Help with a simple 1811 configuration
Jun 30th, 2011
I have a very basic level of understanding with Cisco products and I need help with what should be simple and even doable by me.
I have a Cisco 1811 integrated router and am simply trying to use it on my home network.  I can configure the router with an enable secret password, password encryption, VTY, aux, and cons logins with no issues.  The router has 2 Ethernet interfaces, 0 and 1 and 8 switch ports.
The idea is to bring Comcast ISP service into one of the Ethernet ports and then have three machines on the switch ports able to access the Internet.  Also I have an off-the shelf wireless router that I thought I would just plug that into an available switch port and allow a wireless AP as well.
This is so simply, that I can't believe I can't figure it out, but I can't.
I set int F1 to DHCP, performed a 'no shut', and connected the ISP's router and have an up and up indication.  I have setup a static network with my three machines on the switch ports and enabled all applicable ports and have up and up indications - however, no traffic flow, even amongst my static Layer 2 switched LAN - not even a 'ping'.  By my understanding of Layer 2, this should work right now, whether the ISP service is working or not - WHAT AM I DOING WRONG?
The addressing scheme I have ended up on is 172.16.1.0/28
Obviously without the first hurdle cleared, of why the switched LAN doesn’t work, I haven't got any deeper.  Do I need to configure NAT?  I don't think I would need to in the scenario right?
All of my experience, and none at the CCNA level, has been with larger Cisco equipment.  One thing I noticed on the 1811 was that when trying to create a new VLAN, it appears to work yet does not do anything and the 'sh vlans' output returns nothing, not even the VLAN1 I can see with 'sh ip int brief".
Anyway, if anyone has time to help a newbie out I would appreciate it; I’m lost.
Josh
NGnumber62 Fri, 07/01/2011 - 10:53
Thanks for the help Andrew!  You know, I think if this was two separate devices (switch and router) I think I would be up and running, but this integrated stuff is throwing me off, not to mention that the IOS is a much older version (I guess) than what I'm used to.
They were throwing this 1811 in the trash can at work, so I just emptied the trash can.  I have no documentation at all but I have since found the 1800 series documentation on Cisco.com and have tried to implement the basic configurations cited; with what seems like success, but still no joy.  I did have to recover the password and did so with 0x2142, I bypassed the setup and compared the default configuration with what is listed in the documentation and they DO NOT match; I also tried to go through setup mode with the same indications.  Additionally I've also learned that the 1800 series is pre-configured on certain options (DHCP, VLAN), which is new to me - I thought Cisco routers were not configured by default - isn't that kind of the point?  (By the way, the below port status may not be correct since I now have all the ports unplugged)
Anyway, here is the 'show run' command, the 'sh ip int brief' command, followed by the 'sh version' command:
Show Run
Casino#sh run
Building configuration...
Current configuration : 2006 bytes
version 12.4
service password-encryption
hostname Casino
boot-start-marker
boot-end-marker
enable secret 5 $1$meWw$nsMTp6US7axi/uE0MWULK.
enable password 7 06535E741C1B584C55
no aaa new-model
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 172.16.1.1
ip dhcp pool Casino
   import all
   network 172.16.1.0 255.255.255.240
   default-router 67.165.208.1
   dns-server 68.87.89.150
   domain-name hsd1.co.comcast.net
no ip domain lookup
ip domain name GinRummy.localhost
ip name-server 68.87.85.102
ip name-server 68.87.69.150
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
archive
log config
  hidekeys
interface Loopback0
ip address 172.16.1.1 255.255.255.240
interface FastEthernet0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet1
ip address dhcp
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
pppoe enable
pppoe-client dial-pool-number 1
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface FastEthernet9
interface Vlan1
no ip address
ip nat inside
interface Dialer0
ip address negotiated
ip mtu 1492
encapsulation ppp
dialer pool 1
ppp authentication chap
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat pool Casino 172.16.1.2 172.16.1.14 netmask 255.255.255.240
ip nat inside source list 1 interface Dialer0 overload
access-list 1 permit 172.16.1.0 0.0.0.15
dialer-list 1 protocol ip permit
control-plane
line con 0
password 7 080E5916584B4442435E5C
login
line aux 0
password 7 013C135C0A59475A70191E
login
line vty 0 4
password 7 09635B51485756475A5954
login
end
Show IP Interface Brief
Casino#sh ip int brief
Interface                  IP-Address      OK? Method Status                Prl
FastEthernet0              unassigned      YES NVRAM  administratively down do
FastEthernet1              unassigned      YES DHCP   up                    do
BRI0                       unassigned      YES NVRAM  administratively down do
BRI0:1                     unassigned      YES unset  administratively down do
BRI0:2                     unassigned      YES unset  administratively down do
FastEthernet2              unassigned      YES unset  up                    do
FastEthernet3              unassigned      YES unset  up                    do
FastEthernet4              unassigned      YES unset  up                    do
FastEthernet5              unassigned      YES unset  up                    do
FastEthernet6              unassigned      YES unset  up                    do
FastEthernet7              unassigned      YES unset  up                    do
FastEthernet8              unassigned      YES unset  up                    do
FastEthernet9              unassigned      YES unset  up                    up
Vlan1                      unassigned      YES NVRAM  up                    up
Loopback0                  172.16.1.1      YES manual up                    up
Dialer0                    unassigned      YES manual up                    up
NVI0
'show version'
Casino#sh ver
Cisco IOS Software, C181X Software (C181X-ADVIPSERVICESK9-M), Version 12.4(15))
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Thu 24-Jan-08 13:05 by prod_rel_team
ROM: System Bootstrap, Version 12.3(8r)YH12, RELEASE SOFTWARE (fc1)
Casino uptime is 52 minutes
System returned to ROM by reload at 17:09:25 UTC Fri Jul 1 2011
System image file is "flash:c181x-advipservicesk9-mz.124-15.T3.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].[email protected]
Cisco 1812 (MPC8500) processor (revision 0x400) with 118784K/12288K bytes of m.
