Cisco ASA vs Fortigate
Aug 4th, 2011
Hello everybody, i need replace a Fortigate 310B with Cisco products, that is, all Web Filtering, IPS/IDS, AV, so, the question is, what we can use to replace?
First, we can use Cisco ASA 5520 right? with CSC Module, so, this for Anti-X, but for IPS? is better router with IPS on IOS? or IPS Sensor? or other Cisco ASA with IPS Module?
thx
Collin Clark Thu, 08/04/2011 - 18:17
  • Purple, 4500 points or more
a.mendezchavez Fri, 08/05/2011 - 11:32
Thanks for answering Collin.
Sounds good, but i cant find any documentation for Cisco ASA & ScanSafe, only 1 article doing WCCP to ScanSafe Gateway and doesnt provide Failover or something.
I want to know about ScanSafe what is the difference between ScanSafe Web Filtering and ScanSafe Web Security?
What about IronPort & CSC-SSM module for ASA?
What do you think?, i need to get  the most stable and robust solution to take off the Fortigate.
Thank you.
Collin Clark Fri, 08/05/2011 - 11:52
I think your best bet is to contact your local Cisco office and have one of their pre-sales come out. They can answer any of your questions and go over all your options. If you can't get someone, let me know and I'll help where I can.
