Linksys E1200 Wireless-N Router
Jun 21st, 2011
hi all,
i'm planning to buy this wireless router but i don't see the specs whether it's backward compatible with 802.11b/g. can anyone confirm if it works with b/g. any personal review/experience with this device? thanks in advance.
http://homestore.cisco.com/en-us/Routers/Linksys-E1200-WirelessN-Router_stcVVproductId129966524VVcatId551966VVviewprod.htm
cindy toy Tue, 06/21/2011 - 22:36
Hi John,
Thank you for your question.  However you posted your question in the Cisco Small Business Support community which is for Cisco Small Business products.  The E1200 is a Cisco Home product and the place to post your question is here: http://homecommunity.cisco.com/t5/Wireless-Routers/bd-p/Wireless_Routers
Cindy Toy
Cisco Small Business Community Manager
for Cisco Small Business Products
www.cisco.com/go/smallbizsupport
johnlloyd_13 Wed, 06/22/2011 - 08:14
Hi Cindy,
I've tried to go to the link you've provided but my Cisco login doesn't work. I assume I'd need to create a new one in order to join this forum. Anyways, I've got a feedback from a friend and went ahead buying this device.
cindy toy Wed, 06/22/2011 - 12:58
Hi John,
Oops sorry I forgot to tell you about that. Yes, you are correct, your Cisco login will not work there.  They require a different login.
Cindy
Related Content
