07-20-2011 06:44 AM - edited 07-03-2021 08:27 PM
I have two wireless networks configured in the AP1200, both SSIDs are configured with WPA.
SSID 01: configured whit WPA
SSID 02: configured whit WPA
I have configured the access-list number 700, and I would like to apply to a single network. Achieving the following:
SSID 01 : WPA + Mac Filter, using the ACL number 700.
SSID 02: WPA
How I can apply the list 700 to the first SSID only ??
Thanks !
07-20-2011 07:18 AM
I am not sure if this works!! i wanna try, coz MAC filter is a Global configuration and for radio interface not for SSID.. please try the below and see if this helps..
here is the config
en
conf t
access-list 700 permit XXXXXXX XXXXX
exit
en
conf t
int dot11 0.1
bridge-group 1 input-address-list 700
end
See if this helps!! Lemme know if this helps
Please dont forget to rate the usefull posts!!
Surendra
07-20-2011 07:40 AM
ok, I will comment
04-11-2013 01:05 AM
Did you get the ACL working on the specific dot11 subinterface ?
Or does it only work in the global configuration ?
04-11-2013 03:20 AM
If you have one ssid , accordingly one bridge-group needed you can apply under the global configuration.
Please make sure to rate correct answers
04-11-2013 04:26 AM
yes but if you have multiple SSID's and you want to block the user using this MAC ACL on 1 SSID but not all the SSID's.
You would need to use the bridgeroup statement:
int dot11 0.1
But i wanted to know if the command worked out for ricardorojas123 since he said he would comment....
However i have already implemented the config in a testcase and it seems to be working.
Also when using command for the global configuration:
dot11 association mac-list 700
The dot11 interfaces will reset which should be a NOTE in the documentation i guess
