Help - Voice Lab Setup - No Commn between Router Switch
Answered Question
Jul 12th, 2011
Hi Networkers !!!
I have been trying to set up a basic voice lab with 2621XM and 3524XL (WS-C3524-PWR-XL). I am not able get the switch and  router talk to each other. I am sure that this is something to do with  VLAN and Subinterface Configuration but I can't get it working. Please  find the configuration of 2621 as follows. I sincerely thank you for  your valuable time and support.
VOICE_GATEWAY#show run
Building configuration...
Current configuration : 1819 bytes
version 12.4
hostname VOICE_GATEWAY
boot-start-marker
boot-end-marker
no aaa new-model
no network-clock-participate slot 1
no network-clock-participate wic 0
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 172.16.1.1 172.16.1.10
ip dhcp excluded-address 172.16.2.1 172.16.2.10
ip dhcp pool VOICE
   network 172.16.1.0 255.255.255.0
   default-router 172.16.1.1
   dns-server 4.2.2.2
   option 150 ip 172.16.1.1
no ip domain lookup
ip host SW1 172.16.3.2
vlan internal allocation policy ascending
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.1
encapsulation dot1Q 1 native
ip address 172.16.3.1 255.255.255.0
interface FastEthernet0/0.10
encapsulation dot1Q 10
ip address 172.16.1.1 255.255.255.0
interface Serial0/0
no ip address
shutdown
no fair-queue
router eigrp 109
network 172.16.0.0
auto-summary
ip http server
no ip http secure-server
control-plane
voice-port 1/0/0
voice-port 1/0/1
telephony-service
max-ephones 10
max-dn 10
ip source-address 172.16.1.1 port 2000
auto assign 1 to 5
auto assign 1 to 5 type 7940
max-conferences 4 gain -6
transfer-system full-consult
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn 1 dual-line
number 1001
name Jason
ephone-dn 2 dual-line
number 1002
name Jensy
ephone 1
mac-address 0017.9538.84D9
type 7940
button 1:1
ephone 2
mac-address 0013.C44A.7CC0
type 7940
button 2:2
line con 0
password cisco
login
line aux 0
line vty 0 4
password cisco
login
end
VOICE_GATEWAY#
The Switch Configuration is as follows :
SW_3524>en
SW_3524#show run
Current configuration:
version 12.0
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname SW_3524
ip subnet-zero
no ip domain-lookup
ip dhcp-server 172.16.1.1
interface FastEthernet0/1
description UPTLINK to ROUTER
switchport trunk allowed vlan 1,10,50,1002-1005
switchport mode trunk
switchport voice vlan 10
switchport priority extend cos 0
spanning-tree portfast
interface FastEthernet0/2
interface FastEthernet0/3
switchport voice vlan dot1p
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
switchport access vlan 50
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface VLAN1
ip address 172.16.3.2 255.255.255.0
no ip directed-broadcast
no ip route-cache
shutdown
interface VLAN10
no ip route-cache
interface VLAN50
no ip route-cache
shutdown
ip default-gateway 172.16.3.1
line con 0
transport input none
stopbits 1
line vty 0 4
login
line vty 5 15
login
end
SW_3524#
Correct Answer by ADAM CRISP about 5 years 8 months ago
The problem is either ccme related or switch related. To rule out the switch, do a show mac address table and see if you can see the phone in vlan 10.
If you can't then remember that nowadays we expect the switchport voice vlan command to do do two things
1, change CDP announcements so that cisco phones pick up that they should be using that vlan and
2, enable forwarding of tagged packets in that vlan on the switchport.
You XL switch is of the ISL era so i would be tempted to change fast 0/3 to dot1q trunking
Ie
int fast 0/3
Switchport encap dot1q
Switchport mode trunk
Sw voice vlan 10 you already have
Ask the phone what ip address it has and what the call server is...
If phone appears in show mac-address table then look to the ccme router
Check tftp configuration, ping the phone etc.
Sorry about any typos - on iPhone.... Adam
this is a really old XL switch - I reckon the 'management'  command will sort it.
Also given that fa0/1 is a trunk, vlan 1 will come up so long as it's the active management vlan
Overall Rating: 0 (3 ratings)
ADAM CRISP Tue, 07/12/2011 - 13:19
  • Silver, 250 points or more
Vlan 10's probably working, but If you want to ping between the router and switch on vlan 1 then:
1. on the router
change
no ip address
duplex auto
speed auto
to
no interface FastEthernet0/0.1
and on the switch
conf t
int vlan 1
management
no shut
Adam
ADAM CRISP Tue, 07/12/2011 - 13:20
also - on the switch make sure you have vlan 10 defined in the database
from enable mode
show vlan
-  see if you have a vlan 10... if not
vlan database
vlan 10
name myvoicevlan
exit
Brian Meade Tue, 07/12/2011 - 13:40
interface VLAN1
no shutdown
Also, you must have a host in VLAN1 for the line protocol to come up.  Then try again.
