07-21-2011 06:31 AM - last edited on 03-25-2019 04:15 PM by ciscomoderator
Does anyone have a working a config or any ideas as to to getting radius to work on a 2950G switch with an older IOS of 12.1(22)EA1.
I have radius setup on a windows 2k8 box and all of my other switches 2960's and above have no issues. I am unable to input the nas-identifier of 32 into the config using - radius-server 32 attribute 32 include-in-access-req format %h as well as the aaa session-id common commands.
Doing a debug radius says that the radius server is not defined.
Here is a snippet of my log:
Also attached is a copy of my current running config.
Any help would be greatly appreciated.
Shawn
07-21-2011 08:22 AM
If you notice below, there is no "
aaa authorization exec default group radius_ew local". This is because, even though the device get's authenticated it fails the authorization. So if you wish to go straight into enable mode add the following to your vty line
line vty 0 15
privilege level 15
Below config is mine
login authentication Maxxam-RADIUS
IOS (tm) C2950 Software (C2950-I6Q4L2-M), Version 12.1(22)EA2, RELEASE SOFTWARE (fc1)
aaa new-model
aaa authentication login RADIUS-GROUP group radius local
aaa accounting exec RADIUS-GROUP start-stop group radius
ip radius source-interface VlanX
radius-server host 192.168.x.20 auth-port 1645 acct-port 1646 key MyKey
radius-server host 192.168.x.11 auth-port 1645 acct-port 1646 key MyKey
radius-server retransmit 3
radius-server deadtime 1
This should work for you
aaa authorization exec default group radius_ew local - DELETE THIS LINE
if you wish to use radius at the console login
line con 0
login authentication radius_ew - ADD THIS LINE
privilege level 15 - ADD THIS LINE
Radius on TTY lines
line vty 0 15
P.S. You should upgrade to 12.1(22)EA14
Let me know if this helps
07-22-2011 06:57 AM
Thanks Ill give this a try and update you in about an hour...
07-22-2011 08:42 AM
Getting the below error when trying to apply the command -
Any suggestions
03-13-2012 12:23 PM
Can anyone help me further with this. I need to be able to configure radius on some old 2950 switches running IOS 12.1 but the commands are different from the newer IOS....
07-25-2012 04:17 AM
this is my cfg:
aaa new-model
aaa authentication login default local group radius
radius-server host x.x.x.x. auth-port 1645 acct-port 1646
radius-server key 0 yourpassword
line vty 0 15
privilege level 15
