Flash through WEBVPN
Answered Question
Jun 23rd, 2011
I'm having problem accessing internal webpages that have flash through the webvpn. Is there a compatibility problem ?
Thank you
Correct Answer by Todd Pula about 2 years 9 months ago
You can configure the Smart Tunnel feature on the iNotes bookmark directly.  When the user clicks on the bookmark, a connection will be made through the client's browser to the iNotes server using the ASA as a proxy.  All traffic for the iNotes session will be sent through the tunnel thus bypassing the rewriter.
Todd
Average Rating: 0 (1 ratings)
Todd Pula Fri, 06/24/2011 - 14:57
The ASA will attempt to rewrite the Flash content.  For cases where the Flash content cannot be rendered correctly, you will want to configure a Smart Tunnel.
Todd
Rodrigo Gurriti Fri, 06/24/2011 - 15:19
Todd thank for you reply
How does the smart tunnel works on that case ?
I've used smart tunnels before to fix port problems but never because of problems with flash.
The user will be on the webvpn and then he access a bookmark with a link to intranet and then the webvpn proxies the calls to the web server. How the ST works on this case ?
Thank you
Correct Answer
Todd Pula Fri, 06/24/2011 - 15:33
Todd
Rodrigo Gurriti Tue, 06/28/2011 - 08:58
Thank you, tested and it works just fine.
Its just odd because an other tab is opened but works just fine
ROBERTO GIANA Tue, 12/20/2011 - 07:56
How can we enable the Smart Tunnel feature when the web page is accessed over a "Homepage URL" configuration? So there is no bookmark to set Smart Tunnel mark.
Login or Register to take actions
Posted June 23, 2011 at 6:12 PM
Stats:
Replies:5 Avg. Rating:
Views:839 Votes:0
Shares:0
Tags: No tags.
Discussions Leaderboard
