Remote access ipsec vpn - can't ping past vlan interface
Hi Guys,
I have configured a Cisco 881 with a remote acccess ipsec vpn. The VPN authentication works fine, and connects fine.once connected i can see the route is available, split tunneling is working and i can ping the Vlan interface on the router, however i can't ping past that. i've been looking over all the obvious things like NAT rules and and return routes, everything looks fine. Thers is also a site to site vpn configured that is working fine. Any ideas???
Router#show run
Building configuration...
Current configuration : 4156 bytes
! Last configuration change at 11:46:09 AEST Sun Jul 3 2011 by matt
version 15.0
no service pad
service timestamps log datetime msec localtime show-timezone
service password-encryption
hostname Router
boot-start-marker
boot-end-marker
logging count
logging buffered 16384
enable secret 5 <SNIP>
aaa new-model
aaa authentication login rtr-remote local
aaa authentication login LOCAL local
aaa authorization network rtr-remote local
aaa session-id common
memory-size iomem 10
clock timezone AEST 10
ip source-route
ip cef
no ip bootp server
no ip domain lookup
no ipv6 cef
license udi pid CISCO881-K9 sn FGL150821W4
username <SNIP> password 7 <SNIP>
crypto isakmp policy 1
encr 3des
hash md5
authentication pre-share
group 2
crypto isakmp policy 10
encr 3des
group 2
crypto isakmp key <SNIP> address <SNIP>
crypto isakmp client configuration address-pool local VPN_POOL
crypto isakmp client configuration group VPN_GROUP
key <SNIP>
dns 192.168.1.21 4.2.2.2
domain <SNIP>
pool VPN_POOL
acl 140
crypto ipsec security-association lifetime seconds 86400
crypto ipsec transform-set 3des-sha-hmac esp-3des esp-sha-hmac
crypto ipsec transform-set 3DES-SHA-HMAC esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set vpn1 esp-3des esp-sha-hmac
crypto dynamic-map VPN_MAP 1
set transform-set vpn1
reverse-route
crypto map VPN_MAP client authentication list LOCAL
crypto map VPN_MAP isakmp authorization list rtr-remote
crypto map VPN_MAP client configuration address respond
crypto map VPN_MAP 1 ipsec-isakmp dynamic VPN_MAP
crypto map VPN_MAP 2 ipsec-isakmp
set peer <SNIP>
set transform-set 3des-sha-hmac
set pfs group2
match address 101
crypto map static-map 1 ipsec-isakmp dynamic VPN_MAP
bridge irb
interface FastEthernet0
switchport access vlan 10
spanning-tree portfast
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
ip address <SNIP> 255.255.255.240
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
crypto map VPN_MAP
interface Virtual-Template2 type tunnel
ip unnumbered BVI10
tunnel mode ipsec ipv4
interface Vlan1
no ip address
interface Vlan10
ip nat inside
bridge-group 10
bridge-group 10 spanning-disabled
interface BVI10
no ip address
ip nat inside
shutdown
ip local pool VPN_POOL 192.168.211.1 192.168.211.30
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 110 interface FastEthernet4 overload
ip nat inside source static tcp 192.168.1.21 25 <SNIP> 25 extendable
ip route 0.0.0.0 0.0.0.0 <SNIP>
ip route 192.168.2.0 255.255.255.0 <SNIP>
logging trap warnings
access-list 101 permit ip 192.168.1.0 0.0.0.255 192.168.2.0 0.0.0.255
access-list 101 permit ip 192.168.211.0 0.0.0.255 192.168.2.0 0.0.0.255
access-list 110 deny   ip 192.168.1.0 0.0.0.255 192.168.211.0 0.0.0.255
access-list 110 deny   ip 192.168.2.0 0.0.0.255 192.168.211.0 0.0.0.255
access-list 110 deny   ip 192.168.211.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 110 deny   ip 192.168.211.0 0.0.0.255 192.168.2.0 0.0.0.255
access-list 110 deny   ip 192.168.1.0 0.0.0.255 192.168.2.0 0.0.0.255
access-list 110 permit ip 192.168.1.0 0.0.0.255 any
access-list 140 permit ip 192.168.1.0 0.0.0.255 any
access-list 199 permit ip 192.168.211.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 199 permit ip 192.168.1.0 0.0.0.255 192.168.211.0 0.0.0.255
control-plane
line con 0
exec-timeout 30 0
logging synchronous
login authentication LOCAL
no modem enable
line aux 0
line vty 0 4
exec-timeout 30 0
logging synchronous
scheduler max-task-time 5000
end
Router#
lgijssel Mon, 07/04/2011 - 05:22
  • Red, 2250 points or more
Indeed your config looks fine except for a small remark:
The acl 110 (NAT exemption) is longer than necessary
This would also suffice:
Expl: NAT exemption only needs to be performed for inside address ranges.
Or even shorter:
access-list 110 deny   ip 192.168.0.0 0.0.3.255 192.168.0.0 0.0.255.255
Private ip's are not routed on the Internet so you are not taking risks.
IPsec and NAT are both performed before routing as you can see here:
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080133ddd.shtml
This  is why the static route for 192.168.2.0 can also be omitted. This traffic is matched by acl 110 and 101.
regards,
Leo
regards,
Leo
Leo,
Thanks for your response! I will be configuring the VPN to have access to the site at the other end of the site to site VPN, so this entry will have to remain:
I will go through and make the changes you have suggested, thanks for taking the time to read through!
Matt
Related Content
