08-04-2011 11:41 AM - edited 03-21-2019 04:27 AM
I have heard that the UC 560 (UC560-T1E1-K9) can now ship with 24 licenses included rather than the orginal 16. Can anyone else verify this?
08-04-2011 11:48 AM
Hi Invitechnologies,
To make it happened, you need to upgrade to latest software pack 8.2.
best regards
Rogelio Valtierra
08-04-2011 11:49 AM
so this would also apply to units that have already been purchased?
08-04-2011 01:59 PM
Yes, the new licensing will apply to both new and existing units already purchased... If they are running Software Pack 8.2.0 or newer.
Thank you,
Darren
08-17-2011 05:06 PM
I've upgraded mine, but it still reflects only 16 licenses. Is there something else to do to tell the system to update the quantity?
Index 1 Feature: uc-user
Period left: Life time
License Type: Permanent
License State: Active, In Use
License Count: 16/16/0 (Active/In-use/Violation)
License Priority: Medium
running Version 15.1(2)T4
-Mike
08-18-2011 08:54 AM
Try these commands in the IOS exec commands
"show lic detail"
"show platform software lic"
They will show the right count
David Dunlap
SBSC UC Support Engineer
10:00am to 7:00pm EST
Monday to Friday
Office +1 (866) 606-1866 ext. 601050
Fax +1 (866) 875-3916
<> www.cisco.com/go/SMB>
Sent: Wednesday, August 17, 2011 11:46 PM
To: Arthur Dunlap
Subject: - Re: UC 560 Getting License Increase (from 16 to 24
<> Cisco Support Community>
Re: UC 560 Getting License Increase (from 16 to 24 included)????
created by Michael Jewell
<> in>
SBCS - UC500 - View the full discussion
08-04-2011 02:50 PM
If I am not mistaken, the UC-540 is also getting some rework done to the licensing as well right?
Cheers,
David.
08-04-2011 03:43 PM
That's correct. The UC540 and UC560 will get these changes. The UC520 will not.
Cole
08-04-2011 03:49 PM
Yes.
The UC540 box will start with 24 base licenses instead of 16, I believe and still top out at 32.with one 8U PAK upgrade.
and remember the license math with allowance for analog ports and CIPC..:
24 + 6 = 30 Max licenses capability.
If you add the license PAK my understanfing is you get 2 more extra freebies..???
32 + 8 = 40
08-04-2011 11:35 PM
As Steve has correctly pointed out, the max licenses for UC540 is 40 (including analog and CIPC) and for UC560 it's 138 (including analog ports and CIPC).
08-18-2011 01:44 PM
i have a small question , if i do not have any analog phone can i use this 4 license for ip phone , and does it apply the same for CIPC ,please clarify this important as it is confusing and i can not answer client most of the time
08-18-2011 02:00 PM
Absolutely. The licenses for the UC500 arent tied to a particular model of phone. As long as the analog ports arent set to use skinny those licenses will be freed up for other uses.
Cole
02-20-2012 04:59 AM
I too got the uc560 upgraded with upgrade pack 8.2 but still my licenses did not got upgraded. There is one more thing when i check licenses from the CCA it shows me current capabilities as 30 but i cannot register more than 16 phones.
I need help regarding this as i promised the customer that upgrade will give him extra 8 phone licenses.Below are the outputs from uc560 and cca.
