf1/XMLDefault7962-7916-24-2.cnf.xml
316       1260 Nov 30 2013 17:52:34 +07:00 its/vrf1/XMLDefault7965.cnf.xml
317       1422 Nov 30 2013 17:52:34 +07:00 its/vrf1/XMLDefault7965-7914-1.cnf.xml
318       1422 Nov 30 2013 17:52:34 +07:00 its/vrf1/XMLDefault7965-7915-12-1.cnf.xml
319       1422 Nov 30 2013 17:52:36 +07:00 its/vrf1/XMLDefault7965-7915-24-1.cnf.xml
320       1422 Nov 30 2013 17:52:36 +07:00 its/vrf1/XMLDefault7965-7916-12-1.cnf.xml
321       1422 Nov 30 2013 17:52:36 +07:00 its/vrf1/XMLDefault7965-7916-24-1.cnf.xml
322       1553 Nov 30 2013 17:52:36 +07:00 its/vrf1/XMLDefault7965-7914-2.cnf.xml
323       1553 Nov 30 2013 17:52:36 +07:00 its/vrf1/XMLDefault7965-7915-12-2.cnf.xml
324       1553 Nov 30 2013 17:52:36 +07:00 its/vrf1/XMLDefault7965-7915-24-2.cnf.xml
325       1553 Nov 30 2013 17:52:38 +07:00 its/vrf1/XMLDefault7965-7916-12-2.cnf.xml
326       1553 Nov 30 2013 17:52:38 +07:00 its/vrf1/XMLDefault7965-7916-24-2.cnf.xml
327       1260 Nov 30 2013 17:52:38 +07:00 its/vrf1/XMLDefault7970.cnf.xml
328       1422 Nov 30 2013 17:52:38 +07:00 its/vrf1/XMLDefault7970-7914-1.cnf.xml
329       1422 Nov 30 2013 17:52:38 +07:00 its/vrf1/XMLDefault7970-7915-12-1.cnf.xml
330       1422 Nov 30 2013 17:52:38 +07:00 its/vrf1/XMLDefault7970-7915-24-1.cnf.xml
331       1422 Nov 30 2013 17:52:40 +07:00 its/vrf1/XMLDefault7970-7916-12-1.cnf.xml
332       1422 Nov 30 2013 17:52:40 +07:00 its/vrf1/XMLDefault7970-7916-24-1.cnf.xml
333       1553 Nov 30 2013 17:52:40 +07:00 its/vrf1/XMLDefault7970-7914-2.cnf.xml
334       1553 Nov 30 2013 17:52:40 +07:00 its/vrf1/XMLDefault7970-7915-12-2.cnf.xml
335       1553 Nov 30 2013 17:52:40 +07:00 its/vrf1/XMLDefault7970-7915-24-2.cnf.xml
336       1553 Nov 30 2013 17:52:40 +07:00 its/vrf1/XMLDefault7970-7916-12-2.cnf.xml
337       1553 Nov 30 2013 17:52:42 +07:00 its/vrf1/XMLDefault7970-7916-24-2.cnf.xml
338       1260 Nov 30 2013 17:52:42 +07:00 its/vrf1/XMLDefault7971.cnf.xml
339       1422 Nov 30 2013 17:52:42 +07:00 its/vrf1/XMLDefault7971-7914-1.cnf.xml
340       1422 Nov 30 2013 17:52:42 +07:00 its/vrf1/XMLDefault7971-7915-12-1.cnf.xml
341       1422 Nov 30 2013 17:52:42 +07:00 its/vrf1/XMLDefault7971-7915-24-1.cnf.xml
342       1422 Nov 30 2013 17:52:42 +07:00 its/vrf1/XMLDefault7971-7916-12-1.cnf.xml
343       1422 Nov 30 2013 17:52:44 +07:00 its/vrf1/XMLDefault7971-7916-24-1.cnf.xml
344       1553 Nov 30 2013 17:52:44 +07:00 its/vrf1/XMLDefault7971-7914-2.cnf.xml
345       1553 Nov 30 2013 17:52:44 +07:00 its/vrf1/XMLDefault7971-7915-12-2.cnf.xml
346       1553 Nov 30 2013 17:52:44 +07:00 its/vrf1/XMLDefault7971-7915-24-2.cnf.xml
347       1553 Nov 30 2013 17:52:44 +07:00 its/vrf1/XMLDefault7971-7916-12-2.cnf.xml
348       1553 Nov 30 2013 17:52:44 +07:00 its/vrf1/XMLDefault7971-7916-24-2.cnf.xml
349       1260 Nov 30 2013 17:52:46 +07:00 its/vrf1/XMLDefault7975.cnf.xml
350       1422 Nov 30 2013 17:52:46 +07:00 its/vrf1/XMLDefault7975-7914-1.cnf.xml
