Boot 3750 from tftp
Answered Question
Aug 4th, 2011
  • Bronze, 100 points or more
Tell me please is there any way to boot catalyst 3750 (3560, 2960) switch from tftp?
Correct Answer by Leo Laohoo about 5 years 8 months ago
*.bin file is 20MB
Ok then.  I think I know WHY you are in this predicament.  Anyways ...
Download the IOS version 12.2(55)SE.  For a 3750 with only 16mb of flash, this version (55) is the highest you can go.  It says so in the 12.2(58)SE Release Notes.
Overall Rating: 3.2 (6 ratings)
Collin Clark Thu, 08/04/2011 - 07:36
  • Purple, 4500 points or more
There really is only one way...if you're looking for suggestions, use FTP and if you're in a secure environment (which I guess you're not if you're using TFTP) use SCP.
Jon Marshall Thu, 08/04/2011 - 07:52
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Pavel
Are you using the correct filename for the image. See this link for full details of setting up to load image from tftp -
https://supportforums.cisco.com/community/netpro/network-infrastructure/switching/blog/2011/07/20/booting-cisco-router-from-a-tftp-server
note, i have not used this on a 3750 switch so it may or may not work, you will need to test.
Jon
Somasundaram Ja... Thu, 08/04/2011 - 08:57
  • Cisco Employee,
I think it is not possible to boot 3750 switch using tfp. you can try auto install feature.
i have mentioned below the link for auto install feature
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/ffun_c/ffcprt1/fcf002.htm#wp1012146
Otherwise we left with xmodem recovery.
Hope this helps.
Cheers
Somu
pls rate this answer if the content was found useful
Leo Laohoo Thu, 08/04/2011 - 18:39
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
    2017 LAN, Wireless
Can you elaborate what you are trying to do?
Pavel Doronin Thu, 08/04/2011 - 18:51
I try to load IOS that is more than my Catalyst flash )))
Leo Laohoo Thu, 08/04/2011 - 18:55
  • Hall of Fame,
    2017 LAN, Wireless
Ok, then why not delete the un-necessary files so the BIN file can fit into your appliance's flash memory?
Can you post the command "dir flash:" please?
Pavel Doronin Thu, 08/04/2011 - 18:57
IOS file 20 MB
Flash size 16 MB
Not a variant ))
Leo Laohoo Thu, 08/04/2011 - 18:59
  • Hall of Fame,
    2017 LAN, Wireless
IOS file 20 MB
Hold on.  WHAT file are you talking about?  The TAR file (is > 16 mb) or the BIN file (<14 mb)?  You should upload the BIN file as per the link I've posted.
If you have a TAR file then use a free proggie called WinRAR to unpack it.
Correct Answer
Leo Laohoo Thu, 08/04/2011 - 19:18
  • Hall of Fame,
    2017 LAN, Wireless
*.bin file is 20MB
Pavel Doronin Thu, 08/04/2011 - 19:21
Long time ago i boot 2500 router directly from tftp, because ios image was bigger than flash on 2500 router and it works fine!
I try to find the way to do this on Cat3750.
Leo Laohoo Thu, 08/04/2011 - 19:24
  • Hall of Fame,
    2017 LAN, Wireless
Thanks for the ratings.
Catalyst 3750 or 3560 switches with a 16-MB flash memory can experience problems due to flash memory constraints, especially if they are using larger size images, such as c3750-ipservicesk9-tar, c3560-ipservicesk9-tar, c3750-ipbasek9-tar, or c3750-ipbasek9-tar images. These are the affected switches:
Catalyst 3560: WS-C3560-24PS and WS-C3560-48PS
Catalyst3750: WS-C3750-24PS, WS-C3750-24TS, WS-C3750-48PS, WS-C3750-48TS, WS-3750G-24T, WS-C3750G-12S, WS-C3750G-24TS, WS-C3750G-16TD
The workaround for these switches is to use the corresponding lm images, such as the c3750-ipserviceslmk9-tar or c3560-ipserviceslmk9-tar images, which require less memory. In future releases, images are expected to grow more in size, requiring more need for the lm images.
Pavel Doronin Thu, 08/04/2011 - 19:29
What is lm image? I did not see it befor.
Leo Laohoo Thu, 08/04/2011 - 19:34
  • Hall of Fame,
    2017 LAN, Wireless
Yes.  This is a new kind.  The "l" simply means "lite", filesize wise.  The IOS BIN file is the same but the HTML files have been cut down to fit into a 3560/3750 with 16 mb flash.
Leo Laohoo Thu, 08/04/2011 - 19:26
  • Hall of Fame,
    2017 LAN, Wireless
If you say 3750E or 3750X there's another way to boot:  USB
Pavel Doronin Thu, 08/04/2011 - 19:43
Thanks for help!
Now i think there is no way to directly boot Cat3750 (not E and not X) from tftp.
