Having trouble matching Old PIX and new ASA configs
Answered Question
Jul 15th, 2011
Hi, I've recently upgraded my old firewall from a PIX to an ASA5505 and have been trying to match up the configuration settings to no avail.
First problem I have is that I can't ping the new firewall on it's inside interface, despite having "icmp permit any inside" in the running config.
Secondly, the server I have on there ("Sar") can't connect out to the internet.
I've included the ASA's running config incase anybody can see if something stands out. I have a feeling it's either not letting anything onto the inside interface, or there is no nat going on.
Lastly (and possibly relevant), the firewall is actually going at the end of a vlan, which is different to the firewall's inside vlan number. I don't know if this is actually the problem because the server can't connect out even if connected directly into the firewall.
Cheers,
Correct Answer by varrao about 5 years 10 months ago
Great!!!! , yes it is an access-list issue.
we need to have  the following access-list:
access-list outside_access_in extended permit tcp any object Sar eq 3389
we would need to use the real ip of the server and not public ip, in version 8.3 or above.
This shoudl definitely resolve the issue for you.
Hope this helps,
Varun
Overall Rating: 4.5 (13 ratings)
varrao Fri, 07/15/2011 - 05:06
  • Red, 2250 points or more
Hi Wez,
Just reload the upstream and downstream devices, connected to the ASA, to clear out their arp cache tables. That should help, if still issue persists, kindly post
Varun
Adam Makovecz Fri, 07/15/2011 - 05:06
  • Bronze, 100 points or more
hi,
if you replaced the firewall, the MAC address has been change. You need to clear the arp entries for the other devices to learn the new MAC address.
Also you can confirm by the packet capture that the packet reaches the ASA or not.
Packet capturing an firewalls: https://supportforums.cisco.com/docs/DOC-17345
kind regards
Adam
KingPrawns Fri, 07/15/2011 - 05:55
What do you mean by reload the devices? Would power cycling them work? The firewall connects to a managed modem provided by my ISP, I don't have access to it's configuration directly.
I've managed to get the server to ping the firewall now (wrong subnet) but still can't connect out to the internet.
varrao Fri, 07/15/2011 - 05:57
Yes, a power cycle would work fine.
Varun
KingPrawns Fri, 07/15/2011 - 06:38
Power cycled the router that the ASA connects into with no luck. Haven't restarted my server though, but I don't think that'd be the problem.
Out of interest, If I wanted to check that the firewall has connectivity, could I ping a server outside my network like google.com?
KingPrawns Fri, 07/15/2011 - 07:02
Following the capture instructions now, got a question about it though.
It says to set up access list for 10.10.10.1 as the client IP. Is that an external server like 4.2.2.2 or the ip of the router/firewall?
KingPrawns Fri, 07/15/2011 - 06:45
bt# sho run
: Saved
ASA Version 8.4(1)
hostname bt
domain-name mcserv.co.uk
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Vlan1
nameif inside
security-level 100
ip address 10.20.3.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address xxx.xxx.9.130 255.255.255.192
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
ftp mode passive
dns server-group DefaultDNS
object network obj_any
subnet 0.0.0.0 0.0.0.0
object network Sar
host 10.20.3.151
object network Sar_Outside
host xxx.xxx.9.151
object-group network WebServers
network-object object Sar_Outside
object-group service WebsiteTraffic
description Website required services
service-object tcp destination eq www
service-object tcp destination eq https
service-object tcp destination eq smtp
access-list outside_access_in extended permit tcp any object Sar_Outside eq 3389
access-list outside_access_in extended permit object-group WebsiteTraffic any object-group WebServers
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
nat (inside,outside) dynamic interface
object network Sar
nat (inside,outside) static Sar_Outside
access-group outside_access_in in interface outside
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.1.0 255.255.255.0 inside
http 10.20.3.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
class-map global-class
match default-inspection-traffic
policy-map type inspect dns dns-map
parameters
  message-length maximum client 512
  message-length maximum 512
policy-map global-policy
class global-class
  inspect dns dns-map
  inspect ftp
  inspect icmp
  inspect icmp error
  inspect http
  inspect rtsp
  inspect rsh
  inspect sip
  inspect skinny
  inspect sqlnet
  inspect tftp
service-policy global-policy global
prompt hostname context
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email [email protected]
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:2b24cf92dd709b0721cd29819d300c39
: end
Here is the current running config for those who don't want to have to dl the attachment
Adam Makovecz Fri, 07/15/2011 - 06:47
yes, but you have to allow the icmp  on the outside interface's ACL
varrao Fri, 07/15/2011 - 06:48
Please take captures on the firewall as suggested by Adam, try pinging 4.2.2.2, from the server machine, check in the captures whether the packets are reaching the firewall and being forwarded to the router.
