ASA 5520 with NAT and HTTP traffic
Answered Question
Hi Friends,
Shall i configure like this,
1. Static NAT to ISP1
    HTTP traffic to ISP2
2.if ISP1 fails ALL Static NAT and HTTP traffic should go through ISP2
pls guid me
Correct Answer by varrao about 5 years 7 months ago
Hi Thiru,
Yes, if you configure it as per the doc, whenever ISP1 fails, all the traffic including http, would go through your ISP2 only.
Varun
Overall Rating: 0 (1 ratings)
varrao Tue, 06/21/2011 - 05:32
Yes that is correct, it would failover to the ISP2
Varun
tasneemjan Tue, 06/21/2011 - 06:24
You might want to look at static route tracking with sla monitor. You can use icmp to ping an ip address to ISP1 and if ASA sees a drop in ping reply it would populate a backup route in the routing table.
yes, that's correct,
Shall i configure ISP1 to take the Static NAT traffic, at the same time ISP2 take the HTTP traffic for user web browsing. Same time both ISP Will work? Suppsoe ISP2 goes down only internet browsing Stopped, that is not an issues,
if ISP1 fails, ISP2 will takecare of both traffic? is this possible in ASA5520 or we will go to router?
pls clarify me, i'm so confused
Correct Answer
varrao Tue, 06/21/2011 - 06:50
Hi Thiru,
Varun