Processor board ID FHK120622J3, with hardware revision 0000
10 FastEthernet interfaces
1 ISDN Basic Rate interface
31488K bytes of ATA CompactFlash (Read/Write)
Thanks again for your help,
Josh
OK - try the below, do a wr mem to your current config, then try the below...
no int loop0
no int dialer 0
int vlan 1
vpdn enable
vpdn-group 1
request-dialin
protocol pppoe
no ip address dhcp
no ip nat outside
no ip virtual-reassembly
duplex auto
speed auto
pppoe enable
interface Dialer1
description Logical ADSL Interface
ip mtu 1492
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1452
no ip mroute-cache
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname [your username, provided by ISP]
ppp chap password 0 [your username password, given by ISP]
ppp pap sent-username [the username] password 0 [the password]
ppp ipcp route default
ppp ipcp dns request accept
ppp ipcp address accept
ip nat inside source list 1 interface Dialer1 overload
int fa0
switchport access vlan 1
int fa2
int fa3
int fa4
int fa5
int fa6
int fa7
int fa8
int fa9
NGnumber62 Fri, 07/01/2011 - 14:39
Ok thanks Andrew, that seems to be a much better direction; however, it still didn't work.
First, I use Cable Internet from Comcast, not ADSL...I'm not sure that that matters, but I don't know all the PPP authentication information as its' local to the ISP's equipment they installed in my house, however I am digging for that info at this time.
All of the 'ppp ipcp' commands you listed do not work and are not supported by my router.  Also, I found out the hard way also, but Fa0 and Fa1 are the router ports and will not accept switchport access commands; so we can't assign Vlan 1 to Fa0.
Other than those items, I had no issues and it seems to be configured much better now; still doesn't work but we are making some progress.  Before I acquired this router, my configuration was as simple and un-secure as you can imagine, straight from the ISP's equipment to a wireless Cisco M20 with 4 pre-configured ports serving DHCP to every device I needed it to.  I have inspected the wireless routers config and have not come up with any username or password information, only gateways and DNS servers, but I am still looking through all of my paperwork for that information.
Here is the new configuration:
Casino#sh run
Current configuration : 2175 bytes
version 12.4
hostname Casino
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
ip dhcp pool Casino
   import all
no ip domain lookup
ip domain name hsd1.co.comcast.net
vpdn enable
vpdn-group 1
request-dialin
  protocol pppoe
archive
log config
  hidekeys
bba-group pppoe global
no ip address
shutdown
duplex auto
speed auto
no ip address
duplex auto
speed auto
pppoe enable group global
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface Vlan1
ip nat inside
interface Dialer1
description Logical ADSL interface
ip mtu 1492
ip nat outside
encapsulation ppp
no ip mroute-cache
dialer pool 1
dialer-group 1
no ip http server
control-plane
line con 0
login
line aux 0
login
line vty 0 4
login
end
Thanks again for your help, I appreciate it!
Josh
OK - the pppoe config threw me, thought you were adsl etc...
put the below in the router
duplex auto
speed auto
no pppoe enable group global
no pppoe-client dial-pool-number 1
ip address dhcp
shut
no shut
BUT turn off your cable modem for about 5 minutes, put the above config in the cisco router, and power the cable modem backup and see if that works for you.
Related Content