351       1422 Nov 30 2013 17:52:46 +07:00 its/vrf1/XMLDefault7975-7915-12-1.cnf.xml
352       1422 Nov 30 2013 17:52:46 +07:00 its/vrf1/XMLDefault7975-7915-24-1.cnf.xml
353       1422 Nov 30 2013 17:52:46 +07:00 its/vrf1/XMLDefault7975-7916-12-1.cnf.xml
354       1422 Nov 30 2013 17:52:46 +07:00 its/vrf1/XMLDefault7975-7916-24-1.cnf.xml
355       1553 Nov 30 2013 17:52:48 +07:00 its/vrf1/XMLDefault7975-7914-2.cnf.xml
356       1553 Nov 30 2013 17:52:48 +07:00 its/vrf1/XMLDefault7975-7915-12-2.cnf.xml
357       1553 Nov 30 2013 17:52:48 +07:00 its/vrf1/XMLDefault7975-7915-24-2.cnf.xml
358       1553 Nov 30 2013 17:52:48 +07:00 its/vrf1/XMLDefault7975-7916-12-2.cnf.xml
359       1553 Nov 30 2013 17:52:48 +07:00 its/vrf1/XMLDefault7975-7916-24-2.cnf.xml
360       1260 Nov 30 2013 17:52:48 +07:00 its/vrf1/XMLDefault7985.cnf.xml
361        404 Nov 30 2013 16:39:02 +07:00 its/vrf1/ATADefault.cnf.xml
362       1224 Nov 30 2013 17:52:50 +07:00 its/vrf1/XMLDefaultCIPC.cnf.xml
363       1353 Nov 30 2013 17:52:50 +07:00 its/vrf1/XMLDefault6921.cnf.xml
364       1353 Nov 30 2013 17:52:50 +07:00 its/vrf1/XMLDefault6941.cnf.xml
365       1353 Nov 30 2013 17:52:50 +07:00 its/vrf1/XMLDefault6961.cnf.xml
366       1260 Nov 30 2013 17:52:50 +07:00 its/vrf1/XMLDefault6901.cnf.xml
367       1260 Nov 30 2013 17:52:50 +07:00 its/vrf1/XMLDefault6911.cnf.xml
368       1222 Nov 30 2013 17:52:52 +07:00 its/vrf1/XMLDefault7926.cnf.xml
369        903 Nov 30 2013 16:39:06 +07:00 its/united_states_7960-tones.xml
370       8777 Nov 30 2013 16:39:06 +07:00 its/united_states_7960-font.xml
371       1313 Nov 30 2013 16:39:06 +07:00 its/united_states_7960-kate.xml
372      19750 Nov 30 2013 16:39:06 +07:00 its/united_states_7960-dictionary.xml
373       2740 Nov 30 2013 16:39:08 +07:00 its/united_states_SCCP-dictionary.xml
374     496521 Dec 3 2013 12:38:48 +07:00 music-on-hold.au
375      55599 Dec 3 2013 17:23:12 +07:00 app-b-acd-aa-3.0.0.2.tcl
376    1030860 Dec 3 2013 17:44:44 +07:00 en_bacd_welcome.au
377          0 Dec 5 2013 14:10:12 +07:00 gui
378     828928 Dec 5 2013 14:20:14 +07:00 gui.tar
379       4118 Dec 5 2013 14:21:30 +07:00 gui/admin_user.html
380     677820 Dec 5 2013 14:21:32 +07:00 gui/admin_user.js
381       1029 Dec 5 2013 14:21:32 +07:00 gui/CiscoLogo.gif
382        639 Dec 5 2013 14:21:32 +07:00 gui/CME_GUI_README.TXT
383        953 Dec 5 2013 14:21:32 +07:00 gui/Delete.gif
384      16344 Dec 5 2013 14:21:32 +07:00 gui/dom.js
385        864 Dec 5 2013 14:21:34 +07:00 gui/downarrow.gif
386       6315 Dec 5 2013 14:21:34 +07:00 gui/ephone_admin.html
387       4558 Dec 5 2013 14:21:34 +07:00 gui/logohome.gif
388       3978 Dec 5 2013 14:21:34 +07:00 gui/normal_user.html
389      78428 Dec 5 2013 14:21:36 +07:00 gui/normal_user.js
390       1347 Dec 5 2013 14:21:36 +07:00 gui/Plus.gif
391        843 Dec 5 2013 14:21:36 +07:00 gui/sxiconad.gif
392        174 Dec 5 2013 14:21:36 +07:00 gui/Tab.gif
