06-28-2011 01:11 PM
I am attempting to configure an ASA to form an IPSec L2L tunnel with a Juniper device. Phase one completes OK but phase two fails. I see the following message in the ASA logs:
3|Jun 28 2011|15:52:22|713902|||||Group = x.x.x.x, IP = x.x.x.x, Removing peer from correlator table failed, no match!
3|Jun 28 2011|15:52:22|713902|||||Group = x.x.x.x, IP = x.x.x.x, QM FSM error (P2 struct &0x7aa6c190, mess id 0x8bc2144b)!
3|Jun 28 2011|15:52:22|713061|||||Group = x.x.x.x, IP = x.x.x.x, Rejecting IPSec tunnel: no matching crypto map entry for remote proxy 0.0.0.0/0.0.0.0/0/0 local proxy 0.0.0.0/0.0.0.0/0/0 on interface Outside1
I did some research and found a document on Cisco (http://www.cisco.com/en/US/products/ps6120/products_tech_note09186a00807e0aca.shtml), that appears to describe the exact issue I am having, stating that this issue is indicative of a dynamic crypto map entry having a LOWER seq number than a static entry and gives an example of a properley numberes crypto map as follows:
crypto dynamic-map cisco 20 set transform-set myset
crypto map mymap 10 match address 100
crypto map mymap 10 set peer 172.16.77.10
crypto map mymap 10 set transform-set myset
crypto map mymap interface outside
crypto map mymap 60000 ipsec-isakmp dynamic cisco
The IPSec config I added is in Bold, the config not in bold already existed:
crypto ipsec transform-set AES esp-aes-256 esp-sha-hmac
crypto ipsec transform-set Shopper_Trans_Set esp-aes esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map DYN-MAP 5 set transform-set AES
crypto dynamic-map DYN-MAP 5 set security-association lifetime seconds 86400
crypto map VPN 1 match address Outside1_cryptomap
crypto map VPN 1 set peer X.X.X.X
crypto map VPN 1 set transform-set Shopper_Trans_Set
crypto map VPN 60 ipsec-isakmp dynamic DYN-MAP
crypto map VPN interface Outside2
crypto map VPN interface Outside1
crypto isakmp identity address
crypto isakmp policy 10
authentication pre-share
encryption aes
hash sha
group 2
lifetime 28800
crypto isakmp policy 65535
encryption aes-256
hash sha
group 2
lifetime 86400
The sequence numbers seem to follow the rules, so I am confused as to what is wrong.
However I am cocerned that the ASA I am using has two "OUTSIDE" interfaces and am worried the ASA is trying establish through the wrong interface, however my research suggests I would see a message such as:
%ASA-3-713042: IKE Initiator unable to find policy:
Can any one help please !!!!
06-30-2011 05:51 AM
The error message seems to suggest that your crypto ACL does not match the one that Juniper is configured with.
The crypto ACL on the ASA needs to be mirrored image ACL on the Juniper.
Check out the "Outside1_cryptomap" ACl, and make sure that Juniper is configured with the mirror image of that ACL.
From the error message, Juniper seems to be configured with "any to any" ACL for the crypto ACL.
