Registration error 404 - Not found
vlad.vlaicu
paolo bevilacqua
Set username to be the same as DN number.
6 Replies 6
paolo bevilacqua
Wow... thanks. It worked. One small question: i've used this tutorial and at some point the guy uses username: test. In the end the phone registers correctly for him. How come it worked the username different than the DN number?
That trick is needed when the phone that is registering does not support digest authentication.  You can use a username like test if the phone supports digest authentication, otherwise the DN will have to be the username.
Digest authentication... that's the pointer I needed.  Wish I'd googled it 2-hours earlier :-)
Just some different settings.
Thanks for the nice rating and good luck!
This worked for me too (sorry for the me too)
