ICM v8.5 Upgrade Locked DLLs
Jul 8th, 2011
I'm trying to upgrade one of my lab ICMs from 8.0.1 to 8.5, and the upgrade fails each time complaining of a running executable.  The install log shows the following DLLs locked:
Locked file: C:\icm\bin\CampaignManagerPerf.dll
Locked file: C:\icm\bin\CTISVRPerfmonObjectDLL.dll
Locked file: C:\icm\bin\DialerPerf.dll
Locked file: C:\icm\bin\EapimPerfCounters.dll
Locked file: C:\icm\bin\ImportPerf.dll
Locked file: C:\icm\bin\LoggerPerf.dll
Locked file: C:\icm\bin\OPCPerfmonObjectDLL.dll
Locked file: C:\icm\bin\RealTimePerf.dll
Locked file: C:\icm\bin\VRUPIMPerfCounterDLL.dll
Found a similar thread here which indicated that the SNMP service was the culprit, but in my case, all efforts to start/stop/manual/disable the SNMP service have no effect on the error.  Is there any other service that can lock these DLLs?  There is no third party software on this box, and I ran an identical upgrade on it's paired server which ran flawlessly.  Attached is a screenshot of all active services on the problem host.
Amer rajai Sha'er Sat, 07/09/2011 - 03:44
I had a problem not exactly like this but similar when i tried to upgrade from ICM 8.0(1) to 8.0(3) on AgentPG , as i understand from cisco it is a defect , when you manually stop all services , there is a service never stops and it has to be manually stopped from the task manager , this service is called tomcat6 , please give it a try .
Amer
anubhati Sun, 07/10/2011 - 06:17
As Amer mentioned there is a defect were patch manager fails to stop the following services
Cisco Contact Center SNMP Management
Cisco ICM Diagnostic Framework
Cisco Performance and Scalability Monitor
Make sure these are stopped alos if you have any third party monitoring software on the serveres please stop those services as well.
Hope this helps
Anuj
kpstross Mon, 07/11/2011 - 14:31
Aside from SQL, there is no other third party software left on this system.  I have tried disabling all of the Cisco services completely, and rebooting (and killing Tomcat6 as mentioned above), and the upgrade still fails with the same error.
Amer rajai Sha'er Mon, 07/11/2011 - 14:34
Since this is lab , can you please try to upgrade to ICM 8.0.3 , is it also giving the same error or not ?
Just to be clear , the tomcat6 will run twice on the processes , when you stop all the service from the service control , you need to kill the tomcat6 then start the upgrade , give it a shot with the ICM 8.0.3 and let's see how things will go.
Amer
kpstross Tue, 07/12/2011 - 06:38
It's the same with 8.0.3.  All Cisco services are disabled, tomcat6 is shut down in Services and killed in Task Manager, but the installation fails with a complaint about the same locked DLLs.  The log shows everything is shutdown, so no indication of what might be causing this to hang.
kpstross Thu, 10/13/2011 - 08:31
It was finally determined to be VMWareService.exe that was locking the DLLs.
shirpati Fri, 10/14/2011 - 09:57
You can also use the process explorer, to find out which process is blocking that dll,
For your reference below the link to download
http://technet.microsoft.com/en-us/sysinternals/bb896653.aspx
Once you install it in the menu options click find Find handle or Dll enter the dll name
and search it will show you what process is using that dll kill the process and run the
install.
Isidro Fernandez Thu, 01/17/2013 - 01:32
In my case, process wmiprvse.exe was locking this files (W2K8). Stopping Windows Management Instrumentation fixed the issue
Saludos!
Isidro
Oleh Doroshenko Mon, 07/22/2013 - 04:55
Hi all. Unlock files that show up in the install log. Finding blocking process is easy by means some unlocking utility (lockhunter.com). than stop all processes and everything will be ok.
