3550 and 3560 - Unable to bring fiber interfaces up
Jul 20th, 2011
Guys,
Not sure what I'm missing, however, I'm unable to bring a fiber interface up on two switches to trun. Below is the information from running conifig and show int. One swtich is at int gi0/1 and the other at int gi0/3. The link will be configured as a trunk eventually, but for now I just need it up.
Thanks for any and all assistance.
First Switch - Show run int gi0/1
interface GigabitEthernet0/1
switchport trunk native vlan 10
switchport mode trunk
logging event trunk-status
end
-- Second switch - Show run int gi0/3
interface GigabitEthernet0/3
end
First Switch - Show int gi0/1
GigabitEthernet0/1 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is 000f.f791.7cb1 (bia 000f.f791.7cb1)
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive not set
  Auto-duplex, Auto-speed, link type is auto, media type is 1000BaseLX
  input flow-control is off, output flow-control is off
  Last input 00:31:32, output 00:31:36, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     14989 packets input, 17579854 bytes, 0 no buffer
     Received 290 broadcasts (0 multicast)
     0 watchdog, 95 multicast, 0 pause input
     109 packets output, 10360 bytes, 0 underruns
0 output errors, 0 collisions, 19 interface resets
Switch 2 - Show int gi0/3
GigabitEthernet0/3 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is 0019.e877.f21b (bia 0019.e877.f21b)
  MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
  Keepalive not set
  Auto-duplex, Auto-speed, link type is auto, media type is unknown
  input flow-control is off, output flow-control is unsupported
  Last input never, output never, output hang never
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 multicasts)
     0 watchdog, 0 multicast, 0 pause input
     0 packets output, 0 bytes, 0 underruns
     0 output errors, 0 collisions, 7 interface resets
Switch1 - show int gi0/1 switchport
Switchport: Enabled
Administrative Mode: trunk
Operational Mode: down
Administrative Trunking Encapsulation: dot1q
Negotiation of Trunking: On
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 10 (VLAN0010)
Administrative Native VLAN tagging: enabled
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk Native VLAN tagging: enabled
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk private VLANs: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Protected: false
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
Appliance trust: none
Switch2 - Show int gi0/3 switchport
Switchport: Enabled
Trunking Native Mode VLAN: 10 (DATA-WORKSTATION)
Voice VLAN: none
Administrative private-vlan trunk associations: none
Administrative private-vlan trunk mappings: none
Protected: false
------ Added info ---- Show version ---
Switch1
Cisco IOS Software, C3550 Software (C3550-IPBASEK9-M), Version 12.2(25)SEE2, REL
EASE SOFTWARE (fc1)
Switch2
Cisco IOS Software, C3560 Software (C3560-IPBASEK9-M), Version 12.2(55)SE3, RELEASE SOFTWARE (fc1)
Jon Marshall Wed, 07/20/2011 - 12:04
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
What have you used to connect the switches ie. straight thru, crossover, fibre ?
Jon
nikalleyne Wed, 07/20/2011 - 12:09
It's a GBIC connector. When they are plugged into Dell Switches they light up without any issues
marcosgessolo Wed, 07/20/2011 - 12:17
take a look on gbic on interface gi0/3.
The media type is "unknown".
nikalleyne Wed, 07/20/2011 - 12:19
Yeah I noticed that. Not sure why it is taking into consideration it lights up when plugged into the Dell Switches. This is why I'm confused
hulbertj17613 Wed, 07/20/2011 - 12:19
How old are the Dell switches? Try "speed nonegotiate" on your interface.
nikalleyne Wed, 07/20/2011 - 12:44
Dell Switches are about 2 - 3 years old
I had already tried  the speed nonegotiate - retry again but it does not work still.
speed nonegotiate
end
001104: Jul 20 12:39:52.098: %LINK-3-UPDOWN: Interface GigabitEthernet0/3, changed state to down
speed nonegotiate
end
000026: *Feb 28 18:51:11.249: %LINK-3-UPDOWN: Interface GigabitEthernet0/1, chan
ged state to down
glen.grant Wed, 07/20/2011 - 12:50
  • Purple, 4500 points or more
   Being fiber I assume you swapped transmit and recieve around to check .  Also verify it is a cisco gbic in the side that says unknown.
nikalleyne Wed, 07/20/2011 - 12:59
Guys,
Thanks for the assistance. We changed it to a genuine cisco and it's all good now.
Thanks for all the help. It's very much appreciated the prompt response which I received to my question.
hulbertj17613 Wed, 07/20/2011 - 14:42
If you didn't have cisco SFP's and you didn't have the hidden command to allow non-cisco sfp's to work, these ports should've been err-disabled?
nikalleyne Thu, 07/21/2011 - 05:50
Actually the port did go into err-disable state at times. Would you mind saying what is the hidden command to allow non-cisco sfp's to work.