Varun
varrao Fri, 07/15/2011 - 07:29
Hi Wez,
access-list cap permit ip host 10.20.3.151 host 4.2.2.2
access-list cap permit ip host 4.2.2.2 host 10.20.3.151
access-list cap permit ip host  host 4.2.2.2 host xxx.xxx.9.151
access-list cap permit ip host host xxx.xxx.9.151 host 4.2.2.2
capture capin access-list cap interface inside
capture capo access-list cap interface outside
Try pinging from the servers to 4.2.2.2, and then do show cap capin and show cap capo.
Make sure you permit the ping return traffic by adding an acl on the outside interafce as mentioned by Adam.
Varun
KingPrawns Fri, 07/15/2011 - 07:52
bt# show cap capin
2 packets captured
   1: 07:41:13.446510 802.1Q vlan#1 P0 10.20.3.151 > 4.2.2.2: icmp: echo request
   2: 07:41:16.518772 802.1Q vlan#1 P0 10.20.3.151 > 4.2.2.2: icmp: echo request
2 packets shown
bt# show cap capo
0 packet captured
0 packet shown
So the packets aren't getting through the outside interface? I've added "icmp permit any outside" so I don't think I'm rejecting anything.
varrao Fri, 07/15/2011 - 10:21
Hi Wez,
You are missing a route in here:
the route should be added like this:
route outside 0.0.0.0 0.0.0.0 1
Hope this helps,
Varun
KingPrawns Sat, 07/16/2011 - 02:19
That would make sense, but how do I work out the next hop? All the firewall is doing is swapping inside traffic for outside.
Unless you mean the router connected to the outside interface (xxx.xxx.9.129), in which case is it something like:
route outside 0.0.0.0 0.0.0.0 xxx.xxx.9.129 1
varrao Sat, 07/16/2011 - 02:25
Hi Wez,
Absolutely, thats wat I meant,:
Go ahead and let me know if this works out for us.
Varun
KingPrawns Sun, 07/17/2011 - 05:41
I've added in the route and still not getting anything from the outside packet capture. The router on xxx.xxx.9.129 responds to ping from the firewall, so in theory I should be able to ping it from the server too?
Here is the current config:
bt# sho run
: Saved
ASA Version 8.4(1)
hostname bt
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ftp mode passive
object network Sar
host 10.20.3.151
host xxx.xxx.9.151
access-list cap extended permit ip host 10.20.3.151 host 4.2.2.2
access-list cap extended permit ip host 4.2.2.2 host 10.20.3.151
access-list cap extended permit ip host 4.2.2.2 host xxx.xxx.9.151
access-list cap extended permit ip host xxx.xxx.9.151 host 4.2.2.2
pager lines 24
mtu inside 1500
mtu outside 1500
arp timeout 14400
object network Sar
http server enable
telnet timeout 5
ssh timeout 5
console timeout 0
webvpn
parameters
class global-class
  inspect dns dns-map
  inspect ftp
  inspect icmp
  inspect icmp error
  inspect http
  inspect rtsp
  inspect rsh
  inspect sip
  inspect skinny
  inspect sqlnet
  inspect tftp
call-home
profile CiscoTAC-1
  no active
Cryptochecksum:f36d6cfcf9791d95e642ae7c4289ed05
: end
varrao Sun, 07/17/2011 - 06:27
Hi Wez,
Now that we have the route in place, can you take the captures again, to see if the packets are getting to the outside interface, unlike earlier.
and also plz provide the complete output of :
packet-tracer input inside tcp 10.20.3.151 2345 1.1.1.1 80 detailed.
Varun
KingPrawns Sun, 07/17/2011 - 10:42
Ok, we have progress!
I can now access the internet (www.google.com) from the server, however I can't seem to RDP to it or connect to any of the websites. I'm guessing these are access control issues?
