WVC200 and bad audio on monitor software
mpyhala Wed, 07/20/2011 - 14:46
Hi Rick,
Thank you for posting. I have not seen this issue before. I searched cisco.com for the WVC200 software and found that the latest version is 1.2
Where did you get version 2.0.0.14? Can you post a screenshot of the software?
THanks for the info.  I had been using over 9 cameras so the standard software which supports 9 was not enough and i found another linksys monitor software that worked for more cameras.  in trying the software you reccomended the audio works perfectly so it must have been a compatibility issue with the other linksys monitor which i have sinced stopped using.
Thanks for the help.
Related Content
