Cisco 1941 Router Issue.....
Jul 10th, 2011
Dear Experts!!!!
I configured cisco 1941 router for Normal NATing and Its working fine. All my internal users are getting internet,
But here the issue is, my client using Polycom video conferencing solution. They installed these solution in  different branches.
My client able to connect the Other site video conferecing device using public IP but he is unable to get the Video streaming.
But if i directly connect to the ISP line to the Polycom device, he able to get the video streaming.
But if i use another router cisco WRT161N, he able to get the video streaming.
Onle issue is if i using 1941 router, video streaming is not coming.
Janardhan
sylvain.munaut Mon, 07/11/2011 - 00:29
You're probably missing some deep inspection rule in your config ... What protocol does that device use for video streaming ? Make sure it's configured on the router.
( a dump of the config would be useful )
Janardhan Meesala Mon, 02/27/2012 - 02:56
Thanks for your reply... My polycom device will use H.323 protocol..
And i am attaching my config for your reference.
s runn
Building configuration...
Current configuration : 1618 bytes
version 15.1
hostname Apollo_Conf
boot-start-marker
boot-end-marker
enable secret 5 $1$F0Ei$xrftyfKezoJ7WIgxoaubK/
enable password cisco
no aaa new-model
no ipv6 cef
ip source-route
ip cef
--More--                           !
--More--                           !
--More--                           ip dhcp excluded-address 192.168.10.1 192.168.10.200
ip dhcp pool list_of_dhcp_ips
   network 192.168.10.0 255.255.255.0
   dns-server 202.153.32.2 202.153.32.3
   default-router 202.153.37.233
ip name-server 202.153.32.2
ip name-server 202.153.32.3
vpdn enable
vpdn-group 1
license udi pid CISCO1941/K9 sn FGL1519202N
--More--                           !
interface GigabitEthernet0/0
ip address 192.168.10.200 255.255.255.0
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
ip address X.X.X.X 255.255.255.248
ip nat outside
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
--More--                           !
ip nat pool list_of_public_ips X.X.X.X X.X.X.X netmask 255.255.255.248
ip nat inside source list 101 pool list_of_public_ips overload
ip nat inside source list 110 pool list_of_public_ips overload
ip nat inside source static 192.168.10.202 202.153.37.235
ip route 0.0.0.0 0.0.0.0 X.X.X.X
access-list 101 permit ip any any
access-list 110 permit ip any any
control-plane
line con 0
line aux 0
line vty 0 4
password cisco
login
transport input all
--More--                           !
scheduler allocate 20000 1000
end
Apollo_Conf# sh ip int br
Apollo_Conf# sh ip int brief
Interface                  IP-Address      OK? Method Status                Protocol
GigabitEthernet0/0         192.168.10.200  YES NVRAM  up                    up
GigabitEthernet0/1         X.X.X.X YES NVRAM  down                  down
NVI0                       192.168.10.200  YES unset  up                    up
Apollo_Conf#sh ver
Cisco IOS Software, C1900 Software (C1900-UNIVERSALK9-M), Version 15.1(3)T1, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Sun 27-Mar-11 05:55 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M9, RELEASE SOFTWARE (fc1)
Apollo_Conf uptime is 1 minute
System image file is "flash0:c1900-universalk9-mz.SPA.151-3.T1.bin"
Last reload type: Normal Reload
--More--                           A summary of U.S. laws governing Cisco cryptographic products may be found at:
--More--                           http://www.cisco.com/wwl/export/crypto/tool/stqrg.html
--More--
--More--                           If you require further assistance please contact us by sending email to
--More--                           [email protected].
--More--
--More--                           Cisco CISCO1941/K9 (revision 1.0) with 491520K/32768K bytes of memory.
--More--                           Processor board ID FGL1519202N
--More--                           2 Gigabit Ethernet interfaces
--More--                           DRAM configuration is 64 bits wide with parity disabled.
--More--                           255K bytes of non-volatile configuration memory.
--More--                           254464K bytes of ATA System CompactFlash 0 (Read/Write)
--More--
--More--
--More--                           License Info:
--More--
--More--                           License UDI:
--More--
--More--                           -------------------------------------------------
--More--                           Device#            PID                              SN
--More--                           *0              CISCO1941/K9          FGL1519202N
--More--
--More--
--More--
--More--                           Technology Package License Information for Module:'c1900'
--More--
--More--                           ----------------------------------------------------------------
--More--                           Technology    Technology-package          Technology-package
--More--                                         Current       Type          Next reboot
--More--                           -----------------------------------------------------------------
--More--                           ipbase        ipbasek9      Permanent     ipbasek9
security      None          None          None
data          None          None          None
Apollo_Conf#    sh fla
Apollo_Conf#sh flash ?
  all      show all possible flash info
  filesys  Show file system information
  |        Output modifiers
-#- --length-- -----date/time------ path
1     50172808 Jul 14 2011 12:00:32 +00:00 c1900-universalk9-mz.SPA.151-3.T1.bin
2         2903 May 3 2011 03:41:54 +00:00 cpconfig-19xx.cfg
3      2941440 May 3 2011 03:42:08 +00:00 cpexpress.tar
4         1038 May 3 2011 03:42:16 +00:00 home.shtml
5       115712 May 3 2011 03:42:24 +00:00 home.tar
6      1697952 May 3 2011 03:42:38 +00:00 securedesktop-ios-3.1.1.45-k9.pkg
7       415956 May 3 2011 03:42:50 +00:00 sslclient-win-1.1.4.176.pkg
8     43745284 Jul 14 2011 11:22:14 +00:00 c1900-universalk9_npe-mz.SPA.150-1.M6.bin
161038336 bytes available (99115008 bytes used)
With Regards,
Janardhan
