ā07-28-2011 12:45 AM - edited ā03-11-2019 02:04 PM
Hi All,
Need your help,
I have an ASA 5520 with a CSC-SSM modul,the problem is when i am logging in to my ASDM, on the content security monitoring, it's showing the CPU and memory are at 100%(CSC) but when i directly connect csc-ssm MODULE it comes down,so is it problem with ASDM , java OR csc.
Any idea,
Regards'
Tashbhat.
ā07-28-2011 06:53 AM
Hi Tabish,
What version are you running on the CSC-SSM?
Anu
ā07-28-2011 07:59 AM
Hi Anu,
I am using csc6.6 (csc6.6.1125.0) before 6.6 i was using 6.3, but problem is still there.
Tashbhat
ā07-28-2011 08:39 AM
Hi Tabish,
This may or may not be a cosmetic issue. Anyhow, it needs to be investigated. I suggest you open a TAC case as soon as possible.
Hope this helps!
Anu
ā07-28-2011 08:50 AM
Hi Anu
Thanks for your prompt reply and suggestion .
yes i am going to open TAC for it.
Tabish Bhat
ā06-14-2012 06:00 PM
Can you pls share with me your resolution? I have the exact same problem to a tee even upgraded the same way.
