06-22-2011 12:48 PM
Well it looks like 6.3.2 has been released. I am downloading as I type this from the cisco.com support site. Not on the ET site yet. I will update this post once I have it installed.
Noticed there are no upgrade guides in any of the zip files and not one posted on the support site either. I guess this will come with time.
What will really be nice is when the Software Assistant is updated for 6.3.2.
It is also nice to see that they have finally posted the CIVS-ENC file for the builtin wanka encoder cards.
Camera replacement feature, which lets you easily replace a Cisco IP camera 2421 or 25xx model
• New on-screen Display (OSD) provides the controls for Kalatel Cyberdome 1 and 2 camera models
• New camera and RAID health events
• New RAID Status page in the Management Console
• Support for two graphics cards and four monitors
Health monitoring e-mail notification feature, which sends e-mail messages to the designated
Updates to backup archive permission functionality recipient if error or warning events exist in the system
Erik
06-22-2011 12:52 PM
Hi Erik,
You're correct. The guides should be posted shortly. The installation and upgrade is the same as for 6.3.1. I will be working on a install/upgrade script for 6.3.2 that will be pretty much the same as the one for 6.3.1, but I want to add in support for the new encoder card too.
Sean
06-23-2011 09:36 AM
Hi Erik,
I have published the new Cisco VSM Software Assistant version 6.3.2 in the Documents section of the forums. Please let me know if you run into any problems with it.
Thank you,
Sean
