Can not save my speed dial in CCA 3.0.(1)
Jul 29th, 2011
Hi Folks,
I have UC560 ver: 15.1(2)T with CCA 3.0.(1) , after adding my speed dial for the SPA 508 with S500 expansion module through the CCA 3.0.(1)  the speed dial will disappear once I save my configuration, any ideas?
David Trad Sat, 07/30/2011 - 06:04
  • Gold, 750 points or more
  • Cisco Designated VIP,
    2013 Small Business
Hi Graeme,
CCA 3.1 Is now available for public download and a highly recommended one as well
Click HERE to download version 3.1
Hi B_Rasheed,
I am aware that this is a problem, and the best way to handle it is to log out of CCA altogether, wait for a minute for the JAVA process to be fully terminated, and then load CCA up again, this time do not do anything until CCA has fully discovered the network topology and the voice configuration.
I am not sure if CCA 3.1 will fully fix up these issues but I have my fingers crossed it will
Cheers,
David.
Cheers,
David.
b_rasheed Mon, 08/01/2011 - 09:35
Hi David
Thanks for sharing your ideas, I have tried reloading the CCA from different PCs and I got the same result, could not save the configuration.
Thank you
Rashed
David Trad Mon, 08/01/2011 - 14:53
    2013 Small Business
Hi Rashed,
Have you upgraded to the latest version 3.1 yet?
Cheers,
David.
b_rasheed Mon, 08/01/2011 - 15:32
I did not upgrade to the latest version CCA 3.1 yet, but I will give it a shot and intsall CCA 3.1 and try to save my speed dial configuration.
Rashed
b_rasheed Tue, 08/02/2011 - 10:56
I upgraded the CCA 3.0.(1) to CCA 3.1 and it did not fix the saving issue, I am guessing the CME is acting up and I have to reinstall it or upgrade it to 8.2
David Trad Tue, 08/02/2011 - 13:51
    2013 Small Business
Hi Rasheed,
I am curious... Are these speed dials or are they monitor/watch associations?
Can you paint me a little picture as to exactly what you are trying to do please, something does not seem quite right with what is happening.
Cheers,
David.
b_rasheed Fri, 08/05/2011 - 09:52
Hello David
Sorry I did not get back to you, for sure they are a speed dial, and I am trying to add the speed dial to the expansion S500, I have done it before, please see the attachemnt below:
