ASA 5510 xlate problem
nhelms
I'm having an odd issue with my ASA 5510.  3-5 times a week a number of users will complain they can no longer access the internet, they have local network access but are unable to get past the inside interface of my ASA 5510.  The only way to restore access is to clear xlate on the ASA, and then everyones' connection is immediately back online.  It doesn't impact all users, just a few at any time but it is different users.  My ASA is using 8.2.1.
thanks,  Nick
6 Replies 6
andrew.prince
Level 10
Level 10
What license feature do you have?
Ipsec and a 10 SSL VPN license
thanks, nick
If I remember correct, I guess there is some xlate timeout bug in 8.2 for NAT'd connections (may not be for PAT). Check out the bug tool kit for this IOS Version.
hth
MS
Jay Johnston
Check the output of 'show xlate count' and 'show conn count' to ensure that you aren't hitting the maximum number of allowed connections on the ASA. Issuing a 'clear xlate' would clear any connections associated with a PAT xlate, and therefore mitigate the problem if you are encountering the issue. This problem is most often seen when administrators set the connection timeout to 0:0:0, which causes the total number of connections to slowly grow over time.
Another possibility centers around your ISP blocking certain port ranges of traffic. Do you use an internal DNS server? We've seen a problem that matches your symptoms several times, and it goes like this:
First lets define the issue here, every once in a while, DNS traffic
will fail due to the ISP blocking specific UDP destination ports on
their network. In one case we discovered that RoadRunner will blocks the
following ports on their entire network:
     UPD Destination Port 1026
     UPD Destination Port 1027
     UPD Destination Port 1028
     UPD Destination Port 1029
Because of the way NAT Overloading works (outlined below) there may come
a time when UDP traffic will leave the customer's network with a source
port of 1026-1029. This, because of how IP communications functions,
will cause return traffic to the customer to have a destination port of
1026-1029. These return packets are being filtered out by the ISP.
To get a feel for how NAT overloading works on the firewall, one must
first understand what NAT overloading allows you to do. When you
'overload' and IP address on the Internet, it allows you to have
multiple computer/hosts on your network access the Internet using one
single IP (or a small range of IPs).
The firewall, when translating port for NAT overload, splits the
available ports into three pools:
Low: 0-511
Mid: 512-1023
High: 1024-65535
If a packet inside you network comes into the Firewall destined for the
Internet, and it source port falls into one of those pool, the PIX will
translate it to another port in that pool. When the Firewall first
starts translating addresses, it starts with the lowest port number in
each pool. That means the first UDP packet sourced internally from a
high port will get sent on the Internet with a new source port of 1024.
The next UDP high port translation will go out with a source port of
1025, so on and so forth. This is where the ISP's blocking becomes an
issue...
Since DNS uses UDP, a DNS request will cause the firewall to create a UDP
port translation. When your DNS server happens to get translated to port
1026-1029, you get stuck in this failed position because the translation
never times out.
The reason for the translation not timing out (and getting in this
'stuck' state) is two fold. When a UDP packet going from inside to
outside passes through the firewall, the firewall checks to see if there
already is a translation for that sour IP/port and destination IP/port.
If there is a translation already, the firewall will use that instead of
using up another port and the packet will leave with the already in use
source port.
If there is no translation, then the firewall will build a new
translation and pick the next port in the pool. Since the DNS server is
making requests within the udp timeout range (2 minutes) the UDP
connection never times out on the firewall. If the connection never
times out, then the translation will not timeout either. This factor is
compounded by the behavior of the Windows DNS service. Because the DNS
service, by design, sends out using the same UDP source port to the same
destination IP (ISP DNS Server) and destination port (53) for every
query (does not change until the DNS service is restarted) the
translation is re-used over and over again until both the UDP and
tranlsation timers expire.
To fix this issue, you can force a Windows DNS server Service to use a
pre-specified source port. By forcing the source port to a low number
(0-511) the port will leave the Firewall in that range of low ports. It
will then not hit the issue where you send out on 1026-1029 and the ISP
blocks the return DNS answer.
Why does this happen to some networks and not others? Well it hinges on
whether or not the DNS server just do happens to get that UDP port as it
leaves the firewall. If when the firewall boots up, there may be be some
UDP traffic that takes up those ports before the server starts making
traffic over the Internet.
If you have very little UDP traffic, you might hit the issue because the
server eventually hits those ports. If you have a lot of UDP traffic you
might hit the issue because you use all the UDP port (up to 65535) and
wrap back around to 1026-9.
To test if this is the problem you're facing, issue 'show xlate debug' (or 'show xlate' in ver 8.3+) and look for the translations that your internal DNS server is using, and take a note of the global port that the DNS connection is translated to by the firewall. You can then apply a capture to the outside interface of the firewall to watch traffic sourced from that port, and verify if responses are coming back (
https://supportforums.cisco.com/docs/DOC-1222,
https://supportforums.cisco.com/docs/DOC-12632).
You then clear that xlate selectively on the ASA and see if the problem is mitigated ('clear xlate port x'). That will confirm if you are hitting this issue or not.
If you are hitting this issue, then you can specify a bogus port translation in the configuration that should "use up" the port that the ISP blocks, and therefore mitigate the problem from occurring again. In the below example, UDP port 1026 is reserved, and won't be used for dynamic PAT xlate allocation...we use a bogus inside ip of 10.123.123.123 to ensure that the ASA won't use this xlate with an actual connection built throught the firewall:
static (outside,inside) udp interface 1026 10.123.123.123 12345 netmask 255.255.255.255
nat (inside) 1 0.0.0.0 0.0.0.0
global (outside) 1 interface
Hey Jay,
When I issue a sh xlate count I get 57 current, 72 max connections.  When I issue the show connect count I get 638 current, 1357 maximum connections.  I checked and the timeout for xlate and connect are the defaults, should they be adjusted?  We typically have 10 remote VPN users and 35-40 internal network users connected during the day.
thanks, nick
Nick,
     Don't adjust the timeout settings; the 'show conn count' proves that the ASA isn't hitting the maximum supported connections, so this can't be your problem.
I suggest you run through the troubleshooting steps I suggested above if the problem occurs again.
Sincerely,
     Jay