Btw, Here is the output of the packet-tacer and capture:
Phase: 1
Type: CAPTURE
Subtype:
Result: ALLOW
Config:
Additional Information:
Forward Flow based lookup yields rule:
in  id=0xca88f500, priority=13, domain=capture, deny=false
        hits=1779, user_data=0xca88f400, cs_id=0x0, l3_type=0x0
        src mac=0000.0000.0000, mask=0000.0000.0000
        dst mac=0000.0000.0000, mask=0000.0000.0000
        input_ifc=inside, output_ifc=any
Phase: 2
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
in  id=0xcabe35b8, priority=1, domain=permit, deny=false
        hits=1631, user_data=0x0, cs_id=0x0, l3_type=0x8
        dst mac=0000.0000.0000, mask=0100.0000.0000
Phase: 3
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   0.0.0.0         0.0.0.0         outside
Phase: 4
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
in  id=0xcabe5db0, priority=0, domain=inspect-ip-options, deny=true
        hits=60, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
        src ip/id=0.0.0.0, mask=0.0.0.0, port=0
        dst ip/id=0.0.0.0, mask=0.0.0.0, port=0, dscp=0x0
Phase: 5
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
class global-class
  inspect http
in  id=0xcb225d98, priority=70, domain=inspect-http, deny=false
        hits=2, user_data=0xcb225b90, cs_id=0x0, use_real_addr, flags=0x0, protocol=6
        dst ip/id=0.0.0.0, mask=0.0.0.0, port=80, dscp=0x0
Phase: 6
Type: NAT
Subtype:
Result: ALLOW
Config:
object network Sar
Static translate 10.20.3.151/2345 to xxx.xxx.9.151/2345
in  id=0xcabc7510, priority=6, domain=nat, deny=false
        hits=53, user_data=0xcabc8c40, cs_id=0x0, use_real_addr, flags=0x0, protocol=0
        src ip/id=10.20.3.151, mask=255.255.255.255, port=0
        input_ifc=inside, output_ifc=outside
Phase: 7
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Reverse Flow based lookup yields rule:
in  id=0xcac54358, priority=0, domain=inspect-ip-options, deny=true
        hits=58, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
        input_ifc=outside, output_ifc=any
Phase: 8
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 66, packet dispatched to next module
Module information for forward flow ...
snp_fp_tracer_drop
snp_fp_inspect_ip_options
snp_fp_tcp_normalizer
snp_fp_inspect_http
snp_fp_translate
snp_fp_adjacency
snp_fp_fragment
snp_ifc_stat
Module information for reverse flow ...
snp_fp_tracer_drop
snp_fp_translate
snp_fp_inspect_http
snp_fp_adjacency
snp_fp_fragment
snp_ifc_stat
Result:
input-interface: inside
input-status: up
input-line-status: up
output-interface: outside
output-status: up
output-line-status: up
Action: allow
bt(config)# sho cap capo
8 packets captured
   1: 05:27:07.728493 802.1Q vlan#2 P0 xxx.xxx.9.151 > 4.2.2.2: icmp: echo request
   2: 05:27:12.494252 802.1Q vlan#2 P0 xxx.xxx.9.151 > 4.2.2.2: icmp: echo request
   3: 05:28:08.333967 802.1Q vlan#2 P0 xxx.xxx.9.151 > 4.2.2.2: icmp: echo request
   4: 05:28:13.226382 802.1Q vlan#2 P0 xxx.xxx.9.151 > 4.2.2.2: icmp: echo request
   5: 10:24:25.168204 802.1Q vlan#2 P0 xxx.xxx.9.151 > 4.2.2.2: icmp: echo request
   6: 10:24:30.242358 802.1Q vlan#2 P0 xxx.xxx.9.151 > 4.2.2.2: icmp: echo request
   7: 10:24:34.874359 802.1Q vlan#2 P0 xxx.xxx.9.151 > 4.2.2.2: icmp: echo request
   8: 10:24:39.506443 802.1Q vlan#2 P0 xxx.xxx.9.151 > 4.2.2.2: icmp: echo request
8 packets shown
Correct Answer
varrao Sun, 07/17/2011 - 10:51
Hope this helps,
Varun
KingPrawns Sun, 07/17/2011 - 10:54
Awesome, that's got me into RDP now. I'm guessing I need to do the same thing to allow port 80 traffic in too?
Edit, got it, just changed the port number after eq.
Thanks for everything, you've been a godsend. If you're ever in town, beers are on me!
varrao Sun, 07/17/2011 - 10:58
Absolutely, happy it resolved the issue for you
-Varun
varrao Sun, 07/17/2011 - 11:08
Thanks a lot Wez for your ratings.....all the best and take care
-Varun
KingPrawns Thu, 09/22/2011 - 04:41
Hey, sorry to dig up an old thread but I'm having a similar problem when moving a new server to this vlan/subnet.
