Span to PC Port - Cisco 7941
Answered Question
Jul 27th, 2011
Hi, I'd like to enable 'Span to PC Port' on a cisco 7941 - [Settings - Device Configuration - Ethernet Configuration - Span to PC Port] so we can have a look at the traffic with an analyser and ensure the TOS value is correct.
We are using v7.1.3 CUCM
Phone load file SCCP41.8-5-3S
How do you go about this?
Thanks in advance,
Brendan
Correct Answer by clileikis about 5 years 10 months ago
Hi Brendan,
Check out the following post:  https://supportforums.cisco.com/message/1172757#1172757
The following settings can be found in CUCM by going to Device > Phone and selecting the appropriate phone:
PC Port  set to enabled
PC Voice VLAN Access set to enabled
Span to PC Port set to enabled
HTH,
Chris
Overall Rating: 0 (2 ratings)
Correct Answer
clileikis Wed, 07/27/2011 - 18:34
  • Gold, 750 points or more
Hi Brendan,
HTH,
Chris
