07-22-2011 10:12 AM - edited 03-21-2019 04:23 AM
do we still not support MoH for internal calls with the AP541N
Document below only states AP521
https://supportforums.cisco.com/docs/DOC-9495
Thx
Jo
07-25-2011 11:11 PM
Hi Joachim,
Not sure what you mean by this question??
Lets say you have a Cisco 7925 connected to the AP541N and you place someone on Hold they will get the MOH, alternatively if say it was an internal call to you and the "A" end place you on hold, you will hear the MOH, well this is how it should happen and have not seen it work otherwise...
Or have not understood your question/problem correctly??
Cheers,
David.
07-26-2011 03:49 AM
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/7x/moh.html#wp1043959
"With the increasing diversity of network technologies, in a large single-site campus it is likely that some endpoint devices will be unable to support multicast. For this reason, you might have to deploy both unicast and multicast MoH resources. For example, wireless IP phones do not support multicast due to the behavior of wireless technology. Thus, when deploying wireless IP phones, you have to configure both multicast and unicast MoH."
The document refers to call manager. On the UC500/CME MOH is configured using multicast by default.
07-26-2011 04:19 AM
Thx for replies.
Will try to configure unicas t on the UC500 if possible.
Jo