393       2496 Dec 5 2013 14:21:36 +07:00 gui/telephony_service.html
394        870 Dec 5 2013 14:21:38 +07:00 gui/uparrow.gif
395      10230 Dec 5 2013 14:21:38 +07:00 gui/xml-test.html
396       3412 Dec 5 2013 14:21:38 +07:00 gui/xml.template
397       2910 Dec 5 2013 15:33:52 +07:00 RingList.xml
398       2823 Dec 5 2013 14:41:20 +07:00 DistinctiveRingList.xml
399     326144 Dec 5 2013 14:46:50 +07:00 ringtones.tar
400          0 Dec 5 2013 14:47:18 +07:00 ringtones
401       8160 Dec 5 2013 14:47:18 +07:00 ringtones/Analog1.raw
402       8160 Dec 5 2013 14:47:18 +07:00 ringtones/Analog2.raw
403       5280 Dec 5 2013 14:47:18 +07:00 ringtones/AreYouThere.raw
404       5040 Dec 5 2013 14:47:20 +07:00 ringtones/AreYouThereF.raw
405       8160 Dec 5 2013 14:47:20 +07:00 ringtones/Bass.raw
406      12240 Dec 5 2013 14:47:20 +07:00 ringtones/CallBack.raw
407      16040 Dec 5 2013 14:47:20 +07:00 ringtones/Chime.raw
408       8160 Dec 5 2013 14:47:22 +07:00 ringtones/Classic1.raw
409      16080 Dec 5 2013 14:47:22 +07:00 ringtones/Classic2.raw
410      10800 Dec 5 2013 14:47:22 +07:00 ringtones/ClockShop.raw
411       2823 Dec 5 2013 14:47:22 +07:00 ringtones/DistinctiveRingList.xml
412       9600 Dec 5 2013 14:47:22 +07:00 ringtones/Drums1.raw
413      13440 Dec 5 2013 14:47:24 +07:00 ringtones/Drums2.raw
414      15840 Dec 5 2013 14:47:24 +07:00 ringtones/FilmScore.raw
415      16080 Dec 5 2013 14:47:24 +07:00 ringtones/HarpSynth.raw
416       8160 Dec 5 2013 14:47:24 +07:00 ringtones/Jamaica.raw
417      16080 Dec 5 2013 14:47:24 +07:00 ringtones/KotoEffect.raw
418      12720 Dec 5 2013 14:47:26 +07:00 ringtones/MusicBox.raw
419       8160 Dec 5 2013 14:47:26 +07:00 ringtones/Piano1.raw
420      15360 Dec 5 2013 14:47:26 +07:00 ringtones/Piano2.raw
421       9360 Dec 5 2013 14:47:26 +07:00 ringtones/Pop.raw
422       7200 Dec 5 2013 14:47:26 +07:00 ringtones/Pulse1.raw
423       4000 Dec 5 2013 14:47:28 +07:00 ringtones/Ring1.raw
424       4000 Dec 5 2013 14:47:28 +07:00 ringtones/Ring2.raw
425       4000 Dec 5 2013 14:47:28 +07:00 ringtones/Ring3.raw
426       4000 Dec 5 2013 14:47:28 +07:00 ringtones/Ring4.raw
427       4000 Dec 5 2013 14:47:30 +07:00 ringtones/Ring5.raw
428       4000 Dec 5 2013 14:47:30 +07:00 ringtones/Ring6.raw
429       4000 Dec 5 2013 14:47:30 +07:00 ringtones/Ring7.raw
430        495 Dec 5 2013 14:47:30 +07:00 ringtones/RingList.xml
431      10800 Dec 5 2013 14:47:30 +07:00 ringtones/Sax1.raw
432      14160 Dec 5 2013 14:47:32 +07:00 ringtones/Sax2.raw
433      16080 Dec 5 2013 14:47:32 +07:00 ringtones/Vibe.raw
434       1435 Dec 6 2013 17:33:04 +07:00 its/vrf1/SEP0C6803C179B8.cnf.xml
181395456 bytes available (75214848 bytes used)
RTR-01#
Praveen Arak Fri, 03/28/2014 - 03:53
Dear Team ,
                 Can any body please provide guidance  for single one time pin authentication for LP COR FAC in CME 9.x . Do please suggest and advise doe the best .