Weirdly I can ping anything on the internet from the server (call it 10.20.3.148 or Dev1 ) but when I try access the internet, it fails. Something is stopping port 80 traffic
The following packet trace shows that all traffic is allowed:
     packet-tracer input inside tcp 10.20.3.148 2345 1.1.1.1 80 detailed
Results:
     input-status: up
     output-status: up
     Action: allow
Here are my rules, I tried to copy the existing server (Sar) but with no success
bt(config)# sho run access-list
access-list outside_access_in extended permit tcp any host xxx.xxx.9.151 object-group RemoteDesktop
access-list outside_access_in extended permit tcp any object Sar eq www
access-list outside_access_in extended permit tcp any object Sar eq https
access-list outside_access_in extended permit tcp any object Sar eq ftp-data
access-list outside_access_in extended permit tcp any object Sar eq 1433
access-list outside_access_in extended permit tcp any object Dev1 eq www
access-list outside_access_in extended permit tcp any object Dev1_Outside eq www
bt(config)# sho run object-group
network-object object Dev1_Outside
object-group service RemoteDesktop tcp
port-object range 3389 3389
bt(config)# sho run nat
object network Sar
object network Dev1
nat (inside,outside) static Dev1_Outside
object network Sar
host 10.20.3.151
host xxx.xxx.9.151
object network Dev1
host 10.20.3.148
object network Dev1_Outside
host xxx.xxx.9.148
varrao Thu, 09/22/2011 - 04:45
Hi Wez,
welcome back
It seems to be a DNS issue , since you are able to ping internet but not access website, can you put the DNS server Ip to be 4.2.2.2 on the host machine and try again???
Varun
KingPrawns Thu, 09/22/2011 - 05:03
Ah, that's fixed me going out on port 80 ( i can access google at least!) but what about connections coming in?
When trying to browse to a website on the server externally I just get a connection refused error. Guessing that's the firewall side?
varrao Thu, 09/22/2011 - 05:07
Could be possible!!!!
I woudl request you provide me the following details:
Ip address of the server
Public ip used for this server
Is it behind the Inside interface??
I'll let you know the config for it.
Varun
varrao Thu, 09/22/2011 - 05:58
Hi Wez,
Thanks for the information, I have gone through it and I would suggest that the configuration is fine, casn you test with packet-captures, as I had suggested you earlier in the thread and check where the packets are getting dropped??
Varun
Make sure the port on the server is open as well.
KingPrawns Thu, 09/22/2011 - 06:34
Ran a port scan via (https://www.grc.com/) and it's come up with port 80 being closed. I don't think it's an issue on the server itself as I've just scanned an identical server from the subnet it came from and port 80 came up as open.
I get how packet caps work for pinging, does it function the same way for web traffic?
Obviously I can't browse from 4.2.2.2, do I need to get an external IP and try connect from there?
varrao Thu, 09/22/2011 - 06:43
Hi Wez,
Yes, you need to access the url from outside for it, for applying captures use this:
access-list cap permit ip any host xx.xx.xx.148
access-list cap permit ip host xx.xx.xx.148 any
access-list cap permit ip any host 10.150.3.148
access-list cap permit ip host 10.150.3.148 any
cap capo access-list cap interface outside
cap capin access-list cap interface inside
after this try accessiong the url from outside, and then collect the following outputs on ASA.
show cap capo
show cap capin
This shoudl tell where packets are being dropped.
Varun
varrao Thu, 09/22/2011 - 07:09
Hi Wez,
Thanks for the data, as you can see in the captures, as soon as the firewall sends a request for the connection, the server is sending a Reset for it, so I woudl suggest you to troubleshoot why the server is sending a reset. Ceck if any firewall on the server is blocking the connection. Try putting an exception for the port 80.
S -------> SYN      (initial connection request)
R -------> Reset
Hope this helps.
Varun
KingPrawns Thu, 09/22/2011 - 07:13
I think I've fixed it!
The captures were returning with it all clear, so I did some digging and it looks like there was an entry in the registry for the old ip address that stopped IIS from returning any sites.
(HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\HTTP\Pa rameters\ListenOnlyList in case anyone else has the problem.)
Once again, much appreciated!
varrao Thu, 09/22/2011 - 07:16
Hey thats great!!!!!!!! Thanks for the rating
-Varun
