07-29-2011 02:12 AM - edited 03-16-2019 06:12 AM
Hi All,
I am receiving a LowSwapPartitionAvailableDiskSpace less than 9% critical alert via RTMT/Syslog on the Unity server. There has been no major configuration changes that would cause this. I am running version 7.1 Unity. On reading so far I have found a few sources saying to lower the alarm %age to 1 or 2% which will clear the issue however I would like to find the root cause. I have also read that there are temp files that can be removed with a reboot, is there anyway to remove these without a reboot?
Any advice welcome
09-01-2015 12:03 PM
I am having the same issue with Unity v10. Hopefully an expert can reply soon.
09-01-2015 01:53 PM
Pure the logs / traces from RTMT if this is Unity Connection.
~Avinash
