3560G-PoE error
Jul 26th, 2011
Hey guys
  I had a question regarding a switch which is not working properly. Over at the university here last Friday we had a 30-second power outage wreaked a little havoc on our networks. One of the switches did not come back up properly (the 3560G). It keeps failing one of the POST tests, with the output provided below. Most literature I'm reading, especially from Cisco itself, keep stating that POST test failures are mostly hardware failures that cannot be recovered from. However, I've read some things out there about booting into ROMMON mode and re-installing the IOS. So I'm wondering what I should do, should I consider this switch dead and go to technical support? Or is placing a new IOS image file worth a shot?
Ehsan
POST ouptut:
____________________________________________________________________________________________________________________
POST: CPU MIC interface Loopback Tests : Begin
POST: CPU MIC interface Loopback Tests : End, Status Passed
POST: PortASIC RingLoopback Tests : Begin
POST: Failed Packet Receive asic 5 queue 0
POST: PortASIC RingLoopback Tests : End, Status Failed
POST: port-asic ring loopback test failed
driver class subsystem initialization failed
*Mar  1 00:00:12.826: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
*Mar  1 00:00:12.826: %SYS-2-ASSERTION_FAILED: Assertion failed: "reg_used_xdr_portid_to_lc_logical_slot()" -Process= "Init", ipl= 0, pid= 3
-Traceback= CD2FD8 CD3724 C4E95C 1DB7C0 1DB9B0 14E9028 14E90C0 CDEB38 CDED74 981954 97854C
%Software-forced reload
00:00:13 UTC Mon Mar 1 1993: Unexpected exception to CPUvector 2000, PC = 97F9C8
-Traceback= 97F9C8 97F98C 1DB7C0 1DB9B0 14E9028 14E90C0 CDEB38 CDED74 981954 97854C
=== Flushing messages (00:00:13 UTC Mon Mar 1 1993) ===
Buffered messages:
Queued messages:
*Mar  1 00:00:13.623: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
*Mar  1 00:00:13.245: %SYS-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure console debugging output.
*Mar  1 00:00:13.505: %Insufficient flash filespace for extended crashinfo.
Cisco IOS Software, C3560 Software (C3560-ADVIPSERVICESK9-M), Version 12.2(46)SE, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Thu 21-Aug-08 15:26 by nachen
Debug Exception (Could be NULL pointer dereference) Exception (0x2000)!
SRR0 = 0x006121CC  SRR1 = 0x00029230  SRR2 = 0x006113D4  SRR3 = 0x00021000
ESR = 0x00000000  DEAR = 0x00000000  TSR = 0x8C000000  DBSR = 0x10000000
CPU Register Context:
Vector = 0x00002000  PC = 0x0097F9C8  MSR = 0x00029230  CR = 0x48000042
LR = 0x0097F98C  CTR = 0x0019E7D0  XER = 0x00000051
R0 = 0x0097F98C  R1 = 0x026D0D58  R2 = 0x00000000  R3 = 0x00000000
R4 = 0xFFFFFFFE  R5 = 0x00000000  R6 = 0x026D0D40  R7 = 0x00000000
R8 = 0x00000000  R9 = 0x0245B0F0  R10 = 0x02190000  R11 = 0x00000000
R12 = 0x000033BD  R13 = 0x00110000  R14 = 0x00CDED14  R15 = 0x00000000
R16 = 0x00000000  R17 = 0x00000000  R18 = 0x00000000  R19 = 0x00000000
R20 = 0x00000000  R21 = 0x00000000  R22 = 0x00000000  R23 = 0x00000000
R24 = 0x00000000  R25 = 0x00000000  R26 = 0x00000000  R27 = 0x00000001
R28 = 0x0000049B  R29 = 0x01A1989C  R30 = 0x01BFE9C0  R31 = 0x00000000
Stack trace:
PC = 0x0097F9C8, SP = 0x026D0D58
Frame 00: SP = 0x026D0D68    PC = 0x0097F98C
Frame 01: SP = 0x026D1030    PC = 0x00C4EA38
Frame 02: SP = 0x026D1048    PC = 0x001DB7C0
Frame 03: SP = 0x026D1098    PC = 0x001DB9B0
Frame 04: SP = 0x026D10A0    PC = 0x014E9028
Frame 05: SP = 0x026D10B8    PC = 0x014E90C0
Frame 06: SP = 0x026D10D8    PC = 0x00CDEB38
Frame 07: SP = 0x026D11E0    PC = 0x00CDED74
Frame 08: SP = 0x026D11E8    PC = 0x00981954
Frame 09: SP = 0x00000000    PC = 0x0097854C
Switch uptime is 16 secon
Overall Rating: 0 (1 ratings)
Evess1982 Tue, 07/26/2011 - 10:24
Forgot to mention something. Once is fails that POST test, it will not complete the post process and allow me access to the console. It will keep reloading the switch and try the POST test once again. The IOS image extracts fine, but again it will keep failing POST. It keeps at this circular process.