Praveen
mraj_ Seed Thu, 06/12/2014 - 02:36
hi Shanky,
am facing issue with this config, the audio file are not on my root flash, will it work ?
asotojimenezz Thu, 06/25/2015 - 15:13
Hello everyone
I need help.which is my mistake ??
aaa new-model
gw-accounting aaa
voice lpcor enable
voice lpcor custom
 group 10 end-user
 group 11 pstntrunk
 service fac
 accept end-user fac
 accept pstntrunk fac
voice lpcor policy pstntrunk
 service fac
 accept end-user fac
application
 package auth
  param max-retries 0
  param passwd 1973285
  param abort-digit *
  param term-digit #
  param max-digits 32
username 1 password 0 91724
username 2 password 0 50476
username 3 password 0 87123
username 4 password 0 98237
username 5 password 0 10568
username 6 password 0 29561
username 7 password 0 56102
username 8 password 0 43875
username 9 password 0 87325
username 10 password 0 31854
username 11 password 0 69425
username 12 password 0 79161
username 13 password 0 94989
username 14 password 0 65443
controller E1 0/0/0
 framing NO-CRC4
 line-termination 75-ohm
 ds0-group 0 timeslots 1-15,17-31 type r2-digital r2-compelled ani
 cas-custom 0
  country telmex
  category 2
  caller-digits 4
  dnis-digits min 4 max 13
  dnis-complete
  timer interdigit incoming 1000
  groupa-callerid-end
dial-peer voice 921 pots
 corlist outgoing CallCelularLocal
 incoming called-number 9044..........
 direct-inward-dial
 prefix 044
dial-peer voice 931 pots
 corlist outgoing CallCelularNacional
 incoming called-number 9045..........
 direct-inward-dial
 prefix 045
dial-peer voice 941 pots
 corlist outgoing CallLD-Nacional
 incoming called-number 901..........
 direct-inward-dial
 prefix 01
voice register pool  2
 pin 50476
 lpcor type local
 lpcor incoming superuser
 busy-trigger-per-button 2
 id mac 547C.69D7.6706
 type 7841
 number 1 dn 2
 cor incoming Nivel3 default
 presence call-list
 dtmf-relay rtp-nte sip-notify
 username 2 password 50476
 description 7841
 codec g711ulaw
Regards.
Amit Sharma Fri, 07/31/2015 - 23:06
how can apply FAC as we have SIP trunk with cme 10.5?
what would change in configuration for FAC in CME?
Jaime Terrazas ... Mon, 10/05/2015 - 16:00
Please review this link for the explanation
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configura...
SUMMARY STEPS
1. enable
2. configure terminal
3. voice lpcor ip-trunk subnet incoming
4. index index-number lpcor-group { ipv4-address network-mask | hostname hostname }
5. exit
6. voice service voip
7. lpcor incoming lpcor-group
8. exit
9. dial-peer voice tag voip
10. lpcor outgoing lpcor-group
11. end
Examples
The following example shows a LPCOR configuration for VoIP trunks:
index 1 h323_group1 172.19.33.0 255.255.255.0
index 2 sip_group1 172.19.22.0 255.255.255.0
index 3 sip_group2 hostname sipexample
voice service voip
lpcor incoming voip_trunk_1
dial-peer voice 233 voip
description H323 trunk outbound dial-peer
destination-pattern 233T
session target ipv4:172.19.33.233
lpcor outgoing h323_group1
dial-peer voice 2255 voip
description SIP trunk outbound dial-peer
destination-pattern 255T
Related Content
