Unable to login at Cisco 6509 switch
Answered Question
Jul 4th, 2011
We are unable to login at Cisco 6509 switch, due to username and password not working. We have tried to recover the password as per Cisco document, but that is also not working. This switch is our Primary Switch in our network.Please suggest what to do.
Correct Answer by Latchum Naidu about 5 years 10 months ago
The below link should help you.
http://www.cisco.com/en/US/products/hw/switches/ps708/products_password_recovery09186a00801caa95.shtml
Please click on the correct answer if this answered your question.
Naidu.
Correct Answer by garapoglou about 5 years 10 months ago
Overall Rating: 5 (2 ratings)
Latchum Naidu Tue, 07/05/2011 - 01:05
  • Blue, 1500 points or more
To recover password, it depends on whether you are running CatOS:
http://www.cisco.com/en/US/partner/products/hw/switches/ps708/products_password_recovery09186a00801349aa.shtml
Or Native IOS
http://www.cisco.com/en/US/partner/products/hw/switches/ps700/products_password_recovery09186a0080133fb1.shtml
Naidu.
dipak jaiswal Tue, 07/05/2011 - 01:25
The url is not working. It's giving below mentioned error while opening the url:
Forbidden File or Application
We have tried via ssh and console. The switch has Native IOS.
Thanks in advance for your help.
dipak jaiswal Sun, 08/07/2011 - 13:06
Sorry for the late reply. Thanks a lot for your support. As suggested by you, we are able to recover the password. To recover the password we were using laptop with serial usb converter, but it didn't work. After a lot of searching at online, we found that high end series devices doesn't work properly with usb serial converter. Then we used desktop with com port and we were able to recover the password
Dipak.
Dipak