Correct Answer
ADAM CRISP Tue, 07/12/2011 - 13:43
svictoryshanmugam Tue, 07/12/2011 - 15:05
Hi Adam, Thank you for the quick and helpful response. I did make the  management change in the switch and now the switch and router are  connected and I can ping & telnet to both of them back and forth. But when I connect the IP Phone after configuring the VLAN,  it just stays at the place -- Configuring IP....  Please take a look at  my vlan configuration. When I do the "Show vlan bri" the fa0/3 where I have connected my IP Phone is not listed in the Voice Vlan 10.  My dhcp pool configuration in the Router is the same as above in my first post.  Many Thanks
ip subnet-zero
no ip domain-lookup
SW_3524#show vlan bri
VLAN Name                             Status   Ports
1   default                         active   Fa0/2, Fa0/3, Fa0/4, Fa0/5,
                                               Fa0/6, Fa0/8, Fa0/9, Fa0/10,
                                               Fa0/11, Fa0/12, Fa0/13, Fa0/14,
                                                Fa0/15, Fa0/16, Fa0/17, Fa0/18,
                                               Fa0/19, Fa0/20, Fa0/21, Fa0/22,
                                               Fa0/23, Fa0/24, Gi0/1, Gi0/2
10   VOICE                           active
50   DATA                             active   Fa0/7
1002 fddi-default                     active
1003 token-ring-default               active
1004 fddinet-default                 active
1005 trnet-default                   active
Correct Answer
ADAM CRISP Tue, 07/12/2011 - 15:26
Ie
int fast 0/3
svictoryshanmugam Tue, 07/12/2011 - 16:02
Adam, You are the Man...Enabling dot1q on the ip phone ports has resolved the issue... I sincerely thank you for the great help !!!!
svictoryshanmugam Wed, 07/13/2011 - 12:43
I am trying to hook up my Desktop into the switch and I did connect the desktop in fa0/7 and placed it in Access Vlan 50. The Desktop does get the IP address 172.16.2.11 from the dhcp-server 172.16.1.1 as seen below but the desktop is not pingable from the Router. I can do a ping to the router(172.16.2.1) from the desktop.  I did do a show ip dhcp binding and can see the two ip phones and one desktop having got ip address from the dhcp server. I can ping the the IP phones ip address but not the desktop ip address. Please help me. Thank You.
Ethernet adapter Local Area Connection 3:
        Connection-specific DNS Suffix  . :
        Description . . . . . . . . . . . : VIA Rhine III Fast Ethernet Adapter
        Physical Address. . . . . . . . . : 00-0C-76-69-49-8A
        Dhcp Enabled. . . . . . . . . . . : Yes
        Autoconfiguration Enabled . . . . : Yes
        IP Address. . . . . . . . . . . . : 172.16.2.11
        Subnet Mask . . . . . . . . . . . : 255.255.255.0
        Default Gateway . . . . . . . . . :
        DHCP Server . . . . . . . . . . . : 172.16.2.1
SW_3524#show mac
SW_3524#show mac-address-table
Dynamic Address Count:                 7
Secure Address Count:                  0
Static Address (User-defined) Count:   0
System Self Address Count:             51
Total MAC addresses:                   58
Maximum MAC addresses:                 8192
Non-static Address Table:
Destination Address  Address Type  VLAN  Destination Port
000c.30c9.d3c0       Dynamic          1  FastEthernet0/1
000c.30c9.d3c0       Dynamic         10  FastEthernet0/1
000c.30c9.d3c0       Dynamic         50  FastEthernet0/1
0013.c44a.7cc0       Dynamic          1  FastEthernet0/3
0013.c44a.7cc0       Dynamic         10  FastEthernet0/3
0017.9538.84d9       Dynamic          1  FastEthernet0/5
0017.9538.84d9       Dynamic         10  FastEthernet0/5
out put from show run in SW_3524
VOICE_GATEWAY#show ip dhcp binding
Bindings from all pools not associated with VRF:
IP address          Client-ID/              Lease expiration        Type
                    Hardware address/
                    User name
172.16.1.11         0100.13c4.4a7c.c0       Mar 02 2002 12:01 AM    Automatic
172.16.1.12         0100.1795.3884.d9       Mar 02 2002 12:01 AM    Automatic
172.16.2.11         0100.0c76.6949.8a       Mar 02 2002 12:03 AM    Automatic
VOICE_GATEWAY#ping 172.16.2.11
Sending 5, 100-byte ICMP Echos to 172.16.2.11, timeout is 2 seconds:
Success rate is 0 percent (0/5)
ADAM CRISP Wed, 07/13/2011 - 14:02
I am sure everything is fine with the network. Most likely you have a firewall installed on your pc which is blocking the ping.
svictoryshanmugam Wed, 07/13/2011 - 14:39
HI Adam, Thanks Again for coming to rescue ! That is perfectly correct. And I added the exception in Windows Firewall options to allow incoming router request for the Ethernet adpater which is connected to the switch and I am able to ping from both sides.  Should I run any routing protocols in the router to be able to reach other networks 172.16.1.0  and 172.16.3.0  from 172.16.2.0 (Data Vlan where the desktop resides).
Because I can ping the router 172.16.2.1 from the Desktop (172.16.2.11) but not 172.16.1.1 (the voice vlan network).
Thanks mate !
