Term len 0 equivalent ?
Answered Question
Jul 26th, 2011
I would like to grab a show run-config without the breaks so I can run it through the WLC Config Analyzer. (On a side note, does anyone know where to get the WLC Config Catcher that the training video mentions ?)
I can't use "config paging disable" with the code i am running, 4.0.217.0 on a WS3750:
(Cisco Controller) > config paging disable
Incorrect usage.  Use the '?' or <TAB> key to list commands.
Any advice gratefully received.
NM
Correct Answer by pcroak about 5 years 9 months ago
The WLC config catcher tool is no longer being developed/supported. The main reason for this is that you can use "config paging disable" on latest 4.2/6.0/7.0 WLC code to obtain similar results.
I realize that you are running version 4.0.217.0 at this time, and unfortunately the only option will be to issue the "show run-config" hitting enter for the various sections.
The good news is that the WLCCA will be able to parse through the breaks automatically.
-Patrick
Overall Rating: 0 (1 ratings)
Correct Answer
pcroak Tue, 07/26/2011 - 11:52
  • Cisco Employee,
-Patrick