manju.cisco Tue, 07/26/2011 - 10:45
  • Bronze, 100 points or more
Hi Ehsan,
You must go to cisco tech now., no other go
Below failure indicates its hardware failure
Evess1982 Tue, 07/26/2011 - 10:57
Thanks Manju, I feared that would be the case.
Ehsan
Muhammad Ismail Tue, 07/26/2011 - 11:14
hi Ehsan,
If the switch fails POST, the System and Ethernet management port LEDs are amber.
POST failures are usually fatal. Contact your Cisco technical support representative if your switch does not pass POST.
Router.Maestro Sat, 01/19/2013 - 12:40
Yes, but does anyone know how to fix these types of problems on your own, without access to Cisco Tech Support?
I have a WS-C3560-48PS with the following indications:
POST: Inline Power Controller Tests : Begin
POST: Found inline power controller write failure, inst 0
POST: Inline Power Controller Tests : End, Status Failed
POST: Inline Power feature is disabled on this switch
POST: PortASIC Port Loopback Tests : Begin
POST: Failed PortPhyLoopback Packet Test asic_index 1 port_hardware_index 8
POST: Failed PortPhyLoopback Packet Test asic_index 1 port_hardware_index 9
POST: PortASIC Port Loopback Tests : End, Status Passed
%PLATFORM_ENV-3-LOOPBACK_PORT_POST_ERR: Fa0/7 can't be brought up because it failed POST in Loopback test.
%PLATFORM_ENV-3-LOOPBACK_PORT_POST_ERR: Fa0/8 can't be brought up because it failed POST in Loopback test.
Also, Fa0/7 and Fa0/8 are showing amber. The switch does boot up and has normal layer 2 & 3 connectivity.
Is it because Fa0/7 and Fa0/8 are failed that the PoE has failed? Could problems with these two ports cause the PoE to be disabled?
The Cisco guide, Troubleshooting Power over Ethernet (PoE),
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/troubleshooting/g_power_over_ethernet.html ,
indicates that the PoE section of the power supply could be at fault, if there is no PoE on all or some ports, and the rest of the switch is functioning normally. In this case, a replacement power supply would seem to be in order.
However, I am not sure how or if the failure of the 2 FastEthernet ports 7&8 are confounded with the PoE failure, if at all.
Does anyone have experience repairing such problems?
Leo Laohoo Sat, 01/19/2013 - 14:01
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
It's a hardware failure.  You need to get the switch RMA-ed.
Router.Maestro Sat, 01/19/2013 - 14:03
I left out the following from the failure indications I just posted:
%ILPOWER-3-CONTROLLER_POST_ERR: Inline Power Feature is disabled on this switch because
     Power On Self Test (POST) failed on this switch.
     Please consult TECH support for further assistance
Leo Laohoo Sat, 01/19/2013 - 14:34
  • Hall of Fame,
    2017 LAN, Wireless
Kerry,
Unless you are an electronics expert (which I am not), I recommend you contact Cisco TAC and get the unit RMA-ed.  It's as close as you'll get as a electric-powered door jam with fancy lights.
(Take away the fan and it's a very good floor heater.)
